These NISI rims…. What is going on?
Bikes: several Eddy Merz (ride like Eddy, braze like Jim!)
Quoted: 1148 Post(s)
Liked 2,043 Times
These are/were on my Dad’s Colnago Oro. Notice instead of a sticker is an embossed NISI badge. Pretty fancy. Never seen any wheel with such jewelry.
later notice the strange divots scooped out between the nipple access holes. Maybe to aid glue adhesion? Maybe to lighten it?
dunno. Also don’t know if these are strictly track wheels. Pop had them hanging in the garage, preferring to roll some French rims built by Seattle’s Wheelsmith.
Not a sticker, but a badge that I would suspect could throw off the weight balance
Two chunked out divots, not very well even
Again with the divots (2) between each nipple hole. They look so hastily done.
Quoted: 1869 Post(s)
Liked 666 Times
I've seen those divots on a bunch of Nisi rims, since about 1970. I don't have an explanation, but I think it's a quality rim.
Quoted: 28 Post(s)
Liked 60 Times
Divots were likely a DIY modification to try to give the cement more grab on the rim.
Usually it is the rim joint (opposite valve stem) is the heavy/imbalance point of a wheel, often there is an internal spline inside the rim joint. Back in the 80's there were aftermarket bike wheel weights available that slipped over the valve stem which were intended to re-balance a wheel. Any/all wheel "imbalance" I have ever experienced riding was entirely due to lumpy tires, especially with cheap tubular. Ive had a few MTB tires that are so far out of round that they are hugely annoying to ride on smooth roads.
Liked 2,043 Times
I just noticed the "jewelry" is where the rim joint is. Perhaps it holds the thing together os maybe they had problems with separation and this was the just the lil bit more to insure everything stays put.
In 1976, I bought gold anodized Nisi tubular rims for my first racing bicycle. My Nisi rims also had the drilled countersinking on the outside face, like yours. My rims had a sticker instead of a badge for the branding of Nisi. The overall appearance of the rims I owned vs. yours is otherwise very similar.
So, the drilled countersinking is done by the manufacturer. I believe it's done to lighten the rim.
I've not seen this countersinking done by any other manufacturer. I soon owned Mavic tubular rims (Monthlerery, others) right after I bought the Nisi rims.
I suspect that the ridges on the outside edges may be for improving the glue adhesion. I don't recall whether other manufacturers also had that feature.
Bikes: A few
Quoted: 290 Post(s)
Liked 201 Times
Given the condition of the rim sidewalls, I would venture a guess and say they were used on a road bike.
A few years ago I built up a set of Nisi Campione Del Mondo rims for the Bianchi, and do remember the dimples mentioned. I thought they were for balancing the rim. The dimple pattern if memory serves was random, and not what I would expect if they were for lightening the rim. The treads I think are for glue adhesion. The ones I built had decals, and not the embossed logo.
Nice rims.
Nice rims.
Likes For satbuilder:
Liked 666 Times
So I don't see any reason why the factory did that, but those marks were made before the rims were received by my bike shop.
Liked 666 Times
Nice rims.
Nice rims.
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3931 Post(s)
Liked 6,583 Times
Bikes: 80s Alan Super Record, 79' Somec Special, 90s Rossin(?) Columbus Ego Triathlon, previously: Bianchi SBX Reparto Corse (stolen) and so on...
Quoted: 392 Post(s)
Liked 813 Times
Cicli Berlinetta just posted a pair of NOS ones with factory nylon packaging, and they have it as well...
https://cicli-berlinetta.com/product...622-20mm-290g/
I would say, it helpts ensure to keep the dang together but also a nicer way than a decal to burn their logo into your brain triggering the #wantitnow.....
I like their decal logo as well, but these look cooler in my book:
