Dura Ace Nut, which side works best?
Tange
Bikes: 74 Raleigh Super Course Mk II, 77 Nishiki International, 77 Motobecane Super Mirage, 84 Team Fuji, 85 Schwinn Traveler, 86 Schwinn Prelude, 86 Raleigh Technium 460, 87 Raleigh Technium Tri Lite, 88 Cannondale "Crest", 96 Giant ATX 830, 05 Trek 1000
Quoted: 45 Post(s)
Liked 111 Times
Which way is the easiest for torquing down on it, and hold the cable snug? I see it both ways, and I think Shimano actually shows the bolt side out in their literature. Any opinions on what works best for you, and why?
Quoted: 5930 Post(s)
Liked 2,820 Times
Think about it for a moment. The cable is leaving the adjuster barrel on the bolt head side of the derailleur. Do you really think you want to route it across the unit to the nut side? Odds are you'd get your answer the moment you tried to attach the cable.
The other usual question is "which side of the bolt do I route it to?". The answer is usually in the parts themselves. If there's a hole in the bolt, use it. If not, there's likely a small channel someplace on either side, if so use that.
The worst case scenario is that you go to the wrong side and find the RD doesn't index correctly. if so, reroute the cable and go from there.
FWIW- when I used to teach repair, I'd answer questions like this by suggesting people look at the parts, think a bit, and let the bike itself tell them what's right.
FB
Chain-L site
FB
Chain-L site
Likes For FBinNY:
Tange
Quoted: 45 Post(s)
Liked 111 Times
Oh, I've thought about it, and the design doesn't help. There is no hole in the bolt, and torquing on the nut from above requires you to grip the cage to keep it from moving against the turning of the nut.
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
If I remember correctly they came with bolt head inside from Shimano. I also remember changing them on nearly every one I worked on.
aka: Dr. Cannondale
Quoted: 2172 Post(s)
Liked 3,507 Times
The top picture, nut outside, is the way I orient all of my 740x RD’s. It’s just easier.
Likes For rccardr:
Liked 2,820 Times
I'm sorry. I misinterpreted your original question.
Al long as the cable ends up in the right place, either achieves the same result, so it's up to you.
OTOH - Shimano might have provided a clue to their preference. If the bolt head is knurled on the underside, it is most likely intended to rest on and bite on the aluminum to keep from turning.
In any case, what works right is right.
FB
Chain-L site
FB
Chain-L site
Tange
Quoted: 45 Post(s)
Liked 111 Times
No worries. I've had this sitting on a too small for me Gios Compact for four years, now I'm going to swap it onto a new acquisition; a 1988 Cannondale R500 Crest Team bike.
Quoted: 1955 Post(s)
Liked 2,200 Times
The top picture is correct one, with the hex head outside the RD.
However, the more important question is which index shifters are you using?
That my friend is the real driver to attaching the cable.
John
John
Clark W. Griswold
Quoted: 4485 Post(s)
Liked 4,158 Times
Worst shimano bolt I can recall I replaced mine with a more standard bolt not sure why they did that but Shimano being Shimano I guess. Great derailleur if only they made a longer cage version it would be perfect.
Liked 2,200 Times
A close second was the RD-7700GS. Would be first except for max cog of 27; probably could be pushed to 30.
John
Likes For 70sSanO:
Tange
Quoted: 45 Post(s)
Liked 111 Times
Quoted: 1621 Post(s)
Liked 2,240 Times
The RD in my stash has the nut on the inside like the second picture. That is the way it was when I bought it.
There is a groove in the body for the cable to sit in and it is parallel to the flat for the bolt, which has two flats.
IMHO It is better to pinch the cable with the head of the bolt than twist the cable with the nut. Oh, and there is a washer under the nut. It only makes sense to me to assemble it this way.
VeloBase.com - Component: Shimano RD-7402, Dura-Ace (8sp) First comment addresses this issue too, stating it was shipped with the nut on the inside.
Likes For SJX426:
aka: Dr. Cannondale
Liked 3,507 Times
They came from the factory with the nut inside the RD body. However, very common to reverse the nut (and washer) to make it easier to properly adjust the cable length.
Threading a driver down through the RD body to tighten the nut might be more aesthetically pleasing but it's not really mechanically advantageous.
Quoted: 3623 Post(s)
Liked 3,047 Times
Liked 3,047 Times
And the top picture is a "modification"--as cxwrewnch and rdcardr noted--to make it easier to access the bolt.
Likes For smd4:
Liked 2,200 Times
I’ve been running a 74XX from 1986 until 2015 when I went to an XTR M910 with a triple crank.
My original new boxed LBS 7400 came with the hex nut out without modification.
You can say what you want want, but I was there 35 years ago.
John
John
Liked 3,047 Times
Liked 2,200 Times
Likes For 70sSanO:
Liked 3,047 Times
Besides--the original question has to do with 74xx derailleurs.
Liked 2,200 Times
It is odd that you think the Dura Ace 7700 represents a sold out and pandering group. I personally think it is one of the best groups they produced.
John
Likes For 70sSanO:
Liked 3,047 Times
Why is it odd? Did I say I didn't like 7700? That's all I use. I even have a post about how I think it's the best groups DA ever made. That doesn't mean I don't think they sold out when they made a version of the group available to tourists. The two opinions aren't mutually exclusive.
Bikes: lots
Liked 2,932 Times
So it's "selling out" to make high quality parts that lots of people will buy because they want...high quality parts? Just because they don't pin on a number race they're not worthy?
Likes For cxwrench:
Quoted: 1276 Post(s)
Liked 1,378 Times
So I assume you are still riding a 52-42 with a straight block in the back? But you are right, Shimano seems to sell out all the time that’s why it’s so hard to find their top tier stuff in stock.
Clark W. Griswold
Liked 4,158 Times
They wouldn't but they should have because I wanted it. A Dura-Ace touring group would have been great or maybe something for randonuerring that is racey with more range.
Liked 2,200 Times
True but I am running on 6 speed freewheel. I am sure the XTR would actually run it but I couldn't run the XTR on that bike and do other modifications to make it more practical because of what that bike is and means to me my other bikes yes that one sadly no for stupid reasons I need to get over.
I think when the 7700-GS came out the only difference from the short was the cage length; same max cog.
John
