Looking for a minimalist seatbag
Quoted: 645 Post(s)
Liked 1,565 Times
I have a spurcycle roll-top seat bag that has worked out pretty well but it's starting to crack and it looks like they don't make them anymore. Looking for something that does not attach to the seatpost and fits fairly close to the bottom of the seat since I have a Cycliq fly camera and a small rear light I need to fit on the post under the bag. I don't carry much; 1 tube, levers, CO2 cartridge and inflator, Allen wrench for thru-axle, a couple of surgical gloves, and a disposable wipe or two.
Considering the following:
Arundel Uno
Lezyne Road Caddy
Silca seat roll assymetrico (The Premio seems to no longer be available)
Silca Mattone
Blackburn Grid
Anyone have any feedback on the above bags or have something else to suggest?
On a side note, anyone have suggestions for a compact tubeless plug/repair kit?
Arundel Uno
Lezyne Road Caddy
Silca Mattone
Blackburn Grid
Bikes: Canyon Endurace, Merckx liege 75, Cinelli Vigorelli
Quoted: 167 Post(s)
Liked 114 Times
Silca Mattone - that is what I use on all 3 of my bikes both tubeless and tubed bikes. Not too big has boa and fits just right on the saddle.
If you have a steady supply of something, you can afford it and it's not interfering with your life, there's nothing wrong with being addicted. - Roland Griffiths
Likes For sshakari:
Thread Killer
Quoted: 3214 Post(s)
Liked 1,754 Times
Yeah, the Silca Mattone is great recco based on the OP’s needs— I use one, too!— but also the Cyckit Aeroclam fit’s the bill as well (I run two of those!).
Cyckit Aeroclam P2 on Fizik Aliante R3
Silca Mattone on San Marco Shortfit Racing
Mostly Harmless
Bikes: Have two wheels
Quoted: 13768 Post(s)
Liked 4,579 Times
I have a Road Caddy that I've used on road bikes and gravel bikes. Tucks up tight against the saddle. Holds plenty of repair gear (see below). And has been durable.
Loaded up here with; road tube, 2 Co2, air chuck, Park IB-3, tire boot, patch kit.
Likes For rjones28:
Should Be More Popular
Quoted: 22714 Post(s)
Liked 9,074 Times
Quoted: 7096 Post(s)
Liked 11,217 Times
Here you go. And unlike the Silca option, it doesn't rely on an overly-complicated (i.e., failure prone) Boa system.
This tubeless plug kit is inexpensive, small, and works like any other. I've had mine for 3.5 years and the plug strips are still sticky and perfectly usable.
Quoted: 4560 Post(s)
Liked 2,804 Times
I've been satisfied with the Lezyne Road Caddy for a few years. No problems. Holds up well. Packs more than I'd expected, although I had to switch to a smaller CO2 chuck and flatter multitool, and Continental's lightest, thinnest butyl tube (Race Lite?). But it all fits.
Bikes: '23 Poseidon Redwood, '07 Specialized Roubaix Comp Triple, '12 Gravity Fixie, '21 Liv Rove 4, '06? Giant EB Spirit
Quoted: 345 Post(s)
Liked 237 Times
Another vote for the road caddy
It’s been great
Advocatus Diaboli
Quoted: 4781 Post(s)
Liked 1,545 Times
Arundel Uno
Arundel Uno
Bikes: Factor O2, Caad10, Caad2
Quoted: 365 Post(s)
Liked 122 Times
Another option is the Orucase 25 Holds quite a bit and is very secure to the saddle rails.
Bikes: 2016 Cervelo R3 & 1999 Litespeed Tuscany
Quoted: 161 Post(s)
Liked 139 Times
Make sure to do your research with the Aeroclam mentioned above. I looked into it a couple of years ago and they only supported certain saddles at the time. Things may have changed though.
I use the Road Caddy and it works great for me.
Liked 11,217 Times
Sunshine
Quoted: 11057 Post(s)
Liked 7,611 Times
Speedsleev Ranger. It comes in 3 sizes, 5 different colors, does not attach to the seatpost, and stays in place(no sway). It also uses simple velcro so it is fast to mount or remove and wont fail(like Silca Boa styles used to). The velcro is nowhere close to contacting lycra shorts too, which is important.
I have had this style bag on all my road bikes and gravel bike for almost 3 years now. The large size fits a big 35mm tube, multitool, tire levers, patch kit, chainlink, and co2 inflation.
They are often on sale for under $25.
Likes For mstateglfr:
Super-duper Genius
Quoted: 768 Post(s)
Liked 984 Times
As an alternative to any bag, I would suggest the Apex Occam strap. The number of items in your kit would be pushing the limits of this attachment method, but it could work. You would probably want to roll up all the smaller items in your tube and then attach this bundle to your seat rails with the strap. It's a very simple, lightweight solution and can be quite secure. I have one and sometimes use it to carry a raincoat somewhere on my bike frame. Mountain bikers use them for all sorts of things, including repair essentials, such as what you're carrying.
Quoted: 1447 Post(s)
Liked 2,034 Times
one of my 'hobbies' is accumulating small seat packs lol
I used the Cannondale seat pack at top right for years ; held multitool, tube, two levers, patch kit, two co2 cartridges, qwickfill, etc
had a small leather strap sewn on to the back part of the pack so I could attach a small taillight (at the time seat packs did not have these attachments)
the three packs bottom left (and top / second from right) are slim/narrow packs that have a 'vertical' profile when installed
Thread Killer
Liked 1,754 Times
There are really lots of good options nowadays, which is quite different from the way it used to be not-so-many years ago.
I think one has to go out of their way to find a small saddle bag with faults, whereas it used to be that even top brands could have problems, like too long velcro straps that would furl at the ends, bags which weren’t secure and would sway on the bike, weren’t water-resistant let alone waterproof, or had crummy construction.
The other thing which makes it hard to go wrong is that we generally just don’t use bags as heavily as we used to. Bike quality is better, so we’re not in-and-out of the bag as much, and with things like smartphones and tubeless tires, we don’t need to carry as much either, so seat packs don’t need to meet the same demands.
got the climbing bug
Bikes: one for everything
Quoted: 636 Post(s)
Liked 929 Times
Blackburn Grid on the roadie is nice and slim. I use Almsther on the gravel rig since the tube is larger, but same style.
I hate bags that need a velcro strap on the seat post. Often leaves rubbing marks over times. Only exception is apidura bike packing style bag there the seatpost strap is very secure and doesn't rub.
Rule #10 // It never gets easier, you just go faster.
Liked 11,217 Times
Liked 11,217 Times
The Boa dial is a solution in search of a problem, and not even a very good one. Having a seatbag's Boa dial fail in the middle of a race would be a real PITA.
Liked 11,217 Times
I’ve never heard of a race that does not allow them.
Have you ever looked at the rigs that people ride in long gravel races like Unbound? Large saddlebags, frame bags, and top tube bags are not at all uncommon — often one of each on a bike.
I’m curious why you think that saddlebags would be disallowed in races. After all, race directors have strong interests in everyone making it back to the finish line under their own power.
your god hates me
Bikes: 2016 Richard Sachs, 2010 Carl Strong, 2006 Cannondale Synapse
Quoted: 1270 Post(s)
Liked 1,314 Times
(Admittedly I have no idea what standard protocol for off-road races might be.)
Liked 11,217 Times
Century Road Club Association, the organization that hosts all the local licensed criterium and stage races in my neck of the woods, explicitly forbids lights, pumps, or saddle bags on participants' bikes during road races. I just assumed that was standard protocol for all such licensed races.
