Converting a 2-speed freewheel to fixed gear (1 speed)
Hi all
I'm basically looking if it is possible to convert a 2-speed freewheel to fixed gear (1 speed). I found a nice bike second hand but it's two-speed. The guy says you can change gears by slightly pedaling backwards.
Is this a stupid question and impossible to do, or not?
Sorry if this is a stupid question. I'm REALLY new to all this
Thanks in advance!
Thanks in advance!
Veteran Racer
Bikes: 32 frames + 80 wheels
Liked 795 Times
Sounds like you have a 2-speed kickback hub of some sort like a Sachs Duomatic. So, basically it is what it is and you can't change it. Also, a fixed gear does not coast, so what you are really trying to do is convert into it into a single speed, which is a one speed freewheel.
I'll be looking at other options, probably just buying a wheelset that is already fixed.
Veteran Racer
Liked 795 Times
A real fixed gear can pedal backwards, but that hub has a coaster brake, so if you try to pedal backwards you will just activate the brake. All you need is a rear wheel with a track hub, and then screw on a fixed cog and lockring.
Bikes: Soma Pescadero, Surly Pugsley, Salsa Fargo, Schwinn Klunker, Gravity SS 27.5, Monocog 29er
Liked 234 Times
You will have to change the rear wheel for one with a track hub. Hopefully the chainline will line up.
Liked 234 Times
The Motobecane Fantom Cross is back in stock at Bikes Direct. You are better off with that than sinking money into a conversion. By the time you buy a new wheel, spend a bunch of time on it and find out it needs tirews and tubes also, the conversion will cost more than the Motobecane.
