Ultegra brifters getting flakey
usual disclaimer, I mostly work on vintage bikes. However, when the stars align I can get indexing to work on a modern bike.
But my problem is stranger (to me) than indexing. When I release the rear brifter, using the inner lever, I get no click, the lever passes that shift point and nothing happens. This is an intermittent problem that has appeared recently, but today it was ridiculous almost to the point of having to terminate the ride (needed my gears for the hills). Sometimes when I repeatedly attempted the shift it behaved and the chain dropped down (in the rear). The outer lever always worked. When I got home and put it on the stand the symptoms almost totally disappeared. It was missing the shift maybe 5% of the time, instead of 70-80% on the road. Btw, this occasionally happens on the front brifter also, but much less often.
The brifters are Ultegra 10-speed, with Dura-Ace RD. Not too many miles on the bike even though it's 10+ years old. The shifting has been immaculate until this Jan when I put on a FSA K-Wing bar. I've had to tweak the indexing a bit since then in the rear, but this brifter problem just appeared the last two rides and seems unrelated. I did not change the cabling when I switched bars. I just loosened the brifter clamps and moved them from one bar to another. For completeness, it is a 3x10 setup. FSA triple with Ultegra FD.
Ideas/suggestions?
Ideas/suggestions?
Over the hill
Quoted: 1011 Post(s)
Liked 1,236 Times
This is common as brifters age, and usually means it's gunked up and needs to be cleaned and then re-lubed. Here's a video how-to.
It's like riding a bicycle
Likes For urbanknight:
SE Wis
Quoted: 2754 Post(s)
Liked 3,422 Times
The other common shimano STI issue is frayed cable inside the brifter
Likes For dedhed:
Quoted: 1634 Post(s)
Liked 1,831 Times
Two answers:
1. as Urbanknight said, Shimano brifters will gunk up with old grease over time. You need to flush it out with WD40, and then re-lubricate with Finish Line dry lube.
2. The Dura Ace/ Ultegra/ 105 10 speed brifter, even in the best of time, was vague feeling. Because the amount of cable pulled was so short, it's very sensitive to cable wear or friction. Make sure you have new Shimano SP41 housing, and slick type cable. Greasing the cable helps too. Especially the tight loops.
Likes For icemilkcoffee:
Quoted: 454 Post(s)
Liked 104 Times
What shifters? Ultegra is just a model range name, do you mean 6500, 6600, 6700 or 6800? as there are known issues with some of these designs which would help with answering a question like this
Likes For jimc101:
Thx for the tips everyone! I will keep you posted.
Sock Puppet
Bikes: 2014 Cannondale Synapse Carbon, 2017 Jamis Renegade Exploit and too many others to mention.
Quoted: 1031 Post(s)
Liked 863 Times
I would agree the shifters might be gunked up. Try spraying out the inside with WD-40.
I doubt it's a frayed cable. If it were, it would take only a couple of rides between when shifting problems start and when shifting becomes non-existent.
Likes For Lombard:
Quoted: 7111 Post(s)
Liked 11,246 Times
Agreed, but new cables and housing is the logical starting point. Can't hurt to replace them, and might solve the problem. If that doesn't work, move on to cleaning and re-lubing the shifters as described.
Likes For Koyote:
Likes For Bmach:
Cantilever believer
Quoted: 565 Post(s)
Liked 1,950 Times
Guess what I was working on last night?*
My experience has been the WD-40 flush doesn't get the old hard grease out - it just redistributes it and temporarily softens it (similar to flushing with White Lightning Clean Streak). Several weeks to months later, the problem will recur. It's the same problem that Rapidfire trigger shifters for mountain bikes develop with age.
What I've been doing with the Rapidfire trigger shifters is placing them in an ultrasonic cleaner with a heated 4:1 citrus cleaner solution for 5 to 6 8-minute duration passes, working the shifter pawls with an awl or scribe in between each pass to loosen up the mechanism and dislodge the old grease. Unfortunately, road brifters hide the pawls inside the mechanism and they can't be accessed without dismantling; e.g. destruction. I run the brifters thru the cleaner, and once the brifter starts shifting across the full range (typically after 1-3 passes), I'll continue cleaning it in the ultrasonic cleaner on high heat for another 40 minutes (5 passes) to try to get as much grease and gunk out as I can. Then let them thoroughly dry, and lube up with moly disulfide for a low-residue lubrication film. Using this method, I'm having near-100% success with MTB Rapidfire rehabilitation, and good success with brifters, even with shifters what wouldn't move or would stick in one spot mid-shift. Yes, it's a time and effort commitment (plus the need for an ultrasonic cleaner and solvent), and requires removal of the shifters from the bike (which means unwrapping and pulling cables), but I estimate I've saved many hundreds of dollars for myself and the nonprofits I work with in bringing gunky shifters back to life.
* Just finished two sets of brifters (105 and Tiagra, both 9-speed) for bikes I'm taking down to Tucson on Sunday for donation. I think I'll wear the moly stains on my fingers as a badge of hard work and success.
Likes For RCMoeur:
Sock Puppet
Liked 863 Times
Agreed. And some older cables are the cheaper galvanized ones which oxidize and become rough causing friction and poor shifting.
Likes For Lombard:
Quoted: 249 Post(s)
Liked 473 Times
Are the cables now routed internally through the new handlebars? If so it may be the housing/cable may be at a harsher angle causing just enough friction to restrict smooth shifting.
I had this problem with me new Enve h'bars. They allow for internal routing but the angle is so harsh they just didn't allow for smooth shifting. I just placed the housings under the bars and the problem is solved. Shifting is smooth and fast as always.
It is never a bad idea to replace cables/housings periodically...make sure you have smooth arcs for fast and smooth shifting.
Good luck and keep us informed.
Liked 11,246 Times
Just to be clear, though, I think you are correct.: This does not sound like frayed shift cables. As you wrote, that usually manifests and escalates quickly – within one ride. Ask me how I know.😃
Likes For Lombard:
Over the hill
Liked 1,236 Times
Sock Puppet
Liked 863 Times
You gotta really flush them out, like to the point that there's a puddle on the ground and your can of WD40 feels noticeably lighter. But yes, even that is borrowed time in my experience, and it gets more and more frequent until you get tired of it and replace the brifters (or I've heard you can rebuild them?).
Likes For Lombard:
Over the hill
Liked 1,236 Times
Yeah I don't know. Someone once claimed they knew how to do it anyway, but I have no idea if he knew what he was talking about, let alone actually done it before.
SE Wis
Liked 3,422 Times
I've found on my 6600 STI that when it shifts down (adding tension and small to bigger cogs) but starts balking on up shifts (releasing tension bigger to smaller cogs) and the RD spring provides the movement it's time to replace the cable.
However, no one, as yet, has commented on why this problem shows up on the road but not on the stand. That is definitely a confusion factor for me. This behavior is common among shifting problems, I know, but if my cables were sticky, or shifter gunked up, why would it work so well on the stand? There is a night and day difference.
Quoted: 860 Post(s)
Liked 1,103 Times
Likes For Crankycrank:
Cantilever believer
Quoted: 565 Post(s)
Liked 1,950 Times
But nearly all the bikes I'm working on right now are for donation to foster kids or for sale / work trade at the nonprofit co-op. The plan is they go to families with limited maintenance experience, sometimes in other cities, and I'll likely never see them again. I'm not comfortable sending out shifters that I know are likely to be a ticking time bomb in terms of eventually failing, and the organization's budget is limited in terms of buying new shifters for every bike that has gumminess.
That's why I'm glad I discovered the ultrasonic cleaner (and patience) is being remarkably effective in getting the gunk out permanently. To be safe, I tested the concept on my own bikes first, swapping in cleaned Rapidfire shifters or road brifters and then using them on rides for over a year. I had one road brifter stick again, but a second cleaning cycle seems to have solved the problem. The Rapidfires have been just about 100% successful, unless they had been crashed or another problem (although the ST-M290s that are currently bathing in the ultrasonic cleaner are being ornery, but when I started nothing was moving on them at all).
Yes, this method requires considerable work in terms of disconnecting & rethreading cables, removing and reinstalling grips or bar tape, removing other items if needed, and removing and reinstalling covers, adjusting barrels, indicators, etc. But it seems to work for the long term when nothing else does.
Cantilever believer
Quoted: 565 Post(s)
Liked 1,950 Times
...and I keep the parts around to remind me to never do it again. Reassembly, even with careful notes and photos, seems to require 5 to 7 sets of teeny hands to hold multiple items in each spot to get it right. Being that I am roughly anatomically normal and don't have ready access to several very patient small-fingered volunteers, it was an utter failure.
Likes For RCMoeur:
Over the hill
Liked 1,236 Times
RCMoeur Hmmmm, I have a small ultrasonic cleaner. Might give it a try next time I have a sticky shifter. Thanks!
Two answers:
This worked!
I used WD40, then Tri-Flo, with the bike upside down like this video. I rode in the hills yesterday and it didn't miss a shift.
I will return with a long-term report the next time this is necessary. I have no idea about longevity, but if it lasts a year, that will be a big win.
If the problem returns fairly soon, I'll replace the cable and housing before cleaning again.
Likes For sunburst:
Over the hill
Liked 1,236 Times
My experience was more like two months, then gradually shortening intervals until I finally gave up and replaced the shifters. Hopefully your experience will differ.
