147mm vs 160mm Axle Length?
Standard Member
Bikes: 1948 P. Barnard & Son, 1962 Rudge Sports, 1963 Freddie Grubb Routier, 1980 Manufrance Hirondelle, 1983 F. Moser Sprint, 1989 Raleigh Technium Pre, 2001 Raleigh M80
Quoted: 1303 Post(s)
Liked 958 Times
Is 147mm for single-speed? (My dropouts are 114mm.)
Bolt-on, or quick release? Also, what is the threading on your axle?
If your rear dropouts are spaced at 114mm, your bike most likely came with a coaster-brake or 3-speed hub originally. If you want to run derailleur gears, you'll need to respace it to at least 120mm.
Likes For eeuuugh:
Quoted: 1646 Post(s)
Liked 1,866 Times
Likes For icemilkcoffee:
Standard Member
Liked 958 Times
Standard Member
Liked 958 Times
Liked 1,866 Times
Standard Member
Liked 958 Times
Quoted: 3469 Post(s)
Liked 2,844 Times
I would leave that hub for fixed gear service.
Likes For repechage:
