Chamois creame?
Chamois cream?
I don't know anyone that uses this stuff. Does it work ? I've never used it.
Quoted: 4227 Post(s)
Liked 2,491 Times
Likes For wolfchild:
Expired Member
Quoted: 3784 Post(s)
Liked 5,774 Times
Welcome back.
Likes For shelbyfv:
Quoted: 6346 Post(s)
Liked 4,948 Times
Still wearing cotton underwear? Don't. It gets very abrasive to your skin when wet with sweat.
Hair rolls around between your clothes and your skin and the follicles get irritated. It also holds in sweat and prevents the fabric of your shorts from wicking away the moisture as they are suppose to do. Consider shaving short all the hair down there under your cycling shorts.
Wear bike shorts or bibs that fit you well. There are loose fitting shorts for mountain bikers if you can't quite embrace your MAMIL look.
I've never had to use chamois butter or anything similar. IMO, if you have to use it you aren't figuring out why you are getting the saddle sores. I don't get saddle sores.
Likes For Moe Zhoost:
Quoted: 4874 Post(s)
Liked 4,040 Times
If you ride enough, the day will come when you will need lubricant down there or run into saddle sores. If you keep riding on them, they do not go away. Chamois cremes can prevent those issues from happening. (Can, not guaranteed will.) If you have to keep on riding after those sores appear- try Bag Balm. A formulation like a vaseline concocted 120(?) years ago in the early days of cow milkers to alleviate cow tit sores so they'd come up and willingly get milked by those rather harsh machines. It worked but quickly the machines got better and it was no longer needed. But farmer's wives quickly found all sorts of uses for this great medication. And I doubt much time went by before a husband or son had saddle sore issues. (This was the heyday of the bicycle.)
Any good pharmacy. $8 for a small green metal box that looks perfect for a folk medicine of a former century. The stuff works. Use enough and you won't get saddle sores. Got 'em? The stuff makes riding them bearable. Edit: and while I was writing, Moe Zhoost provided the illustration.
Likes For 79pmooney:
Rhapsodic Laviathan
I ride in jeans and ain't wore underwear in years, never get saddlesore.
Likes For Jax Rhapsody:
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2701 Post(s)
Liked 5,975 Times
Makes a wonderful shaving cream in a pinch.
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
52psi
Quoted: 790 Post(s)
Liked 803 Times
I can't believe -- am utterly astounded realizing -- there has never been a thread about this before.
Likes For Fahrenheit531:
Clark W. Griswold
Quoted: 4493 Post(s)
Liked 4,172 Times
Bike Glide by Body Glide is my go to. Easy to apply and no mess.
Likes For BTinNYC:
Quoted: 1325 Post(s)
Liked 1,970 Times
Kucharik is what I have used for quite a long time. Smiles, MH
Quoted: 7118 Post(s)
Liked 11,276 Times
Liked 4,040 Times
Quoted: 4018 Post(s)
Liked 7,530 Times
Likes For tomato coupe:
Rhapsodic Laviathan
Liked 11,276 Times
Likes For Koyote:
Sunshine
Quoted: 11066 Post(s)
Liked 7,631 Times
Rhapsodic Laviathan
Liked 11,276 Times
Rhapsodic Laviathan
Liked 2,491 Times
Noxzema works great. I learned this from an episode of Chris Horner's Corner a couple years back. I was previously using the standard issue "chamois butter", but the cost value for the amount I used daily made no sense long term. I lather up my chamois before every significant ride, and rarely suffer from a saddle sore unless the ride is particularly intense (>6hrs, >4000m, >200km in hot conditions), i.e., very very sweaty. I tend to release a lot of sodium in my sweat which is exacerbated at much higher intensities which ultimately makes for some serious friction, if you know what I mean. Personally not a big fan of chemicals in my undercarriage, so I look forward to this thread proposing me an alternative!
Not sure why the video comes up as 'unavailable' on here, so here is a direct link to the episode he discusses this in (remove the space): https: //youtu.be/_qtAw3_kspQ
Likes For markynels:
Advocatus Diaboli
Quoted: 4795 Post(s)
Liked 1,547 Times
