Help!! Frozen ears!!
After 3-month forced layoff I got back to pumping iron and biking today and at age 78 it ain't easy -- my quads are on fire, can't raise my arms above my shoulders -- think I'll apply about two fingers of Dr. Jack Daniels' ointment !!
Meanwhile -- I launched on my bike for the first time in 3 months, kept it to 3 miles. Temp was 37 deg F. Could not get my helmet on over the wool cap, so, wore only the helmet. Gloves were too bulky, could not operate brake and shift levers so I rode without gloves. About 1.5 miles out, ears and hands were damn near frozen.
Anyone have any suggestions for lightweight, thin balaclava (I think that's what it's called) to wear under helmet, and, some not bulky gloves?
But I did see a Pileated Woodpecker in the woods and a group of 18 Tundra Swans on the river. I live in VA where the Potomac joins the Chesapeake Bay and the swans come here from above the Arctic Circle from early Dec to early March.
Thanks in advance.
Thanks in advance.
There's a million lightweight, medium weight and heavy weight balaclavas. Just go to a store that sells outdoor gear and find a couple in different weights. Bring your helmet and make sure it fits over them.
Also, bike shops, especially the online ones, sell various weights of synthetic skull cap type things. As do outdoor stores, ski shops, running shops etc. Just go look for something, there's no specific brand you need to find.
"lobster" gloves are popular among cyclists. I have some and also just use the same gloves I use for XC and/or downhill skiing, how heavy depending on the temperature, from very thin cycling gloves to heavy skiing gloves. For something inexpensive, readily available, and very functional for cycling, go to a hardware store and pick up a couple different weights of these type of gloves (not this brand necessarily, but the type with rubber palms):
Likes For Camilo:
Sunshine
Liked 8,065 Times
https://www.outdoorresearch.com/us/e...186=936&199=74
This style is sold by countless brands. It's a running ear band. Just Google that.
It's thin, insulates a bit, and heavily reduces wind.
You don't need a ton of insulation, just keeping the wind off the forehead and out of ears is huge.
Likes For mstateglfr:
Likes For Average Old Guy:
climber has-been
Liked 4,059 Times
EKOI THERMO EVO Hood Base Layer
The company only sells direct through their website, and they make kit for several pro teams, so I guess their stuff is decent.
Liked 4,332 Times
First step (granted perhaps a little late now) is to bring that hat with you when you buy your helmet and make sure it fits comfortably under your helmet.
I like simple wool hats that can have a fold at the ears or the edges pulled down further. I find wool much better than acrylic. I wear (and size my helmets for) a Pace of Halo cap under whatever winter hat I use. Hats stay cleaner and my hair feels cleaner. (I have a bunch and always leave with a clean one.)
To get a step more warmth, I use one of those rain covers that fit over the helmet, blocking the vents. Big step up in warmth. I try to arrange it so it is held by velcro and is easily removable when I warm but don't always succeed.
SE Wis
Liked 3,657 Times
Around here I wear windfleece gloves. I think mine are Northface &/or Black Diamond.
I wear an earband so I can just pull it down as I warm. Usually a neck gaiter too
Likes For dedhed:
I wear something like this, a motorcycle helmet liner. There a a lot of types available, some cover the ears, others don't. I've read that motorcyclists wear them to keep from having to clean their helmets.
Mine is thin enough that a minor adjustment of the helmet strap is enough to make it fit just fine.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Thanks in advance.
Thanks in advance.
Take a look at their closeout section, under base layers, and you will find baklavas as well. Motorcylegear.com is a great company, I have been buying from them for years.
I wear a skull cap once it gets cold. Anything you want to stay warm you want to be wind blocking. So, you would want a cap with a tightly woven outer layer, no just a wool cap. I use this skull cap regularly, though I see it isn't available now:
Same for gloves. If you get something wind blocking, you don't need as thick a glove.
While I've not used them, there are things that attached to your bars that you slide your gloved hands into. I think I've seen them called pogies.
Liked 1,760 Times
I wear a Halo headband. When it gets cold enough I drop it down over my ears. The next step is to then wear my very thin balaclava. That seems to work for me, your needs may be different.
As far as gloves, I prefer that gloves with Thinsulate that are medium puffyness but pliable work for me. Again YMMV.
Make sure your gloves and shoes are not too snug, as tight shoes and gloves restrict warming blood flow to the extremities. This also means not gripping the handlebars too tightly, and changing hand positions often enough to also prevent pressure from impeding blood flow.
I applaud your gumption to ride, and congratulate your determination, so I don't want to discourage your efforts, but as a 30 year veteran of year-round bike commuting in Colorado I find I don't really warm up until about the three-mile mark. And even then, the closer the temperature is to my 5F limit the less time I can be stopped at traffic lights or busy crossings before the cold begins to creep back in.
I am "only" 61 as of today (Jan 12), but I hope to still be riding at your age, and also to have your fortitude to get back at it after a break, which gets tougher, the older I get.
Go get 'em!
Go get 'em!
Liked 1,711 Times
A few years ago I bought one of those "scarves" which is basically a fleece tube you put over your head and wear around your neck, but you can pull it up over your head and cover your ears and part of your face if you need to. I don't know the brand or remember where I got it, probably on Amazon or somewhere. But it's really made a difference in cold weather riding. No longer do my ears freeze.
Liked 2,159 Times
Polypro for the win! Ear warmers, skull cap, balaclava. At the OP's 37F I'd just have the ear warmers.
Gloves are a bit harder. Cold weather has almost as many meanings as people, so you pretty much have to feel the gloves in the store, try them on the road, lather, rinse, and repeat.
Liked 3,680 Times
Old fart
Liked 3,675 Times
Does anyone wear a ski/snowboard helmet for winter biking? Or have a winter-specific bike helmet?
Hats under helmets are always tricky for me as my helmets end up feeling really tight - but my ski helmet has built in fuzzy ear flaps and vents that can be closed off, so it's pretty warm without wearing anything under it. The only downside is that it's a little bulky compared to bike helmets.
I think there might be different impact testing/standards for snow helmets - so I don't know if these should actually be used for this purpose or not.
Liked 3,680 Times
https://www.bikeforums.net/winter-cy...met-vents.html
but I too, am a fan of helmet covers, depending on conditions, especially for rain
Liked 755 Times
I have trouble wearing balaclavas until it's in the single digits. Even thin ones are too warm! I usually wear some homemade muffs that go over my helmet straps. I think the commercial designation is 'dog earz.' Checking: yep, sold on Amazon.
For upper 30s, I'd wear something windproof but with a light lining, or maybe some heavier polarfleece gloves that let some wind through to keep from getting too sweaty.
Liked 755 Times
LOL - in really cold stuff I've been known to put clear packing tape over the front vents of my helmet. I use an old helmet, so I don't care if a little tape residue is left when I remove the tape.
Likes For BlazingPedals:
Liked 934 Times
A lightweight balaclava. I also use a pair of earmuffs a lot of times without the balaclava.
Cheers
Cheers
