Shouldn't Bike Shorts And Saddles Work Together?
Bikes: Specialized Sequoia
Quoted: 446 Post(s)
Liked 63 Times
One of my frustrations with saddles and bike shorts is that they often seem to be working against each other.
The saddle manufacturers logically try to remove pressure from the crotch area through the use of cutouts and complex curves. On the other hand, the bike shorts manufacturers (who are often the same company) seem to be working against that by placing padding right back in those same areas. The result is pressure coming from the shorts padding instead of the seat padding. Different cause, same result.
It seems to me like shorts manufacturers should have padding under the sit bones only, and NONE in the crotch area, but I have yet to find a pair of shorts like that. Does anyone know of any?
If a saddle like those made by SMP is used, there is no saddle in the center and the pad in your shorts will work better.
https://www.biketiresdirect.com/prod...nt=Selle%20SMP
Quoted: 4009 Post(s)
Liked 7,516 Times
Locating the edge of a pad anywhere in the crotch/saddle region might cause more problems than it solves.
Likes For tomato coupe:
Quoted: 5234 Post(s)
Liked 3,609 Times
I wear thin lined tri-shorts. no "padding". you might like them too
Quoted: 446 Post(s)
Liked 63 Times
I just think that padding in cycling shorts for male riders that presses up against any parts of the male anatomy is counter-productive to what's being attempted through the use of saddle cutouts (discounting saddle with no nose at all, of course).
Quoted: 446 Post(s)
Liked 63 Times
Honestly, I think the reason why guys like slim saddles and padded shorts is because the slim saddle looks fast and makes the rider look more "cool" and "tough," and the padded shorts make him look more "well endowed" than he really is. Human nature I guess.
Quoted: 4574 Post(s)
Liked 1,718 Times
I respectfully disagree. I have tried several saddles with cutouts like the one you linked to, and if you are wearing typical cycling shorts with pads in the crotch area, the pad still rests on the sides of the cutout and presses up against your testicles (for those who have testicles, anyway).
Likes For Kontact:
climber has-been
Quoted: 3550 Post(s)
Liked 3,708 Times
Edit: @Kontact beat me to it. See Post #9.
Liked 7,516 Times
Yeah, that's it. Without a doubt.
Quoted: 446 Post(s)
Liked 63 Times
When you're wearing cycling shorts, are you saying that you don't have any padding touching and/or around your testicles? The only way I could achieve that with any cycling shorts I've ever owned would be to pull them so far up behind me that the sit bone pads were up around my kidneys.
Quoted: 446 Post(s)
Liked 63 Times
I'm not saying that my testicles are contacting my saddle. I'm saying that the padding between my testicles and the saddle is filling that gap to the point where the padding is pressing against my testicles. The saddle presses up against the padding, which in turn presses up against my testicles. No padding, no pressure. Yes padding, yes pressure.
Disco Infiltrator
Quoted: 3133 Post(s)
Liked 2,115 Times
Bikeforums: Shouldn't bike saddles and shorts work together?
Specialized: Hmmm...
Specialized: Our new Body Geometry SHT system ensures you and your bike are one with the road. Note: BG-SHT saddles only compatible with BG-SHT shorts
Genesis 49:16-17
Genesis 49:16-17
SMP sells a variety of saddle widths base on the width between sit bones. That has nothing to do with looks. I got lucky and got the right width the first time. No comfort problems. SMP starts with the assumption that wider people are likely to have a wider distance between sit bones, so the larger your waist size, the wider the saddle. I have a 30 inch waist, so the narrower models are suggested.
I have to agree that testicles shouldn't be bearing against the saddle.
climber has-been
Liked 3,708 Times
Quoted: 446 Post(s)
Liked 63 Times
Man, I'm confused by your answers. Let's try this. If you were naked, and sitting on your bike in a normal riding position, would your testicles be contacting the saddle? Or are you saying that yours somehow stay up between your thighs instead of hanging down?
Quoted: 446 Post(s)
Liked 63 Times
Maybe this thought process will help explain what I'm saying. Suppose you are riding in unpadded shorts, on an old-school saddle with no cutouts. You are unhappy because you feel pressure between the saddle and your testicles and/or perineum. You complain to your saddle maker, so he solves your problem but creating a cutout in your saddle to relieve the pressure.
Later, you complain to your shorts maker about pain in your sit bones. He starts by making you some shorts with padding under your sit bones, but instead of stopping there, he puts padding all over the whole crotch area, including the areas where your saddle maker put the cutout.
Now, your sit bone pain is gone, but you still have the pressure where the cutouts are, thanks to the shorts padding in that area.
climber has-been
Liked 3,708 Times
This is arguably the best feature of bib shorts.
Edit: While I couldn't find a "how to wear bib shorts" explanation, I did find one for wearing a dance belt, which protects the genitals in the same way. From wikihow:
Adjust your genitals. Your penis is supposed to end up facing upwards, towards your abdomen. And you can quickly accomplish this by reaching your slightly curved palm of your hand down inside the dance belt to scoop up your scrotum upwards inside the supportive pouch, guiding all of the hanging parts to point towards 12 o'clock as you withdraw your hand while the fabric panel hugs and securely yet gently cradles and supports everything in place. Your two testicles will be up in front, not dangling between your legs, as they would unsupported once your body temperature rises due to all the physical exertion of dancing and the body's normal need to keep the testicular temperature from overheating. If the thong part feels overly tight, you can adjust by pulling it slightly lower, but there has to be some tension in order for there to be any support to the male anatomy.
- When properly positioned within the garment, the genitals are held closely and firmly to the lower torso in a raised orientation (in other words, pointing towards 12 o'clock). This is in contrast to most athletic supporters, which typically leave the genitalia hanging downwards so that if you jump there is a bounce.
- If anything feels uncomfortable, adjust it now. You won't be able to do this later especially if you are wearing n elaborate costume that covers your lower torso.
- At first, you can expect to sense some unfamiliar pressure in your nether region, but if the device is of a proper fit you will quickly not notice you're wearing one after a few hours total of getting the hang of using it. You'll eventually come to appreciate the ability to jump, leap, and move without any concern for soreness or discomfort.
Quoted: 446 Post(s)
Liked 63 Times
Ok, and when your riding like that, is there padding in the shorts between your man parts and the saddle? Or is it just the thin fabric of the shorts?
I tried sitting on my saddle, just in my underwear. My testicles do rest on the saddle, but the saddle isn't pushing up on them. My Stratos saddle does have an unusual shape to it, so saddle angle is important. You can't use it nose-up. I set a flat piece of metal on it, then set it nose down by 2.5 degrees with a digital level. The bike has to be sitting on a level floor. I like this shape better than saddles that are relatively flat across the top. SMP makes models with even more curvature and some that are nearly flat along the top.
climber has-been
Liked 3,708 Times
(I assume that front padding is for modesty purposes. If that's what the designers are thinking, it ought to go higher. Just sayin'.)
Quoted: 4862 Post(s)
Liked 4,011 Times
I have found the seat and shorts that work well enough that I pay no attention to either. (Other than saddle sores can be an issue if I get behind on certain maintenance or don't use chamois lube when needed.) I do use suspenders always and much prefer them over bibs that have straps that stretch with age and are not easy to re-tighten.
For me, the seat that works is the Terry Fly. The shorts, Segoi. But don't copy me. Keep trying until you find the ones you don't even notice while riding.
Liked 7,516 Times
Just toss them over your left shoulder ... it helps offset the imbalance caused by the drivetrain being on the right side.
Liked 4,011 Times
My man parts don't stay up and out of the way by themselves. They are held up snugly by the bib shorts, safely lifted out of harm's way.
