Lost my noodle
Lost my noodle
Rather, lost track. I took these apart to do some de-rusting and didn't pay attention to which of these went on the front and rear. Giant brand step through if it makes any difference. Thanks!
Quoted: 4237 Post(s)
Liked 3,963 Times
Most likely the noodle with the longer top casing fitting is the front. That longer black part often has a spring loaded casing seat, to reduce the brake's initial grab.
Try setting up the rear first with the shorter noodle and if that goes well then use the longer one up front. Andy
AndrewRStewart
AndrewRStewart
Mother Nature's Son
Quoted: 865 Post(s)
Liked 1,462 Times
My noodle seems to be disappearing at an accelerated rate.
Quoted: 530 Post(s)
Liked 474 Times
Generally, the one with the acute angle is for the rear. But it's not a big deal,. You can bend these a little bit.
Liked 3,125 Times
left to the rear.
-Oh Hey!
-Oh Hey!
Likes For Hondo6:
Quoted: 5964 Post(s)
Liked 2,873 Times
Depending on frame size, you may need to use the shorter noodle on the rear.
The front has no constraint since the cable is free all the way to the handlebar.
However, there's much less room between the rear brake and the top tube, so you have to accommodate that.
FB
Chain-L site
FB
Chain-L site
