Shimano Gearset History and Specs
I followed the long thread about retrofitting a vintage bike with STIs or Ergo shifters. The thread contains amazingly beautiful bikes and some incredibly talented forum members. It got me thinking about doing something similar, but I have never built up a bike from a frame. I am game, but overwhelmed about going about the component selection process. I had earlier inquired about any simple source explaining the various differences of Campagnola gear of the years and learned no such thing exists, which was consistent with my search efforts.
I have now tried to find similar information regarding Shimano and have had no luck. It would help me to know what years/groupset models would work with 126 or 130 mm frames, how many speeds for each model, etc. My guess is I would likely acquire parts piecemeal and want to make them compatible with the frame and each other. The folks on the retro thread speak with confidence about what they bought and used on their projects. Experience can't be beat; I am just trying to see if I can get it figured out without too much backtracking.
My search skills apparently are lamentable. Thanks for any guidance.
Mike
Mike
aka: Dr. Cannondale
Quoted: 2166 Post(s)
Liked 3,491 Times
Start by telling the group what you want to accomplish.
A 30-speed Sting Ray? A bar end shifted IGH wIth a flip flop hub?
Miracles of information will follow.
Likes For rccardr:
SE Wis
Quoted: 2753 Post(s)
Liked 3,415 Times
Sounds like you need to head down these rabbit holes.
https://velobase.com/
https://www.disraeligears.co.uk/site/home.html
Likes For dedhed:
Dr, you are correct. I would like to find an Italian steel lugged frame, hopefully with a fork. I would the like to buy everything needed to get it on the road. I doubt I would spread a frame, so I would be looking at hubs and grupos that would work with the dimensions of any frame I get. I guess I could go about the other way and buy wheels, hubs, crank, shifters, etc and then get a fram that would fit.
I do have some Campy bikes, but I figured I might have better luck getting Shimano parts for this first effort. If it works ok then I could look at better frames and grupos.
In brief, no Stingrays. Just a nice steel Italian road bike.
Mike
Mike
Edumacator
Quoted: 2521 Post(s)
Liked 3,312 Times
If 126, Shimano tri-color is a nice bullet proof 7 speed group though the brifters are harder to come by sometimes.
1987 Crest Cannondale, 1987 Basso Gap, 1992 Rossin Performance EL, 1990ish Van Tuyl, 1985 Trek 670, 2003 Pinarello Surprise, 1990ish MBK Atlantique, 1987 Peugeot Competition, 1987 Nishiki Tri-A, 1981 Faggin, 1996 Cannondale M500, 1984 Mercian, 1982 AD SuperLeicht, 1985 Massi (model unknown), 1988 Daccordi Griffe , 1989 Fauxsin MTB, 1981 Ciocc Mockba, 1992 Bianchi Giro, 1977 Colnago Super, 1971 Raleigh International, 1998 Corratec Ap & Dun, 1991 Peugeot Slimestone
Quoted: 65 Post(s)
Liked 60 Times
Brifters weren't made for 7 speed. The Dura-Ace STI levers big debut at the 1990 TdF. Officially came out to the public a year later. Ultegra got the brifters a year or two after along with moving to 130mm spacing with 8 speed.
Likes For C9H13N:
SE Wis
Liked 3,415 Times
Bikes: A bunch of old bikes.
Quoted: 292 Post(s)
Liked 895 Times
I've got a couple of sets of the 7 speed RSX brifters. They are easier to disassemble and clean up than the later Ultegra shifters. They require more lever effort and lack the trimming functions on the left shifter that the Ultegra's have.
Likes For daverup:
Quoted: 573 Post(s)
Liked 1,067 Times
IcySwan1 My advice, get a frameset that tickles your fancy and then many will be able to assist you. “Nice Italian” is vague so it’s tough to lend a hand. I have a “nice Italian” bike from 1960 (2 actually) and those have unique challenges just trying to keep the original stuff working.
aka: Dr. Cannondale
Liked 3,491 Times
Ok. If you wind up with a frame with 126 rear spacing, there are ways to modify 8-9-10 speed Shimano hubs to that spacing and then use 8-9-10 speed STI levers.
Rather than go into detail on that right now, let’s see what you buy.
For a frame with 130 rear spacing, literally any modern 8-9-10-11 speed Shimano or Campagnolo group will fit.
So, buy the frame first.
Please keep us posted.
Rusty and rccardr, thanks. I will focus on a 130mm frame. 8-10 speed groupsets will be the sweet spot. I am interested in 90s to 2000s bikes like Mondonico.
It looks like there isn’t just one source for the information, other than dedhed’s suggestions, so I will come back here for recommendations once I snag a
frame.
Thanks one and all.
Mike
frame.
Thanks one and all.
Mike
Veteran, Pacifist
Quoted: 3920 Post(s)
Liked 4,894 Times
What size do ya need?
56cm is where I am at now. I am getting shorter as my shelf life is getting shorter. I have a 57mm Torelli that fits great, though.
I am away from home for a bit, and it likely will be about April before I can get the wicks trimmed and burning again.
Mike
Mike
Quoted: 503 Post(s)
Liked 466 Times
And back to the original question, the Miyata has gone through four major updates over that time, aided considerably by having its rear triangle properly spread and re-aligned to 130mm along ago (had the fork drilled for a modern brake caliper at the same time). It’s now 3x8-speed using essentially Campy Ergo shifters, but it also had Shimano Sora 7-speed STI in one of those upgrades.
I’ve also updated a 1985 Miyata 312, older than my daughter who loves it, to 3x7 using Shimano bar end shifters. Brifters would have been a possibility had she been using drop bars. No rear triangle spread or fork drilling was required.
Veteran, Pacifist
Liked 4,894 Times
My zero bike in Arkansas has 7sp RSX brifters. Taiwanese - Wheeler
Chrome socks, nice sharp ride, flat roads, small cogset
Hasn't been ridden in years.
