Aero-hood position, how to grip?
By aero hood I mean holding the hood but with forearms level. I am still figuring out how to hold the hood securely and comfortably. So far I mainly putting my palms over the hoods, griping the shift cable to prevent me from going over the bar, as shown in the pic. Most brifters don't have cables coming out nowadays, so I am interested how you guys do it.
Quoted: 7729 Post(s)
Liked 3,662 Times
Try keeping at least one finger wrapped under the brake lever if riding in a group, so a bad bump doesn't bounce your hand free, leading to the whole peloton hitting the ground.
Solo ... whatever is comfortable. I usually change my grip frequently, sometime gripping the whole brifter body above the brake lever, usually riding the heel of my hand on the bars at the base of the brifter, sometimes grabbing the brifter body with one or two fingers under the brakes and the others, over.
I have experimented a little with different angles and even different overall locations ... not as far as the 30-degree inward lean some pros are using, but on my bikes, i can play with the set-up to make it suit me.
Of course, major changes mean messing with the bar wrap ....
Likes For Maelochs:
I used to put the little fingers under the brifters, but after one 50-miles ride the joint at the base really hurt and it took a month to recover.
Bikes: SL8 Pro, TCR beater
Quoted: 1027 Post(s)
Liked 595 Times
I rarely use this grip / position. When I do, it's usually for a more aero position (leaned forward). I keep one finger on the brake lever so I can have at least some braking power in case I need it.
Klaatu..Verata..Necktie?
Quoted: 10644 Post(s)
Liked 12,298 Times
Likes For genejockey:
Quoted: 2953 Post(s)
Liked 3,106 Times
Ultegra 6800 hoods. I’ll put my palms on the nubs. Hands relaxed, wrists resting on the flat curve of the bars behind the levers, pinkies wrapped under the brake levers. Focus on keeping the forearms parallel to the ground, and keeping the head up. I only use this grip on good roads while riding solo.
Likes For caloso:
just another gosling
Quoted: 3920 Post(s)
Liked 1,982 Times
Like these riders if your hoods allow it. Thumbs hooked over the top of the nub, heels resting on bars. This is my standard going-down-the-road quickly position, solo or pulling. Very, very comfortable if your forearms are strong enough. Otherwise, more pushups.
These photos are from the should-be-famous Numb Hands post.by DannoXYZ in 2011. Gotta give credit.
Results matter
Results matter
Likes For Carbonfiberboy:
Quoted: 10310 Post(s)
Liked 5,284 Times
My hoods on all my bikes are rotated inward at a pretty significant angle. It helps take pressure off the wrists when trying to ride aero on the hoods.
Likes For bampilot06:
Habitual User
Quoted: 5115 Post(s)
Liked 8,444 Times
I added some inward rotation of the levers on my road bike. I wouldn't call it significant, but definitely not straight. I like it with my Camy Record levers.
Liked 5,284 Times
The ritchey’s are actually straight, had an issue and the LBS re wrapped my bars, out the hoods back straight. i need to fix that.
Habitual User
Liked 8,444 Times
Liked 5,284 Times
Liked 12,298 Times
staring at the mountains
Bikes: Obed GVR, Fairdale Goodship, Salsa Timberjack 29
Quoted: 394 Post(s)
Liked 198 Times
I grip as shown, along with a myriad of other positions during the course of a ride. You're not trying to find one hand position for the entire ride, are you?
Liked 12,298 Times
Liked 1,982 Times
Liked 5,284 Times
Liked 12,298 Times
Tops, corners, ramps, hoods, aero hoods, drops. The last 3 with varying amounts of elbow bend.
Liked 12,298 Times
I can't do pushups since I tore my distal clavicle loose from its moorings on my right shoulder. I mean, unless I want to feel the end of it rubbing and clicking against the acromion.
Quoted: 394 Post(s)
Liked 198 Times
mostly like this
to this
and varying positions in between to maintain comfort.
Likes For superdex:
Liked 12,298 Times
It's the sort of thing which requires and allows you to cultivate a different mind space, much like riding does, where enough of your mind concentrates on the task at hand that there's not really room for a lot of other conscious thought, but it doesn't take ALL of your mind, so the unused part can run off and play.
climber has-been
Quoted: 3603 Post(s)
Liked 3,787 Times
Triceps are muscles that scream out (literally) for strength training, so you can hold that horizontal forearm position without fatigue.
I do skull crusher dumbbell lifts, lying on the ground. They really help.
(not Terry)
(not Terry)
Likes For terrymorse:
Liked 3,662 Times
I also lack acromio-clavicular ligaments in my right shoulder but I did pushups for a while after I recovered from the injury ... then I stopped and now it is hard to get re-started.
Those skull-crushers look safe .... if I overdo it I can not only pull a muscle but actually crush my skull. Might help.
Likes For Maelochs:
I tried to take a picture of this the other day, but as you can imagine it's a little difficult to do while riding
I'm sure a lot will depend on what kind of hoods you have.
Liked 5,284 Times
