Mystery track frame #3
Everyone here has been super helpful. Here is the 3rd and last mystery track frame I have. Pics are attached, it’s a repaint and the lugs are fancy but other than that I have no idea.
Bikes: Indeed!
Quoted: 1522 Post(s)
Liked 3,541 Times
Wow! Nice frame. A.S. Gillott looks like a strong contender to me.
Brent
Brent
"I have a tendency to meander sometimes." B.G.
Bikes: Indeed!
Liked 3,541 Times
Likes For obrentharris:
It's the little things
Bikes: Too many, yet not enough
Quoted: 281 Post(s)
Liked 327 Times
Changed my mind.
Claud Butler or Holdsworth maybe?
Edit: I'm a dummy 😂
Edit: I'm a dummy 😂
Bikes: Indeed!
Liked 3,541 Times
Quoted: 3882 Post(s)
Liked 3,494 Times
have little to assist
am weak on British in general and when it gets back onto the fifties & before am pretty much in the dark
have seen these frame ends previously but am unable to recall the producer; they may be from one of the cycle makers who had their own designs such as Percy Stallard or Claud Butler; or they could just be from Cyclo for example...
seat stay plugs are sure to be from someone such as Brampton or Haden
possible lug pattern one produced by a well-known Brit name but a proprietary design done for a specific maker...
Disraeli Gears
It's humorous to me why obrentharris would think of me as an authority in anything like the same league as unworthy1 or juvela. My untutored impression is that Gillott or Hetchins would be likely suspects. As a sometime "bike voyeur" or ogler, I'd have to say that very few constructors are in the same category of "fancy" where lugwork is concerned. I'd be looking not so much at the lugs themselves, as to a) the seat stay terminals, and b) the spacing/arrangement of the head badge holes, as salient clues. Plus, there's the bonus of a serial number. The presence of an oil/grease port hole in the bottom bracket points to an earlier date than the '70s, certainly. Both Gillott and Hetchins used metal head badges, both were secured to two holes disposed vertically. Gillott's (just a WAG based on looking at examples) may have been farther apart than Hetchins. Plus, I found this example on classiclightweights.co.uk that has both a metal head badge and seat stay caps that appear to be similar (or even identical) to those on the track frame:
It's even got a curved brake bridge too. Gotta say, if the track frame turns out to be a Gillott, it's a finer example than the '55 one on classiclightweights (and maybe earlier), which only has garden variety Nervex Pro lugs. Take off that ugly repaint, and it's a treasure.
Stop reading my posts!
Quoted: 1473 Post(s)
Liked 1,112 Times
flattering that Brent thought I have expertise in this field, but I do not, sorry.
What I will offer (as WAGs) are a few observations: I don't see examples in any of these marques that exactly match the example's lugwork:
Holdsworth (or Hurlow) tho there are tempting similarities I don't see a match in any of the "Wind models" or Bill Hurlow's vast hand-cut lug library
Gillott (sorry but no match seen there either)
Claud Butler
Freddie Grubb
Bates (either Horace or E.B.)
and just about everything else in the "Classic British" gallery of Classic Rendezvous.
So in short I gots nuthin.
The track ends with threaded eyelets may indicate this was a "road-path" model, or maybe not. I've seen a similar profile to the stamping of these ends but can't recall what brand(s) used them, nor come up with a photo.
Likewise agree that the staycaps were used by several marques, if I could find them all it MIGHT narrow the field but I think the lugs and BB shell are far better clues (for somebody who recognizes them).
Serial number means nothing to me but "C 7711" is bound to help some better sleuth...I would suggest OP try sending pix to the Classic Lightweights UK folks, if anyone there would play along. Or perhaps a link to the "CR List"
Or cast a bigger net here in C&V and copy this into a general thread (not in the "what's it worth? evaluation" subforum.
Good luck!
Claud Butler
Freddie Grubb
Good luck!
Quoted: 586 Post(s)
Liked 612 Times
As was stated, it might have been set up for both track and path racing. Here's a track frame on the bay which has similar fork ends in the rear. But they don't exhibit those little extra nubs. Did those have a purpose?
https://www.ebay.com/itm/38527053917...xoCeEAQAvD_BwE
Bikes: None in ridable condition
Quoted: 149 Post(s)
Liked 646 Times
Kevin537 - did the frame come with a fork? If not, it's a shame as those were pretty nice looking.
unworthy1 and Senrab62 are on the right track here (no pun intended).
This looks like one of those rare, one or two year Holdsworth Zephyrs (1958/1959). The seat stay caps on the mystery frame were introduced on the Zephyr model in 1957 (and were called "fluted wrap-over top eyes" in the catalog). Also, the ends are only identified as "...long 2" path ends" in the catalogs. In 1958 the lugs were changed to the ones on this frame (with lots of "fishtails"). By 1961, Cyclone and Zephyr had the same lugs (no windows/cutouts in the lugs), after which the Zephyr model goes away (I think it may have been revived relatively recently).
I don't have a late 50s Holdsworth to measure, but I've seen some owners on online forums mentioning 57mm as the distance between head badge rivets. There were different designs of badges though, so I'm not exactly sure which one was 57mm.
The only thing that's confusing me is the serial number that doesn't conform to normal Holdsworth numbering scheme. There were some 'shop special' frames that had a letter prefix, so that's most likely what this is. Apparently, it was not uncommon to have top tier (which the Zephyr was) frames customized, which is probably why the few of these late Zephyrs that you'll run into tend to show small differences.
Bikes: Indeed!
Liked 3,541 Times
Maurice Moss pulls a rabbit out of a hat again!
Brent
Brent
Liked 3,494 Times
Thank you so much DCI Moss!
Verily, the man must have siddhic powers.
Likes For juvela:
Likes For Senrab62:
Quoted: 805 Post(s)
Liked 1,851 Times
Likes For zukahn1:
