Building a bike around Suntour AG?
Quoted: 755 Post(s)
Liked 741 Times
This is a previously pondered hypothetical question dredged up by USAzorro's proposed "class 4"
https://www.bikeforums.net/classic-v...hallenges.html
So I've got the full AG drive train but no particular bike to put it on.
I read a review by Frank Berto about climbing hills on a I think a Schwinn Varsity?
For actually going up hills, a slightly lighter frame might be a good idea.
Would a Schwinn Voyageur 11.8 be a good match?
Its the right vintage.
How about wheels though?
What go's up, must come down.
Smaller rims and bigger tires?
Less stellar braking?
Shorter cranks? (I am partial to the 170 Sugino Maxy's)
Decide I need a Varsity?
Likes For bark_eater:
Do you have the version of the FD where the inner cage plate swings up and down relative to the front plate as it moves?
I have the AG tech RD and the FD I just described, and they work okay. I bought them as a NOS set, but I'm pretty sure they were OEM on my ~1983 Ross MTB. I'm using a humble Shimano freewheel, and not the 40 tooth Suntour it was designed for...
Extraordinary Magnitude
Quoted: 2612 Post(s)
Liked 1,732 Times
I wish you luck building a bike around the AG, looking forward to see what you come up with!!! The only AG piece I have is the FD on my Stumpjumper- and there's just so much steel on it. I suppose that means it's that much more indestructible, but a Mountech FD would weigh like half of that.
There's that whole early 80s period- for derailleurs I just like to skip ahead to 1984/85.
Commence to jigglin’ huh?!?!
Cantilever believer
Quoted: 567 Post(s)
Liked 1,961 Times
Looking at the dismantled Schwinn Sidewinder on my back porch, that may have been the bike Berto may have been describing (the Sidewinder, also being a Chicago-forged diamond frame, bears quite a resemblance to be a Varsity).
For many years, I ran AG gearing, either with an AG, triple pulley, or other similar rear derailleur. The 14-38 rear freewheel makes for a good half-step setup, although I'm not sure the AG front is half-step friendly.
I'm hoping to reassemble the AG-equipped Sidewinder so I can sell it at the Tucson swap next month - if not, I'll just bring all the parts and label it "classic bike - some assembly required".
Cantilever believer
Quoted: 567 Post(s)
Liked 1,961 Times
One thing I didn't mention: back in the days of Suntour sprocket boards, I built up several 14-17-21-26-32-38 six-speed Perfect freewheels. I still have a couple of them. I also have the 14-38 five-speed from the Sidewinder, but that stays with that pile o' parts, er, bicycle.
ambulatory senior
Quoted: 1957 Post(s)
Liked 3,676 Times
I built up an 11.8 for a friend and I have to say it was actually a pretty solid climber.
Quoted: 755 Post(s)
Liked 741 Times
Curtesy of SPEEDOFLIGHT, here's the Frank Berto review:
https://www.bikeforums.net/classic-v...ar-system.html
It's definitely a low priority, down the que project idea, but I'm thinking a more modern 700c hybrid wheel set could get cut down and re-dished from 7 speed to 5 speed.
I'd also check the brake reach needed to see if long reach brakes are "too long" for 700c, because I'm pretty sure Tektro 559's would let me swap in a 650b wheelset relatively easily.
Cantilever believer
Quoted: 567 Post(s)
Liked 1,961 Times
I committed the grievous error of posting on the other thread. I'll go back and whack the zombie momentarily.
Here's what I posted there:
Sincere thanks for posting this.
So it really was a Varsity and not a Sidewinder. I'd stand corrected, but I just got comfortable.
It's interesting how much we put up with in pre-Hyperglide days in terms of just accepting late/overshifts in order to get a wide gear range.
One of the highlights of visiting Interbike in the mid-2000s was an annual dinner (usually at the Sahara Buffet) with Berto and several other long-time cycling scribes. It was great meeting the God of Gearing in person and conversing over a full meal. And buying autographed copies of "The Dancing Chain" direct from the author.
I still have an Ampec Belt Beacon in the Box O' Bike Lights. Just needs a 9 volt battery to start blinking once more.
I did run that "spring plowing" 24-38 ratio on my Rans recumbent for a number of years, as it was nice to have a super-bailout gear to make up for not being able to stand up on steep 10+% climbs.
And now my two 14-38 6 speed freewheels in storage are wondering when they'll see some mileage again.
Cantilever believer
Quoted: 567 Post(s)
Liked 1,961 Times
I'm surrounded by Chicago-forged frames each week at the co-op, so while I do appreciate the offer, I'll have to pass. Plus the shipping costs for such massive chunks of metal could be expensive...
Likes For RCMoeur:
Quoted: 823 Post(s)
Liked 1,051 Times
The Chicago built Sidewinder should sell for something around $200 or more depending on the condition. I don't understand the following that it has, maybe because it is somewhat rare, but it has a following.
