How to dismantle FH-M730-NT?
Old 03-22-23, 01:21 AM
Munny
Bikes: 50 ? More?
Quoted: 55 Post(s)
Liked 15 Times in 13 Posts
Hi,
Recently, I've found new wheels monted with Deore XT hubs, the M730 of 1986.
Yes but ... NT = Nut Type.
These allow for either 126 mm or 130 mm between the rear dropouts.
I'd like to replace the axle by the Quick Release one. I have all part NOS.
Has anyone encountered and dismantled these Nut Types hubs?
If so, how to proceed?
I tried without success.
This to complete the built of another classic MTB.
Thanks for any tips
Munny is offline
Old 03-22-23, 03:24 AM
Bianchigirll
Bianchi Goddess
Bianchigirll's Avatar
Quoted: 2958 Post(s)
Liked 3,031 Times in 1,543 Posts
Sugar "Kane" Kowalczyk
Bianchigirll is offline
Old 03-22-23, 05:13 AM
Hondo6
Bikes: Yes
Quoted: 559 Post(s)
Liked 703 Times in 473 Posts
Originally Posted by Bianchigirll
I wasn’t aware the Deore XT came in a nutted version.
are these freehub type hubs for a cassette or the older freewheel type?
According to Velobase in ‘86 Deore got the 6 Uniglide cassette but there is no mention of nutted axles.
https://velobase.com/ViewComponent.a...4bcd6&Enum=110
Velobase's listings for components are generally good, but I've found that they are sometimes incomplete and don't always list all variants of a particular component. That seems to be the case here.
Shimano documentation (EVs) for the FH-M730 indicate it was produced in versions having a 6-speed Uniglide freehub. Contrary to Velobase's listing, Shimano EVs also show it was produced with both nutted and QR axles.
https://si.shimano.com/en/manual/sea..._model=FH-M730
Shimano documentation lists two different EVs; both show both QR and nutted axle versions. I haven't had a chance to look at both EVs in detail, but sometimes multiple EV versions appear to occur due to part number changes during production, color variants, or other such reasons. In this case, certain part numbers and colors appear to have changed between the EVs.
Hondo6 is offline
Old 03-22-23, 07:22 AM
Charles Wahl
Disraeli Gears
Charles Wahl's Avatar
Quoted: 504 Post(s)
Liked 369 Times in 214 Posts
Pictures of what you're dealing with are necessary. My guess is, at the least, you'll have to replace a solid axle with a hollow one. And guessing further, why would the cones or their threading be any different for solid or hollow axles?
Here is a technical document, if it helps:
I can't seem to find these on Shimano's tech website anymore, for whatever reason -- only have it because I have some M730 hubs, I guess.
Charles Wahl is offline
Likes For Charles Wahl:
Old 03-22-23, 01:24 PM
Hondo6
Bikes: Yes
Quoted: 559 Post(s)
The EVs for those hubs are still available on Shimano's website. See the link I posted in my comment above.
Hondo6 is offline
Old 03-22-23, 01:33 PM
bulgie
blahblahblah chrome moly
bulgie's Avatar
Quoted: 1212 Post(s)
Liked 2,684 Times in 1,121 Posts
I'll be gobsmacked if you can't just
  1. remove original axle
  2. install hollow QR axle
  3. adjust and tighten normally.
How far did you get and what stopped you?
The basic procedure is to remove the left side locknut and cone, which allows the axle to be slid out to the right. Then you can take the right side cone and locknut off.
Some Shimano freehubs had the wrench flats on the right cone hidden under the rubber seal, so you may have to push the seal out of the way to access them.
(That's a D-A cone so yours is different and this pic may not help)
Reassembly is the opposite of disassembly, just remember right and left cones are different.
Apologies if I've misunderstood the question.
Mark B
bulgie is offline
Old 03-22-23, 01:50 PM
bulgie
bulgie's Avatar
Historically, most solid axle hubs had smaller diameter axles than QR hubs, and the cones were not interchangeable. Before maybe around 1980, I never saw a solid axle in 10 mm except for on top quality track hubs such as Campy (with their 26 tpi thread). Never saw any in M10 x 1mm back then myself; anyone else know of any?
But by the time this hub was made, solid axles in M10 x 1mm were indeed a thing, made by a few manu's besides Shimano too, such as Suntour and Specialized. What changed in between was MTBs. They (1st Stumpjumper for example) originally came with solid axles, on the mistaken belief that those are stronger. (I obviously don't believe they are.) Certainly with a freehub, hollow axles are strong enough, and the OEMs quickly figured that out and stopped putting nutted hubs on MTBs. So nutted MTBs were a "thing" for only a couple years in the early to mid- '80s
Mark B
bulgie is offline
Old 03-22-23, 01:58 PM
clubman
Phyllo-buster
clubman's Avatar
Quoted: 2300 Post(s)
Liked 2,062 Times in 1,259 Posts
Fitchel & Sachs made a 10mm axle in the 60's and 70's but the threading is non-standard.
clubman is offline
Old 03-22-23, 02:39 PM
Hondo6
Bikes: Yes
Quoted: 559 Post(s)
Indeed. The Shimano EVs for the hub show both QR and solid-axle versions of these hubs taking the same cones, which are M10 threaded (presumably M10 x 1mm). So a new axle will be most of the conversion hardware needed.
I say "most" because the solid-axle version used very different locknuts (see the EV for details) than the QR version, which also had a NDS spacer. Dunno for sure how well the solid-axle locknuts would work with QR dropouts, but they appear different enough on the EVs that I'd guess they might not "play nice".
Hondo6 is offline
Old 03-22-23, 02:45 PM
Munny
Bikes: 50 ? More?
Quoted: 55 Post(s)
Shimano came with a surprising variety of cones but this is not an issue.
I'm a bag of M730 hollow axles and another one with the cones.
The part #12 (sleeve lock nut & spacer) has 2 positions to allow for the 2 lenghts.
I can't remove it.
Is there a trick?
And the Uniglide can take 7 speeds
Munny is offline
Old 03-22-23, 02:59 PM
Munny
Bikes: 50 ? More?
Quoted: 55 Post(s)
I've a bag of M730 hollow axles and another one with the cones.
I can't remove it.
Is there a trick?
Munny is offline
Old 03-22-23, 03:29 PM
Hondo6
Bikes: Yes
Quoted: 559 Post(s)
I can't remove it.
Is there a trick?
Unfortunately, I have no ideas on that. I've never dealt with a FH-M730 nutted, so I don't know any special tricks for its rather unusual locknuts.
If I recall correctly, yes - Shimano 6-speed Uniglide and 7-speed Uniglide used the same length freehub and will take either a 6- or 7-speed Uniglide cassette.
But also if I recall correctly, Shimano 7-speed hadn't yet been released for Deore when this hub was first produced by Shimano (I believe that happened the next year). That's IMO probably why the EVs refer to it as a 6-speed hub.
Hondo6 is offline
Old 03-22-23, 03:54 PM
bulgie
bulgie's Avatar
I can't remove it.
Is there a trick?
You won't need to change any cones (unless pitted), spacers or locknuts — the originals will work with the new axle. Logically, the cones and locknuts can't tell whether the axle is solid or hollow, makes no difference to them.
As to removing part #12, any chance of a close-up pic? I've worked on those hubs and I don't remember any difficulty, but it was a long time ago and my memory is unreliable.
Mark B
bulgie is offline
Old 03-22-23, 05:03 PM
Charles Wahl
Disraeli Gears
Quoted: 504 Post(s)
As I said before, and as @bulgie just said: photo(s) needed to figure out what you're having trouble with. As @bulgie said, the standard way to remove an axle on a rear hub is to loosen & remove the cone & locknut on the left (non-drive) side, which are accessible (drive side are not, sufficiently). Reverse order is how the bearings are adjusted: fully tighten cone and locknut on the right side, reassemble freehub to the hub, install bearings on right, grease, and feed axle through, install bearings on left, install cone, adjust with locknut. Fiddle with QR (tightening, loosening) and the left side cone-locknut adjustment as needed to get the right free-turning/bearing preload/whatever that floats your boat.
If there's a trick, I have no idea what it might be. I have some M730 hubs, but they've always been QR type -- no Shimano engineering wackiness on those.
Old 03-23-23, 06:29 AM
Munny
Bikes: 50 ? More?
Quoted: 55 Post(s)
..., the standard way to remove an axle on a rear hub is to loosen & remove the cone & locknut on the left (non-drive) side, which are accessible (drive side are not, sufficiently). ...
Thanks Charles.
I should have said that I must have done this with hundreds of hubs, Campagnolo, Shimano, FB, Miche, Porthor, Suntour, Simplex, Sturmey, etc...
The self extending locknut doesn't let go and I was wondering if some pecularities were preventing me to do it as usually.
For uneducated public, these are best advices
Munny is offline
Old 03-23-23, 01:05 PM
eeuuugh
Bikes: Aerotek 4000, Trek 950, Huffy Nel Lusso
Quoted: 78 Post(s)
Liked 108 Times in 51 Posts
Shimano still makes nutted cassette hubs, the TX models. The axle is 10mm x 26tpi, which is what they use on their QR hubs too. I've bought these hubs just to get the axle and axle nuts, as a wheels mfg. 10mm x 26tpi solid axle is something like 30 dollars retail, and axle nuts in that threading are essentially impossible to find. Save the axle nuts from your old hub!!
eeuuugh is offline
Old 03-23-23, 01:47 PM
bulgie
bulgie's Avatar
I'm 98% sure that's not true, Shimano axles are M10 x 1, a standard fine metric thread. 10 mm with 26 tpi (threads per inch) is obviously not a normal metric thread, it's a weird hybrid, that for some reason became the standard in Italy. And as far as I know, only Italy. Yes I know Raleigh used 26 tpi, but not on a metric diameter. it's the weird inch/metric hybrid that's Italy only.
Nowadays 26 tpi pretty much only means Campy. Luckily 26 tpi is close enough to 1 mm that your thinner parts like locknuts are interchangeable (class B fit). I find cones to be too thick though, they start to thread on, but then the accumulated error becomes too much and they bind up.
Campy dropouts also have 26 tpi threads where the derailer screws in, so technically a Japanese mech is a class B fit on any frame with Campy dropouts. In practice though, the soft steel of the dropout just sorta flows as necessary to fit the 1 mm thread. Just don't go back and forth between 1 mm and 26 tpi; after a few back-and-forths, you might strip the threads.
Am I fulla beans? Can we get some confirmation, anyone else ever find 26 tpi on a Japanese part?
Mark B
bulgie is offline
Old 03-23-23, 02:05 PM
bulgie
bulgie's Avatar
I'd try heating the nut that won't budge, like with a heat gun or small propane torch. Heat till the oil smokes, not until glowing!
I find heat to be almost like magic for freeing stuck parts. Even a blow-drier can help, better than nothing.
An axle vise (like in my pic in post #6) is also recommended, for gripping the axle tightly enough to really reef on, without hurting the threads. Soft jaws in your vise (copper, plastic, aluminum) are not as perfect as a dedicated axle vise, but good enough if used judiciously.
Mark B
bulgie is offline
Old 03-23-23, 06:23 PM
eeuuugh
Quoted: 78 Post(s)
I agree that 10mm x 26tpi is truly weird and shouldn't exist. It was very frustrating when I was trying to find a solid axle for a parallax-era Shimano cassette hub, couldn't use an M10x1 axle, checked the cones on a gauge, and found that it was 10mm x 26tpi. I bought the nutted TX500 and was able to use its axle with the parallax hub's hardware, then rebuilt the TX500 with the QR axle from the parallax hub. This was three years ago, I mostly work on older bikes and don't know what Shimano's doing now, if they switched to standard metric axles then I'm glad!
eeuuugh is offline
Old 03-23-23, 08:23 PM
Charles Wahl
Disraeli Gears
Quoted: 504 Post(s)
Thanks Charles.
I apologize for underestimating your facility with hubs. Still, you haven't provided any photo that shows what you're having a problem with, and the Shimano tech article I posted is insufficiently clear to illustrate anything meaningful about the nutted vs QR configuration. So I (certainly) am at a loss as to how we might help.
Old 03-23-23, 11:33 PM
bulgie
bulgie's Avatar
No switch, they've always been 10x1, as long as I've known them, which is back to the early '70s. I remember they were incompatible with Campy, which was very annoying sometimes when I wanted to do some "hack" that required a Frankestein monster.
I too have no idea what they've been doing for the last 25 or so years. 8-speed is as far as I got with "current" Shimano, and that's only on the tandem, most of my bikes are 5- 6- or 7-speed.
I'm not saying you didn't find one that was 26 tpi, but I'd be more likely to believe that a previous owner had swapped in a Campy, than believe Shimano ever made a 26 tpi cone.
bulgie is offline
Old 03-27-23, 11:41 AM
Munny
Bikes: 50 ? More?
Quoted: 55 Post(s)
Here comes the pictures...
For the story, the wheelset is intended for Bugs Bunny.
Marin Suntour by bagheerabe, on Flickr
A Marin that I'm rebuilding mostly in Suntour XC Pro ... except when I don't find the parts New...
and since Suntour Cassette are an extinct specie, I spared on finding cheap Nos Grease Guard hubs!
Here on a wheelset with XTR M900 hubs that will go on another project.
So here the FH-M730-NT hub
Deore XT M730 NT by bagheerabe, on Flickr
FH, surely like Rear Hub and NT , Nut Type.
Deore XT M730 NT by bagheerabe, on Flickr with a little bit of shop dust...
These "sleeve lock nut and spacer" can be set to a 126 mm wheel width like here
OR...
Can be extended to a 130 mm wheel width ...
HOW?
(and now you will understand that I succeeded to dismantle it)
With concentric ... sleeve.
You can see that the internal part has an exagonal shape
And ...
The outer part has a matching exagonal shape that can be locked (sort of) in extended position.
So now gone to the parts bin.
Welcome the QR axle-cone
Thanks for the help.
Munny is offline
Likes For Munny:
Old 03-27-23, 08:05 PM
Charles Wahl
Disraeli Gears
Quoted: 504 Post(s)
Congratulations! Like many Shimano "improvements", an invention in search of a necessity. I still don't understand how it locks in the 130 mm position, so as to be secure enough; but maybe I don't need to know. And, thank you for the photos.
Old 03-28-23, 01:24 AM
bulgie
bulgie's Avatar
Here comes the pictures....
Excellent, thanks for documenting that super weird part. Mind = blown.
Like ​​​​​Charles Wahl , I'm mystified how it works, but it's such an obscure niche, I don't need to know. Chalk it up to one o' those unsolved mysteries.
Mark B
bulgie is offline
Old 03-28-23, 01:45 AM
Munny
Bikes: 50 ? More?
Quoted: 55 Post(s)
Well, I considered to leave the nutted axle and came to the conclusion that I was not trusting it to be secured.
You lenghtened it by pulling and twisting of a few degrees at the extended lenght.
The outer sleeve has 2 flats to allow it to be hold while tightening the external nut but such a little twisting movement is enough to unlock it.
Mmm... no!
Munny is offline
Likes For Munny:
