Improved cable "management"?
Bikes: Drysdale/Gitane/Zeus/Masi/Falcon/Palo Alto/Raleigh/Legnano
Quoted: 1037 Post(s)
Liked 717 Times
Are there alternatives to this item for having some control over non-aero brake cables betwixt the brake levers and the front brake and/or top tube?
I've used these but they only hold the cables at a fixed distance aprt which is OK but they do tend to slide down the housing a bit. And the finish is rather plain plastic although I see there are a few color options. Looking around the internet (and it's challenging to find the correct search words to get the wired results) I see this at Amazon but, wow, it's shiny, and unsure what diameter cable housings it fits: CHROME
Larry:1958 Drysdale, 1961 Gitane Gran Sport, 1974 Zeus track, 1988 Masi Gran Corsa, 1974 Falcon, 1980 Palo Alto, 1973 Raleigh Gran Sport, 1974 Legnano. Susan: 1976 Windsor Profesional.
Quoted: 4893 Post(s)
Liked 4,062 Times
I'm a little confused. My question is why? I've been riding a long time and never used ties between my brake cables. Seems to me the tie would pull the rear brake cable housing inboard to create still more of the inevitable rub on the headtube.
Likes For 79pmooney:
aka: Dr. Cannondale
Quoted: 2175 Post(s)
Liked 3,531 Times
I use those plastic doodads, but a short piece of leather thong works as well. I keep around old bits of leather bar tape to slice up.
Quoted: 1165 Post(s)
Liked 1,846 Times
The French have everything. TA Specialties had just what you are looking for. Here are cable connection clamps that should have a hooked spring that goes between the clamps. Mine was stretched and probably thrown out.
Likes For Mr. 66:
Bikes: 1964 Huffy Sportsman, 1972 Fuji Newest, 1973 Schwinn Super Sport (3), 1982 Trek 412, 1983 Trek 700, 1989 Miyata 1000LT, 1991 Bianchi Boardwalk, plus others
Quoted: 589 Post(s)
Liked 706 Times
If you are one to use string or twine to finish the ends of cotton bar tape, that string looping the cables looks good on the same build.
Polymultiplié
Bikes: Yes, please.
Quoted: 2223 Post(s)
Liked 4,840 Times
I like these. Also by Spécialités T.A.:
Likes For non-fixie:
Ride, Wrench, Swap, Race
Quoted: 1573 Post(s)
Liked 1,315 Times
I usually run the cables without any "auxiliary" management if you will. The cables run gracefully as God intended, with the rear cable crossing and passing behind the front brake cable (just above the stem extension).
There are exceptions however, such as with centerpull brakes or the "backward" early Dia-Compe and Shimano (non-Dura-Ace) sidepull calipers.
On these setups, the cables do not usually cross (except in rare cases where the front brake cable perhaps passes to the right of the stem extension).
With stem shifters, I may tuck the rear brake cable behind the right shifter cable, against the upper headset, in those cases when it is routed along the right side of the top tube (Peugeot, Raleigh and Schwinn often did this).
I've even used a tiny loop of bead chain on a couple of builds.
Often some cable management trick is used to keep a cable housing from clinking noisily against the handlebar or even against the other brake cable!
Likes For Vintage_Cyclist:
A short section of pipe cleaner. Available in any color you want. Free if you know a toddler or pipe smoker.
Quoted: 1983 Post(s)
Liked 2,099 Times
The itty bitty cable ties do it for me. I like to run the cables short and. They are not going to meet up in any parallel fashion like the looping cables on my UO-8 in 1974 where I did use a cable clip.
Quoted: 4560 Post(s)
Liked 2,805 Times
Y'all are fancy. I use zip ties (always carry spares in the tire fixings saddle bag), small Velcro straps or sometimes twist ties to route cables to suit myself.
Of the three, zip ties are probably the least ugly. Change them every couple of years, depending on exposure to sun and UV, as the plastic ties get brittle after awhile.
Quoted: 1119 Post(s)
Liked 1,352 Times
I find that if the outers are cut to the correct length those bits are unnecessary; they don't move when the brakes are applied, only when the bars are turned; and the inners run the smoothest.
If the outers are NOT the correct length they will flop about when the brakes are applied and the friction between the inner and outer is higher.
Liked 717 Times
So it looks like there are various ways to address the problem -- if indeed it is a problem (I suspect I tend to leave my cable loops a bit long).
Thanks - I see one on eBay. $49.50********** Wow. Velobase says that's a copy of a TA item #34, which I did NOT find.
... and there it is. And you know that looks like a little square of aluminum that could be wrapped around a dowel, one might be able to replicate if desired (except the logo)
Sounds like an option, or at least for those with knot-tying skills (thus I do not finish off bar tape with twine).
Now THOSE I seem to recall from BITD. Presuming you can find one, and presuming your stem has an exposed and not recessed quill bolt.
Cool, and I see plenty of color choices, even Celeste. Now to decide if I match the paint color, or the color of contrasting cables and accessories. And one place in UK has them for a few dollars, but $30.99 in shipping?
Likes For tiger1964:
Twine
I find Twine works pretty well, I ‘sealed’ this one with beeswax lip balm, I have another I shellacked .
Likes For Nwvlvtnr:
The Wheezing Geezer
Bikes: 1976 Fredo Speciale, Rivendell Clem Smith Jr., Libertas mixte
Quoted: 429 Post(s)
Liked 1,020 Times
Let 'em flap in the breeze! It actually increases speed - it's a resonance thing, like tuning a muffler.
Plus, it makes highly critical modern riders slightly nauseous, so there's that advantage.
Quoted: 1092 Post(s)
Liked 709 Times
Doesn't that reduce mobility? I always make my cables as short as possible, while still being able to pass the "wheel flop" test to both sides. Tying any of the cables together would seem to reduce their ability to move freely as the handlebars are turned.
Polymultiplié
Bikes: Yes, please.
Liked 4,840 Times
These came from Belgium. A 200 mile round trip. But look a the price tags. I don't think I spent more than $40 on the lot. And I had a nice day.
Old fart
Quoted: 3617 Post(s)
Liked 3,454 Times
A little bit of brass rod or solid wire works for me:
Likes For JohnDThompson:
Liked 717 Times
So far, the best option I see. Looks like it not only should hold them together -- but parallel.
Bikes: yes
Quoted: 512 Post(s)
Liked 420 Times
