Tallow, neetsfoot, Mink oils: need to bring some old leather back on-line.
Quoted: 1869 Post(s)
Liked 666 Times
Brooks made leather dressing based on tallow and cod oils, but now it’s mainly vegetable/plant based oils and waxes. Does the modern Proofide work as well as the old tallow stiff?
in the market today are products seeming to be based on neetsfoot oil (from Feibing’s and others) and mink oil (from Feibing’s and Andalus among others).
In addition we have fully vegetable products, such as Obenauf’s.
What are modern Bobs choosing and preferring for leather saddle conditioning, to prepare for a summer of training, touring, and climbing, or to bring new live into valued classics? I currently like B17, Professional and Swallow Selects, and vintage Ideale 80, 90, and 92.
The 17, Swallow, and the 90 are responding well to older tallow-based Proofide, but I’m running out of it, and need to choose a substitute. I suspect that the animal products are all pretty similar.
But, what have the other Bobs found?
Old fart
Quoted: 3616 Post(s)
Liked 3,446 Times
I haven't had any problems with the new-production Proofide, but it is expensive. I've also had good luck with SnoSeal, which is just beeswax in a volatile carrier. The carrier allows the beeswax to penetrate deeper into the leather, then evaporates and leaves the beeswax behind.
Likes For JohnDThompson:
Quoted: 4854 Post(s)
Liked 3,992 Times
I've switched to Obenauf's Heavy Duty LP at the advice of the excellent local cobbler. I believe it is also beeswax based and it behaves similarly. (The lettering on the tub is worn off so I cannot read it.) Both are good stuff. If I could not find the new stuff, I'd go back to SnoSeal in a flash. I stay far from neatsfoot and mink oil on any leather I want to keep its shape.
Likes For 79pmooney:
Quoted: 97 Post(s)
Liked 294 Times
I like Tanner's Preserve- Automotive leather seat cleaner and conditioner
all my leathers get it from car seats to razor strops to motorcycle leathers
For horse and bicycle saddles, neatsfoot oil (I used to buy it by the gallon) and glycerine saddle soap, the kind in honey-colored bars, not the stuff Kiwi sells in tins, are the way to go. Since leather is not a vegetable product, I don’t fret over using animal products to treat it. Leather isn’t a sophisticated substance, and it doesn’t take sophisticated products to maintain it.
Bikes: 1974 Masi GC, 1982 Trek 728 (aka 720), 1992 Trek Multitrack 750
Quoted: 123 Post(s)
Liked 225 Times
Again, IMHO, concerning the other products, too little is better than too much.
Unfortunately I've had to learn these things the hard way, don't be like me.
Likes For HelpSingularity:
Been Around Awhile
Bikes: Vaterland and Ragazzi
Quoted: 12 Post(s)
Liked 1,552 Times
Quoted: 1090 Post(s)
Liked 707 Times
I just use Kiwi saddle soap on my leather saddles, as well as my leather shoes and boots. It's been working fine for years, and by years I mean decades. I own four leather saddles and they're all pretty old.
Liked 666 Times
Quoted: 430 Post(s)
Liked 712 Times
Seems some of the products that used to be good are not so great these days. I was going to recommend Lexol, which we used to recondition a very dry western leather horse saddle decades ago. But when we used it, it was made in USA, but now made in China. Also, from reading reviews, seems that it also now stinks and doesn't work like it used to. So, whatever product you consider, you might want to read some current reviews. Hoping if I need to use it, that my old container of Lexol is still useable.
Liked 666 Times
Old fart
Liked 3,446 Times
Connolly Hide Care was the best conditioner I used for my leather seats to bring back suppleness. Lanolin base cream. Then you need to protect it. Good luck
Liked 666 Times
I'm not really interested in beeswax, rather I want the tallow.
Veteran, Pacifist
Quoted: 3919 Post(s)
Liked 4,886 Times
I use Saddle Butter from Holes Leather Care Products. Butte, Montana. Since 1936.
From the description:
Beeswax, Brazilian carnuba wax, tallows, pure neatsfoot oil. No modern synthetics, mineral oils, or other leather treating chemicals.
Saddle Butter® – Ray Holes Leather Care Products, Inc.
$20 for a 14oz jar = lifetime supply.
edit: What's a Bob? English police used to be 'bobbies'.
Quoted: 913 Post(s)
Liked 515 Times
Endorsed by rodents
I was deathly ill in the hospital for a couple of months last summer and upon returning home I discovered a jar I left open on the work bench of home brew goose fat and beeswax that was completely eaten and licked clean by the neighborhood voles.
Use whatever suites you but just don't leave it out
And Bob's yer uncle!
Likes For FBOATSB:
Quoted: 1441 Post(s)
Liked 1,998 Times
recently been using Pecard leather dressing
also Wilson Pro Stock glove conditioner
for decades used Lexol - but it does not appear to work as well as it did at one time ... ?
Old fart
Liked 3,446 Times
I'd be careful with the glove conditioner. Those products are usually formulated to soften leather by breaking down the fibers in the leather. That's fine for a glove, but problematic for a leather saddle that needs to support your body weight.
Bikes: 1996 Trek 970 ZX Single Track 2x11
Quoted: 624 Post(s)
Liked 578 Times
On car leather (seats) and other similar leathers that aren't at grave risk of softening and stretching, I've had good results with Fiebing's Saddle Soap and Fiebing's Neatsfoot Oil. Can't say how it'd work, long term, on a leather bike saddle.
Liked 666 Times
Liked 1,998 Times
glove needs to be able to receive a hard hit baseball often coming off a bat in excess of 100 mph (so it cannot be too broken down)
where some get into trouble is when they use some oil based products (and similar) to speed up the process ... with neatsfoot oil and similar products the results can be disastrous and ruin the glove ... floppy and heavy
we typically start with light application of Lexol - and then proceed cautiously and slowly from that point with some other products ... it can take some time before a glove is put into game use - typically will break in a glove over time while another glove is being used
Neetsfoot oil damages stitching. Brooks saddles have no stitching, so it is not a concern, but beware of stitched items like boots, gloves, bags, wallets etc.
Neetsfoot oil should only be used in miniscule quantities and it is best to dilute it with a carrier like beeswax or microcrystalline wax.
Accessible Preservatives makes a product that is neetsfoot oil, beeswax, and microcrystalline wax in suitable proportions.
Microcrystalline wax (Rennaissance Wax brand) is easier to apply than beeswax or carnauba wax and I can't think of a reason it isn't at least just as good as either.
I use Rennaissance wax alone for maintenance.
Snoseal is beeswax and pinetar. So is Hubbard's Shoe Grease.
Pinetar's main benefit is that it adds waterproofing. It's valuable for boots (assuming they don't have Goretex liners which it will thwart), but I don't see the point on saddles.
I would use Neetsfoot oil carefully if I wanted to soften the leather or if the leather was badly dried out. The chances are if I was considering using it, I would probably prefer the result of replacing the item if that were possible.
Feibing's saddle soap is a great product for cleaning leather. Clean it with that and use Rennaissance wax. If it needs anything else, replace it.
Quoted: 123 Post(s)
Liked 225 Times
Bikes: 1980 Gitane sprint,1977 Motobécane C4, 1977 Carlton Clubman, 1959 Claud Butler European
Quoted: 75 Post(s)
Liked 128 Times
I am trying out using ballistol on an old brooks saddle. I have used ballistol for various things over the years, great stuff, eco and cruelty free as well.
https://ballistol.com/uses/leather-care/
Liked 666 Times
My number is based on a simple calculation, where a strip (a very simplified saddle top) is suspended between a pair of end supports, which are assumed to be rigid. I also assume the strip is loaded at its midpoint by the weight of a 200# rider. No prejudice, that's just what I weigh. I assume the shape is a loaded strip angled down about 5 degrees at each. At this angle it looks slightly like a bike saddle, and with a steeper angle it does not.
But I'm pretty sure bike saddles need to carry internal skin tension which is far more than the weight of the rider. This kind of loading is not true for a gun holster, baseball glove (or lacross glove for that matter), shoe, jacket, easy chair, or other common item of leather goods.
Why is this in my head now? We have been speaking of several different types of leather treatments, and several of us think that Neetsfoot oil might weaken leather under tension. If this is so, and we are also sharing anecdotes which follow this concern, then while Neetsfoot might be good for leather in normal, low-stress usage, it might not be a good treatment for bicycle saddle leather,which we want to continue to support hundreds of pounds as it did 30 years ago. Essentially, Neetsfoot oil is contraindicated as a treatment for bicycle saddles, if my model is correct and its implications match reality..
If anyone wants to talk about my calculation, send me your email and we can chat.
