What causes this?
What causes this?
This is from a donated bike so I don't know the history. 1 x 7 schwinn cruiser type bike with the symptom being a "juddery" feeling, present on all rear cogs but progressively worse as you approach the smallest cog. I took the chain guard off to find what is pictured. Chain shows little wear using the chain gauge. I took the chain off and it doesn't have any stiff links. I have checked the RD for alignment and it is OK, and the jockey wheels are running smoothly. I don't have another chain to try; what I think I am feeling is the chain vs. front gear as it leaves the gear. Is this chain shot even though it doesn't show it on the gauge. Thanks!
Quoted: 230 Post(s)
Liked 18 Times
What you've taken a photo of there is extreme chain wear. You'll also need to replace the freewheel, and honestly i'd take a good hard look at the chainring too.
Likes For Cute Boy Horse:
I am potato.
Quoted: 1838 Post(s)
Liked 1,713 Times
+1 on the extreme chain wear. But in the odd chance it is not...It could be a 1/8 (4/32) chainring being too wide for a 3/32 chain.
In either case, a new proper chain is in order.
Cheers.
Cheers.
Car dependency is a tax.
Likes For base2:
Bikes: !982 Trek 930R Custom, Diamondback ascent with SERIOUS updates, Fuji Team Pro CF and a '09 Comencal Meta 5.5
Quoted: 1313 Post(s)
Liked 763 Times
an extremely Low Quality Chain, Lousy chain lube(if any) and obvious Neglect.... with a chance of a bent tooth or chainring... but all that offset pictured leads me to think it's that chain... !
set a new chain around the chainring,,, pull it tight.... then try to pull it outwards from the mid point opposite the end... see if it lifts more than 1/2 a tooth height... if so, then the ring is shot.
Quoted: 531 Post(s)
Liked 477 Times
[QUOTE=base2;22864082But in the odd chance it is not...It could be a 1/8 (4/32) chainring being too wide for a 3/32 chain.
Cheers.
[/QUOTE]
Just worn. Observe how the links mesh with the cog at the bottom. If the chain were too narrow, it couldn't have been used long enough to cause elengation, unless, maybe, diabolically, it was worn out on a different bike and then transferred to this one.
Cheers.
[/QUOTE]
Likes For oldbobcat:
Quoted: 6365 Post(s)
Liked 4,962 Times
Chain ring is worn if you are sure the chain measures within spec. Perhaps the previous chain was used well beyond time to replace and that wore out the ring and probably some of the rear cogs too.
Quoted: 518 Post(s)
Liked 661 Times
Likes For KerryIrons:
Clearly a case of a severely worn chain or chain ring. You say the chain is OK by your chain checker. I suggest getting out a ruler and measuring the chain. It should be less than 1/8" elongated in 12" original length (1% elongation). The current spec is actually 0.5% elongation (1/16" in 12") but with these low quality setups, and 7 speed, 1/8" is OK. You have way more issue than that.
Quoted: 4239 Post(s)
Liked 3,975 Times
Likes For Andrew R Stewart:
Droid on a mission
Quoted: 320 Post(s)
Liked 286 Times
Look this video about the 2:50 mark and will see the tool bouncing off the closer rivet.
Sock Puppet
Bikes: 2014 Cannondale Synapse Carbon, 2017 Jamis Renegade Exploit and too many others to mention.
Quoted: 1031 Post(s)
Liked 863 Times
Bicycle: Measuring Chain Wear using a 12-Inch Ruler
The ruler does not lie!
Extremely worn chains may yield a false "good" because the checker is hitting the roller closer to the "hook" end. I always have a steel rule on hand in addition to the chain checker.
https://www.youtube.com/watch?v=gXd-3UnqoaM
Bikes: a couple
Quoted: 563 Post(s)
Liked 871 Times
That's an old schwinn, love that Ashtabula crank.
My bad, not a single speed! the front sprocket will be fine, the rear not so much.
Mad bike riding scientist
Quoted: 6286 Post(s)
Liked 4,329 Times
Stuart Black
Stuart Black
That checker isn’t showing a “false good” at all. The “bouncing” of the hook end is because the mechanic is moving the checker to illustrate that the chain is worn beyond 0.75%…well beyond at that. The chain checker in that video shows that the chain is obviously worn. The only way that measurement would show a “false good” is if the person doing the measurement didn’t know how the tool worked. No steel rule is needed to further check the results.
Likes For louky:
