(padded liner + loose fit shorts) or (liner + padded loose fit shorts) ?
I ride to public spaces like grocery stores and parks, so I do not want tight race bib.
I think I want to try padded shorts.
I want some sort of snug liner shorts
What are my options?
Padded shorts over liner shorts?
Regular shorts over padded liner shorts?
Compression shorts + loose shorts with padding ($15 + $35 = $50)
https://www.amazon.com/DRSKIN-Compre...dp/B088LYHZC5/
https://www.amazon.com/Mountain-Bicy...dp/B0BV6FWRPJ?
OR
Padded compression shorts $20 total (Can wear any shorts over this)
https://www.amazon.com/Baleaf-Padded...dp/B00MTE6OTQ/
EDIT:So, which is correct?
A. Chamois inner compression short + random pair of unpadded outer shorts
B. Blank inner compression short + padded outer shorts
C. Chamois inner compression short + padded outer shorts
Is C redundant, if chamois serves as padding also?
OR
What mileage range do pads come into play? Any downsides?
So, are you saying liner+regular shorts or Mtb shorts (with padding)
52psi
Quoted: 790 Post(s)
Liked 803 Times
Urban ride under 10 miles or so, just wear what you wear. Don't overthink it.
Likes For Fahrenheit531:
Clark W. Griswold
Quoted: 4498 Post(s)
Liked 4,184 Times
Probably none of those. If you are riding distance than a good pair of bib shorts (not cheap not some Jeff Bezos knockoff special but good quality comfortable ones) and then whatever you want over top. If you are riding short distances ride whatever you ride I usually just ride in my ExOfficio Give and Go Underwear which is nearly all I wear (I have a couple pairs of their Sol Cool undies as well but they have worn out quickly but ExOfficio Give and Go is the way to go. I have a pair that is now 10 years old or so and was retired recently because the elastic was wearing out finally but have many other pairs and will happily purchase more over and over and over again.
If you really need padded shorts then I would still go with bibs always but if needed be I would get a set of Club Ride shorts they at least used to make shorts for different ride times and for me I would want something thinner depending on the saddle.
If you are experiencing discomfort then I would see a fitter. They can help get your bike set up so you don't feel discomfort and if you aren't feeling any, it will enhance your riding experience anyway and make you feel even more comfortable. Ideally look for someone who does dynamic fitting like Retül and not a static fit as those just aren't that good.
Likes For veganbikes:
Less than an hour and I don't bother with any special clothing. For any serious riding its a good cycling short and then any kind of shorts or pants over the top.I like something baggy to not interfere with leg motion. That is just to hide the shorts and not look silly in certain situations.
Quoted: 6349 Post(s)
Liked 4,948 Times
I tend to think for a ride to the store and back, then you must not be going far. So wear what ever you want on the outside. Even if that is a tuxedo.
I'd recommend you ditch the cotton underwear though. Use some sports underpants made from synthetic fiber. You don't need a pad or chamois either. But you are a individual, so you can pretty much do whatever you want. You don't need to get our consensus. However if you have some issues because of what you do, then we'll have our own opinions of how to solve whatever that actual problem is. But how you dress really isn't a issue until you have a problem caused by how you dress.
If as another thinks, that this question is about expanding your distances, then still you can wear whatever you want. I used to do long rides with just synthetic fiber sports underwear and a pair of loose outer shorts that didn't have thick irritating seams. And no chamois either even for 100 mile rides. However eventually as I started doing more of those longer rides I realized the benefits of the more typical cycling shorts or bibs and other cycling clothes.
Quoted: 458 Post(s)
Liked 490 Times
Casual rides = no special clothing. But if you want to ride hard and still dress casually, I usually wear regular bike shorts (not bibs) and wear regular street shorts over them.
So, yes, how I dress is already an issue.
It sounds like you're suggesting compression shorts with no chamois or padding under loose outer shorts with no chamois or padding
That certainly is the simplest $15 solution.
Here are the options:
D. Blank inner compression short + random pair of unpadded outer shorts
Liked 4,948 Times
IMO, compression isn't needed for cycling clothes used for cycling at a high effort level. You just want them to be form fitting so there are no wads of fabric bunching up. And especially so the sweat wicking abilities of the fabric are utilized fully.
I see no need to compress one's muscles with overly tight clothing as that seems like it would limit blood flow, which is all about how muscles get O2 in and CO2 out. So at best they only need to compress maybe enough to add some support. Even I'm guilty of calling my bibs and shorts compression. But they aren't really that tight. Just enough to pull the wrinkles out.
Quoted: 2390 Post(s)
Liked 2,942 Times
what works varies widely for each person
for me anything over say 8 miles and I want bike shorts.. I really don't care if I go into store with them on.....and it is not showing off
I did 5 mile commutes with compression shorts and loose outer shorts for years, but any more I just wear bike shorts as 1) I make the return ride 10 pluse miles and 2) nearly killed my self catching loose shorts on saddle.... couple of by
Life is too short not to ride the best bike you have, as much as you can.
It's certainly a viable option available to you. Though for me I wouldn't go strictly for compression shorts. I'd just use some close fitting underwear that is made from synthetic fibers. Usually they market that as for sports activities.
I used the term "compression shorts" as a generic catch-all term for "tight underwear"
You're telling me that general tight fitting athletic briefs are not classified as compression shorts?
Mother Nature's Son
Quoted: 865 Post(s)
Liked 1,462 Times
I have four comments: do not wear any kind of liner underneath padded biking shorts, tight or baggy.
If you are self conscious about riding in any kind of bike shorts, you will get over that, with time, once you find one that offers the comfort and support you are looking for.
Bike shorts/tights, like saddles, can be a very personal thing. Recommendations are just that. Experience tops them, every time.
IME, compression type shorts can lessen muscle soreness on long rides.
Or are you implying that padded shorts have some sort of built-in liner ?
Mother Nature's Son
Quoted: 865 Post(s)
Liked 1,462 Times
yes
I wash my bike shorts
No
No
Yes, I’ve now read conflicting opinions on underwear and 2 layers causing bunching.
Remember that cycling shorts are made to be worn without underwear. The pad inside the shorts fights bacteria so the shorts are actually more sanitary when worn alone. Equally important, when you wear underwear with your cycling shorts, you end up sitting on the seams in the underwear, which can cause numbness, chafing and pain
https://www.wheelworld.com/articles/...orts-pg263.htm
I’m now leaning towards single layer of outer shorts with shamwow.
No compression shorts, no padding (assuming padding is different than shamwow)
Verdict: I ordered Pearl Izumi w/ liner chamois deeply discounted in blue for $55
https://www.westernbikeworks.com/pro...iner-clearance
https://www.competitivecyclist.com/p...-mens#the-wall
Liked 4,948 Times
Quoted: 833 Post(s)
Liked 1,979 Times
It's not that difficult.
More layers = more possibility of bunching and chafing.
Spend the money on a quality pair of bib shorts.
You will figure out over time whether you need a minimal chamois pad or something thicker.
If you want to wear a loose or MTB style shorts have at it.
Only issues I see are increased heat where you will sweat more, and possibly ripping your shorts if they get caught in the saddle nose.
Clark W. Griswold
Liked 4,184 Times
Even on a short 3 mile ride, sweatpants and boxers start to feel uncomfortable.
In terms of undies and bike shorts, keep them separate if you are wearing bike shorts you don't need undies at all and it will just create more issues the bike shorts take over the position of undies.
When I first put them on, it felt like I dumped a load into my shorts because the liner was hovering over my netherAss, not really contouring my body.
Once I sat down, the maxiCham was forced to contour around my body.
After my ride, when I got off the bike, the maxi pad was now cradling my netherAss, and felt like it fit correctly.
Went for ride, felt good, I never had to stand up out of the seat to rub my dog ass along the carpet to adjust everything.
I can see this adding up over longer rides.
Thanks to everyone who helped me !
