Dead di2
Bikes: BMC SLR01; Cannondale Trail; Lot's of project and vintage bikes..
Quoted: 342 Post(s)
Liked 168 Times
Dead di2
Help! During update the app shown an error. Now nothing works. I tried unplug the derailleur cable and wait a bit but still nothing change.How i can fix as fast as possible? I also don't have any kind of cable except for the charging one......
ignominious poltroon
Quoted: 2284 Post(s)
Liked 3,510 Times
The first place to look for a possible answer is here: https://bettershifting.com
I'll keep looking, but I wanted to post that first.
Maybe try this: https://bettershifting.com/frequentl...my-di2-system/
Briefly, it says to unplug the battery and wait, to initiate the reset.
Are you dealing with 12 speed or 11 speed?
Likes For Polaris OBark:
Liked 3,510 Times
Wireless updating of firmware (which I have never tried) does occasionally cause this problem. I would try the battery unplug trick first, and if that does not resolve it, a reset followed by wired firmware install is probably the best option. If you don't have the charger that allows one to do this from a PC, a bike shop should be able to do it for a few hundred thousand euros.
Quoted: 342 Post(s)
Liked 168 Times
Quoted: 7091 Post(s)
Liked 11,210 Times
TerryDi2C is the resident Di2 expert and one of the forum's most helpful members. Perhaps tagging him will get the OP the needed info.
Though in the meantime, the simplest solution is to take the bike to a good shop.
Likes For Koyote:
Bikes: SL8 Pro, TCR beater
Quoted: 1025 Post(s)
Liked 594 Times
Shimano app has never been very good... Not surprised to read such failure. If you tried updating through Bluetooth, try it through your computer instead (e-tube software needed. Windows only - Mac not supported) and see if it works.
You can always bring it to your LBS and see if they can work their magic.
I eat carbide.
Bikes: Lots. Van Dessel and Squid Dealer
Quoted: 1326 Post(s)
Liked 1,307 Times
You have to pull the cables at the battery and let it set if you want the soft reset. Apart from that I would highly recommend NOT updating firmware via the app. I have seen more than one Shimano Di2 system become inoperable from firmware updating via Bluetooth/app.
With 12spd unfortunately you're going to be best off finding a shop with a PCE02 diagnostic tool to push all of the firmware updates and do testing and find any error codes if the soft reset doesn't work.
PSIMET Wheels, PSIMET Racing, PSIMET Neutral Race Support, and 11 Jackson Coffee
Podcast - YouTube Channel
Video about PSIMET Wheels
Quoted: 3318 Post(s)
Liked 2,156 Times
I have not updated in years as no point. The system shifts perfectly and from what I've seen, nothing about the updates makes perfect better.
Liked 11,210 Times
Quoted: 342 Post(s)
Liked 168 Times
Here how i fix everything.
It was late night and the battery were at 40% when the problem begin. I tested a few things for example remove the rd cable without any update.
The next day the battery was completely drained, i just plugged into the charger and let it charge completely.
After the bike was charged the rd and fd were functional eccept for the satellite buttons on the hoods, at this point my phone was not connecting to the bike.
I used another phone with my e-tube profile and make a full update on the firmware list, then disconnect from the other phone and connect with mine.
I was able to cheeck almost everything, and disconnect it whitout any errors. Then after the disconnecting all the personal preferences including the satellite button came up as they were before.
Pretty silly if you think, and pretty stupid how shimano is selling some expensive cables for those kind of problems (or asking to send the groupset for assistance).
I hope this tread and my last update will help people figuring out how to solve it.
Likes For CrowSeph:
Advocatus Diaboli
Quoted: 4781 Post(s)
Liked 1,544 Times
Just a question out of curiosity, but what improvements come with this Di2 update, presuming you eventually get it to work?
Liked 3,510 Times
Having said that, I haven't updated since 2015.
Quoted: 842 Post(s)
Liked 1,696 Times
Firmware updates on just about any electronic device are, IMHO, a crap shoot. I updated the firmware on a DSLR and it turned into a brick. My motto is "if it's working fine for me, leave it alone."
Likes For Bald Paul:
Quoted: 4576 Post(s)
Liked 5,115 Times
Maybe, but I’ve updated firmware many times on countless devices without any major issues. So there is no excuse for Shimano to turn it into a crap shoot
Likes For PeteHski:
Advocatus Diaboli
Liked 1,544 Times
It's like a BIOS update. I won't even pretend to know what they are, but I cringe if I see that my PC is somehow automatically updating it and I can't stop it. I have no idea what it's for, or if things will be screwy after it's done. The ole 'if it ain't broke, don't fix it' adage is what we're on about.
Likes For Sy Reene:
I eat carbide.
Liked 1,307 Times
Agreed with above - I have seen enough issues over the years that I don't recommend updating the firmware unless there's an issue you're already having. If it is working then it's working.
Likes For Psimet2001:
Quoted: 9664 Post(s)
Liked 6,377 Times
Liked 11,210 Times
Likes For Koyote:
The Wheezing Geezer
Bikes: 1976 Fredo Speciale, Rivendell Clem Smith Jr., Libertas mixte
Quoted: 423 Post(s)
Liked 993 Times
With apologies to the OP, who is just looking for a solution, the last two posts remind me that mixing the software world with the bicycling world was a mistake. You end up with people boasting that software difficulties are worth extra money, which they are superior for having.
Di2 fanatic
Quoted: 54 Post(s)
Liked 68 Times
On 12-speed Di2, pull the wire from the middle port of the battery for ~5-15 seconds and then reconnect it.
If there is a dummy plug in there, take that out instead... and then reconnect it after a couple of seconds
Liked 5,115 Times
Likes For PeteHski:
