Chain ring compatibility with Ultegra?
Curmudgeon
Bikes: Specialized Diverge Comp
Quoted: 164 Post(s)
Liked 33 Times
I can not find Shimano Ultegra 50/34 chainrings. What other brands of chainrings will fit Ultegra cranks?
Bikes: !982 Trek 930R Custom, Diamondback ascent with SERIOUS updates, Fuji Team Pro CF and a '09 Comencal Meta 5.5
Quoted: 1314 Post(s)
Liked 763 Times
you're going to need to post the series/part numbers of your "ultegra cranks" before someone can do your shopping for you.
do you know where to see those numbers ?
Likes For Crankycrank:
Quoted: 863 Post(s)
Liked 1,113 Times
Here is one possibility. https://www.performancebike.com/shim...9670?v=1405698 You may find better deals by shopping around but Shimano has a mind boggling number of subset versions of their groupsets these days so hard to tell for sure if is. I suspect they are all interchangeable with 8100 and maybe some other tiers of Shimano's cranksets but I ran out of time digging for info on that. As far as other brands my experience is that none shift quite as crisp as Shimano's with their shaped teeth and ramps but some still come pretty close.
Curmudgeon
Quoted: 164 Post(s)
Liked 33 Times
Thanks to all who provided helpful input. I eventually found original ultegra r8000 50/34 for sale. All good.
Likes For rbrides:
