JIS Spindle in Swiss bottom bracket cups
Bikes: Motobecane C41, Matsu$hita Nashonaru
Quoted: 215 Post(s)
Liked 439 Times
I remember reading something about swapping BB spindles on Sheldon Brown's website in the past, but can't seem to find it now. So I thought there might be some forum members with knowledge regarding the subject.
I'm slowly gathering pieces and funds for this Winter's project, which is Motobecane C5. It came with a Stronglight Competition BB with Swiss threading, but I've basically used (almost) all the components I got with it for a Grand Sprint build. What I'm planning to do with C5 is to go for lightweight & Japanese components (I've got Suntour Superbe 1st gen derailleurs and shifters, SR Royal-5 Extra Super Light crankset, haven't decided on stem, handlebar, hubs and brakes yet). The problem, as usual, is the Swiss BB threading. On my other Moto I use IRD BB with Swiss threaded cups, but it seems they are not that easily available any more. I happen to have a set of traditional cups with Swiss threading (and a 126mm spindle, which is 1. too long 2. probably ISO taper) so I was wondering if I could use the Swiss threaded cups and get a JIS tapered spindle in the correct length (112mm) or some English threaded, JIS-tapered BB as a donor. Bearing ball size is the same, the width of the BB shell is the same (68mm). Is this a viable solution?
Likes For VintageSteelEU:
Likes For Mr. 66:
Bikes: old ones
Quoted: 26481 Post(s)
Liked 10,448 Times
...back about ten years ago, when I still had access to a huge box of old loose ball spindles at the bike co-op, I did a lot of spindle swapping. My experience leads me to believe that people often make too much of the JIS/ISO incompatibility.
It's not really all that simple as yes or no, and you need to do some dry fitting and mockups, to figure out whether you can make a crank work with your frame and chosen spindle. And there are some really surprising things you discover along the way, like the years when Campagnolo cranks were actually closer to JIS than ISO. If you read that Sheldon Browne material linked above, you'll soon figure out that a nominally JIS taper will push your crank arms out farther, by a mm or two.
What my own experience led me to, is the realization that I no longer can find the endless supply of old loose ball spindles that used to be available, that makes this practical as a solution.
With something like you are describing, I would probably just ream out the BB shell, and rethread it Italian. Then buy some sort of sealed unit square taper in the appropriate length, and call it good. But I have the tooling to do this, and it might not be the best solution for you, unless you have access to someone or some place with the stuff you need to do this modification. And you might have access to a large collection of loose ball spindles. So mostly just realize it will probably take you several tries (maybe more), to find something that works well.
So if you're buying them used, or online somewhere, the costs can add up after multiple tries.
Likes For eeuuugh:
Bikes: old ones
Liked 10,448 Times
...yes. If I could get them, I would use those as the simplest and most straightforward solution.
The Phil Wood Swiss retaining rings still show up as available, online. Link
Nothing Phil Wood sells is cheap, but it's all high quality and very durable. Lifetime guarantee, and that sort of thing.
Quoted: 4878 Post(s)
Liked 4,042 Times
Does Phil Wood do Swiss? Does Shimano on their cheaper BBS? If yes to both, the easy way to get exactly what you want is to buy the Shimano, mount it, put on the cranks, measure where they sit and where you want them. do the math to come up with the spindle length you want and its asymmetry (if you want that; I always go to get Q-factors down to where my knees are happy.. Call Phil Wood, place the order and rake out that second loan. In a week or so you will have a unit that looks high tech medical in quality and appearance that you can pass on to your grand kid. (The one who causes your son so much grief. Tell him he has to find a Swiss threaded frame to put it on. That should keep him out of trouble for a few years.)
Shimano and Phil are both very close to JIS spec. Phil BBs should put the chainring within a mm or 2 of where Shimano does. And Phil gives you adjustment ability to boot.
Quoted: 215 Post(s)
Liked 439 Times
Another thing here is that SR Royal-5 ESL is not an easily obtainable crankset, especially in usable / good condition. So I'm not too keen on even a slightest chance of messing it up
As for Italian threading, that's a design flaw Their BB's also use typically a 70mm wide BB shell, the one on the bicycle is standard 68. It's also threaded the same way as British standard, just a different thread (1.378 x 25.4tpi instead of 1.375 x 24tpi). So if there was any re-threading going to happen (which I don't think there's a point in doing), it would have to be brazing over the existing thread and going British.
The problem is that the cones / bearing stop on the spindle is in different position. So I'm wondering, since the bearings are all the same size (it would seem), would it be safe to use JIS spindle with the Swiss cups considering the slightly different position of the cones?
I'll show what I mean. ISO spindle upper part of the photo, JIS at the bottom.
ISO (Swiss threaded BB) versus JIS spindle
And another comparison is Italian ISO vs Swiss ISO (different BB shell width)
Italian (Ofmega) ISO vs Swiss ISO
Quoted: 215 Post(s)
Liked 439 Times
Two easy options are IRD conversion cups (with IRD BB and probably some Shimano ones) and Phil Wood (which are: a. expensive b. require special tools c. not popular in Europe because of reasons a and b). Or threadless BBs (which usually require some modifications of the BB shell as well)
Oh, I found what I couldn't find on Sheldon Brown's website:
"French bottom bracket cups usually have thinner walls than Japanese ones, so the bearing ridges on the spindles are farther apart. If you use a standard Japanese spindle, the adjustable cup won't be able to screw in far enough to snug up the bearings, or if it does, it will sink into the bottom bracket shell so that you won't be able to install the lockring.
The good news is that a Japanese spindle made for an Italian size (70 mm) bottom bracket will usually fit! In the J.I.S. marking system, these are the spindles that are marked with a "5" code. Spindles for 68 mm bbs have codes beginning with 3. This trick often makes it possible to upgrade an older bike from cottered to cotterless cranks, at a reasonable cost, or replace a worn French cotterless spindle that is no longer available -- but see warning below about French crank extractors."
Now the question is whether French and Swiss cups are the same, thickness-wise...
Well, another thing is that SR Royal-5 is apparently ISO, according to Velobase. So something to double check.
Bikes: old ones
Liked 10,448 Times
You install it, using a drive side spacer, and the adjustable side retaining thingy might stick out a thread or two more. I would just say trust me on this, but it's the internet. Maybe if there's anyone else who has done it, they could help reassure you.
Here are pictures of the thing being done. It really does work, but if you can buy and use the IRD stuff, that's what I would do, since your bike is not damaged in the shell threading.
before
during
after
I ride this bike here all the time, with it's Italian threaded bottom bracket. The sealed unit Italian BB's are much less inclined to back out on the drive side under use, but that's why God has given us Loctite.
The only issue is what it's costing you for each experimental failure. In my case, it was costing very little, because I had that huge box of cannibalized spindles. Now I don't.
Likes For 3alarmer:
Bikes: old ones
Liked 10,448 Times
Bikes: 1980 Gitane sprint,1977 Motobécane C4, 1977 Carlton Clubman, 1959 Claud Butler European
Quoted: 75 Post(s)
Liked 128 Times
Nobody does Swiss threaded BBs as such any more (IRD and Phil Wood make cups). They were not exactly popular back in the day, the only major volume manufacturer using the standard, I believe, was Motobecane from early 70's until early 80's (and apparently some Swiss manufacturers, I don't know any Swiss bicycle brands, though I did stumble upon something made in Switzerland). Perhaps some other French manufacturers did follow the example to some degree.
Quoted: 215 Post(s)
Liked 439 Times
I'll have to do some searching. I have one spindle from an Italian BB, but it's Ofmega and they had different standards at times. And at times they didn't. Kind of like every manufacturer, it seems. It's close, but about 0.5mm too wide apart on each side (aldo, too long in total). The other Italian bottom brackets I have are cartridge ones, so no use here. For now I asked some eBay sellers for measurements, we'll see if anyone replies.
Disraeli Gears
https://www.interlocracing.com/shop/...cket#attr=1107
If you need help, I could buy them on your behalf and ship from USA -- provided you can wait for a couple weeks.
Likes For Charles Wahl:
Bikes: old ones
Liked 10,448 Times
Old fart
Quoted: 3617 Post(s)
Liked 3,454 Times
Yes. And French. And Raleigh 1-3/8" x 26tpi. And Chater Lea. And T47.
https://phil-wood-co.myshopify.com/c...ottom-brackets
No. But Phil mounting rings fit some other cartridges, e.g. SunTour, EDCO.
Ride, Wrench, Swap, Race
Quoted: 1568 Post(s)
Liked 1,308 Times
On my Swiss-threaded 1979 Peugeot PX10E or PXN10 I used an older Shimano 115mm cartridge bottom bracket having aluminum cups.
I greased the threads heavily and "worked" the cups in using a large 1/2" breaker bar, back-and-forth until the cups settled in against the bb shell on the right and against the cartridge on the left. The frame's threads seems to have cut new threads into the alloy cups on the bb, and I've been riding this one for over ten years now.
Quoted: 215 Post(s)
Liked 439 Times
I'm not sure why you think these aren't "easily available".
Just ordered a loose SR Royal BB spindle in 112mm. Wasn't expensive, so though might as well give it a go. I think what I have to do today is to dig out that crankset, all bottom brackets I have knocking about and check the taper. Velobase says ISO, which I totally forgot about (because Sakae Ringyo being Japanese, I expected JIS). But best to double check, I think. If it's ISO, IRD BB wont be a good solution because their bottom brackets are JIS. The same goes for Shimano. So the new headache will be to sort out what bottom brackets IRD conversion cups can be used with and who makes them with ISO taper ;D
I think overall I would stick with the headache of choosing the correct spindle to work with the cups I have and the crankset I have. Also because I'd like to use parts that would not be out of place in the late 70's. The required length (112mm) might make it a bit of a challenge, but I'm sure Campagnolo (well, that's another can of worms), Miche, Stronglight or some Japanese manufacturers must have made bottom bracket in this or similar spindle lenght and correct spacing of the ridges. Or perhaps it's time to start a vintage parts factory and make loose bearings bottom brackets a thing again?
Quoted: 1975 Post(s)
Liked 2,092 Times
Just to share my experience:
I must have been lucky with my 1977 Swiss Motobecane G.R. I swapped either a Stronglight or Sugino spindle to use with a Shimano crankset that worked fine. The shoulders matched. Maybe that spindle came from a Somec that I put to the curb many years ago because I couldn’t remove the stem. (I’m smarter now.)
Quoted: 215 Post(s)
Liked 439 Times
My commuting Motobecane frame came with the bottom bracket below. Nadax Favorit. They are sometimes listed on eBay as Swiss, because the company was Switzerland based, but I have only seen Italian and British threaded ones. Mine is British threaded and it was sitting in a Swiss threaded bottom bracket shell. Because it's aluminium, I think it worked kind of in a way you describe, most likely by accident. BB shell thread just cut into aluminium on the drive side. On non-drive side thread doesn't matter because the lockring threads onto the bottom bracket body. That same frame now uses IRD Swiss threaded bottom bracket and also another Swiss threaded cup I have goes in without an issue. However, when I tried it on another, Swiss threaded frame (the one I'm going to work on), it will go a few threads in and then not so much. Because the "lockrings" are also aluminium, it might be actually quite difficult to forcefully "re-thread" it the way you described (but it explains why they are so worn out). I might not have enough purchase with the standard lockring spanner and it doesn't have any spline, like Shimano standard bottom brackets. Might be challenging.
It's actually the best bottom bracket I've seen to date, it's way smoother than Suntour Superbe with very fine grade loose bearing balls. The spindle length is 114mm, so a bit too long (but I might be able to live with chainline being 2mm out of spec) and looking at it right now it seems the taper might be ISO (12.6mm at the end). The crankest taper... well, that's still a guess. I seems to be 12mm at the very thin end and 13mm at the wide end. It goes noticably further down on the known JIS spindle than it goes on the Nadax one (without actually using any bolts, so it's eye-balling it, not scientific measurement).
I mean, in the end, the difference between ISO and JIS is not that great, as mentioned by people above before, this might not be a problem. The crankset itself is almost new. It has been mounted on some bottom bracket before and used, but not much overall. Basically there's no wear to the taper on cranks. So I'm guessing this will help with adapting it to whatever taper is available.
I have to say, I dislike trying to force things on to make them work. The tolerances when it comes to various bicycle components standards might not be quite as tight as in spacecraft construction, but I do like having parts that are a fairly close fit. I have now ordered a spindle that was most likely designed to go with this crankset and probably take it from there. One of the people selling these SR Royal spindles sent me their measurements and they don't quite match (but ae close), so I guess in a few days I should be able to just compare both spindles.
Thankfully, the frame won't be worked on before Autumn. I did have a look at an option of having the BB shell threaded to 1.37x24TPI and that is £120, which considering other costs (frame repairs and re-painting) makes it not a very cost effective option
Bikes: old ones
Liked 10,448 Times
My commuting Motobecane frame came with the bottom bracket below. Nadax Favorit. They are sometimes listed on eBay as Swiss, because the company was Switzerland based, but I have only seen Italian and British threaded ones. Mine is British threaded and it was sitting in a Swiss threaded bottom bracket shell. Because it's aluminium, measurement).
The old sealed unit I removed looked like this:
The original concept was OK, but the execution using aluminum that rides in such close proximity to the dissimilar steel BB shell lends itself to accelerated corrosion in wet environments. I suppose you could make it work better with drainage holes in the shell, but I threw this one away.
Good luck with your project.
Quoted: 215 Post(s)
Liked 439 Times
...just in passing, I thought I might mention to you that this sort of large bore, aluminum casing for a sealed BB unit is exactly the kind of thing that damaged the Ron Cooper frame I showed you as an example.
I think many designs in cycling are made with pro racing in mind, where components are not planned to be used 30 + years later and throughout this period. They used aluminium probably because it's easy to work with and lightweight, so made sense. Not that great on the frames In the long term.
This project is going to be quite a money sink anyway. I'd rather get another C5 frame in my size if that was an option, that would definitely be cheaper. I do have enough parts to probably put 3-4 good bicycles of various types on the road, though for this particular one I'll be getting some more components. And another saving grace is that I build my own wheels.
aged to perfection
Quoted: 864 Post(s)
Liked 1,301 Times
I think many designs in cycling are made with pro racing in mind, where components are not planned to be used 30 + years later and throughout this period. They used aluminium probably because it's easy to work with and lightweight, so made sense. Not that great on the frames In the long term..
put another way, I am skeptical that the current crop of all carbon, electronic shifted bikes will be rideable 20 years from now !
But what do I know ?
/markp
Quoted: 3466 Post(s)
Liked 2,841 Times
Electronic shifting, the single speeds of the 2040’s
Quoted: 215 Post(s)
Liked 439 Times
In 2040 we might have neural link or brain waves shifting, who knows If I'm still around then, I think I will be still happily using Suntour derailleurs with friction shifting.
Looks like I found Swiss IRD cups in a shop within the EU. So I'll get a set just in case whilst I'm trying to figure out a spindle. Combined with checking whether any Miche or Tifosi cartridge type bottom brackets are compatible. I have Sakae Ringyo Royal in 112 on its way, though I expect this won't be the correct fit for the cups I have as it's not from a 70mm BB. Other ideas to try are Sugino MW-70, though that is 114mm, and Campagnolo 70-SS, which I think can be 111 or 115mm.
