Looking for padded cycling gloves for large hands
I have large hands with a girth of about 11.5”. I trying to find some padded half finger gloves which don’t squeeze my hands. All the XXL or XXXL ones I am finding are two small and my hand and fingers will start tingling after minutes.
Can anyone recommend some large padded gloves?
Quoted: 6321 Post(s)
Liked 4,912 Times
I've not found any difference in whether I use padded gloves, unpadded gloves or no gloves. For shorter rides perhaps padded gloves make them seem nicer. And for longer rides, gloves of either sort can make it easier to grip the bar/hood than a slippery sweaty hand.
For a road bike with drops, this is what I've found over the years... If your fingers are tingling, it might be how you are holding the bar or hoods. Your wrists need to be straight. If you can't keep them straight, your bars may be too wide. I like to have the palm of my hand going down the side of the hood.
If you can't find a wide enough cycling glove, then just find what you can and cut the fingers out if you need too.
Quoted: 7674 Post(s)
Liked 3,557 Times
It is a tough call, because manufacturers are reall distributors, and they wikll buy gloves from wherever they can at a good price and re-brand them.
I have some truly large gloves from Pearl Izumi, Bellwether, and Louis Garneau, all bought at online close-out sales, so I cannot direct you to the exact models ... but there are some actual American-sized 3xl gloves out there. I don't know where .... "buy low, send back", is my practice.
Henderson, NV
Bikes: Trek Alpha 3700, GT STS DH, Raleigh Grand Prix, Fisher Montare, Fisher CR-7, Fisher Aquila, Diamondback Sorrento, The Bike Beat Revolution, KHS XC 504R
Quoted: 327 Post(s)
Liked 615 Times
I use gym gloves to ride. I would suggest a sports store that deals in weightlifting. You might find a set of 3XL gloves available.
Quoted: 2364 Post(s)
Liked 2,887 Times
try these from aerotech, I got the 3xl and had to go to 2xl so not fitted small https://aerotechdesigns.com/extra-pa...html#sizechart
these i have not used but aerotech is known for big sizes https://aerotechdesigns.com/tempo2-f...loves-gel.html
Likes For squirtdad:
Thread Killer
Quoted: 3209 Post(s)
Liked 1,749 Times
Anyway, I don’t have any specific reccos, but would suggest you contact the company Elastic Interface and see if they manufacture a suitably sized palm pad which some glove maker is using. The EI palm pad is, as the name suggests, stretchy, so when combined with a stretchy upper, really increases the fit range and enhances comfort.
I use MAAP Pro Race Mitts in XL, which according to their fit chart are appropriate up to 9.6”, but they fit my 10 5/8”ers like, well, a glove! They’re the best gloves I’ve ever had in my +30 years of cycling; I’ve had a lot of gloves. I don’t know that there’s another .6” of comfort in those for you, so I won’t reccommend those, but it’s the proof of concept to me that’s interesting; all the material stretches, so it’s not the same as cramming your hand into a fixed-width glove. Maybe EI make a pad larger than the XL used by MAAP, Q.36.5, and others. DHB, Wiggle’s house brand, claim to have an EI pad glove in a 2XL, and the pricing is quite good, so it may be worth a flyer just to see. I suspect that a lot of these companies are posting fit guides based on standard gloves, not the EI palms, which would explain why I can fit into an XL.
Shoot an email over to EI and see what they say. Good luck!
Quoted: 571 Post(s)
Liked 604 Times
My hand arthritis has me look at industrial supply companies for anti-vibration gloves which I have found more effective than cycling gloves. They typically have at least XXL and some XXXL, some are like "tactical" gloves and way overkill but I have found some nice fingered and fingerless that are made for vibrating tools like jackhammers/hammer drill, etc. I liked these but ordered L and had to return for XL as I thought they run small so would be no help to you.
I'll just mention that with the fashion going to a bit wider tires and lower pressures gloves are possibly a bit less of a necessity. The more comliant ride offers a good reduction in the vibration transmittted to the hands and wrists. I notice quite a few in the pro peleton riding sans gloves. I am not saying you should as well, but it is something to think about.
Even if you wear gloves a nice complant tire with a supple sidewall and a wide-ish width running a lowish pressure may help quite a bit with hand comfort. This will be particuarly ture if you ride somewhere with especially bad chipseal. I recall much of Texas being especially bad when I rode across it. I was on real skinny tires and it helped when i went a step wider when they wore out. I bet some even wider and more supple tires would have been a joy.
I have big paws also and wear XXL or XXXL depending on the glove. The absolute best gloves I have found are made by Bionic, yes the golf glove maker. I'm still on my first pair that I bought two years ago. They are very high quality and I rinse them under the faucet often to rid them of sweat, which greatly extends any glove's life in my opinion.
I bought a replacement pair but have not had to use them yet. If you value durability over anything else I would also recommend the Mechanix half finger M-Pact gloves. I used those for a few years before I bought the Bionic's; however, the padding in the Bionics is better but the Mechanix gloves just don't ever wear out. The problem is that it's hard to find the Mechanix in stock in XXL or XXXL.
https://www.bionicgloves.com/Bionic-...-the-Dream-Pad
https://www.mechanix.com/us-en/finge...gerless-gloves
Location: western Massachusetts (greater Springfield area)
Bikes: Velosolex St. Tropez, LeMond Zurich (spine bike), Rotator swb recumbent
Quoted: 67 Post(s)
Liked 67 Times
Bikes: A few older US made Cannondales, a modern Soma Saga (no longer made, alas!), and one gifted crabon Specialized. Never enough.
Quoted: 45 Post(s)
Liked 60 Times
Vibrastop gloves
While not as big as your hands, I’ve had issues finding big enough padded gloves. Ended up using Vibrastop gloves for the past 10 years now. Biggest I could find was XL, although Superior Glove lists bigger sizes now. I cut off the strap portion and they stretched enough to fit comfortably after a while. The padding is made for vibrating tools, which is what I originally ordered them for, and they work great for that too.
I bought a pair of the vibrasoft ones from Amazon. I ordered a large as my Specialized Double gel gloves are in large. The padding seemed OK and the fit was a little too large. I took them out for a couple of rides and my fingers get numb after about 8 to 10 miles. I think they are too large and not flexible enough for my use. I will give them some more trials hoping they become less stiff.
