PSA: Stronglight 3-pin 116 bcd chainrings
vintage motor
Bikes: 48 Automoto, 49 Stallard, 50 Rotrax, 62 Jack Taylor, 67 Atala, 68 Lejeune, 72-74-75 Motobecanes, 73 RIH, 71 Zieleman, 74 Raleigh, 78 Windsor, 83 Messina (Villata), 84 Brazzo (Losa), 85 Davidson, 90 Diamondback, 92 Kestrel
Quoted: 169 Post(s)
Liked 107 Times
Somebody is offering NOS Stronglight 3-pin 116mm bcd 38-tooth chainrings on Ebay for $20 shipped. These will fit many vintage cranks, I bought mine for a TA Professional. These are great cranks but it is really hard to find chainrings for them that are smaller than 42t. I have not yet received it and am not sure if the holes are the correct size, but that's something I can work out.
Likes For kroozer:
Quoted: 5909 Post(s)
Liked 3,559 Times
Just bought one.
Quoted: 3866 Post(s)
Liked 3,459 Times
thanks for this great tip!
assume they would be TS
are they offering both regular & bis or just regular?
Quoted: 3839 Post(s)
Liked 6,888 Times
I took a flyer one one, but I’m guessing that those holes will need to be modified if used for a TA 3-pin crankarm. They look like they were designed for Stronglight 116 bcd cottered steel arms.
https://www.ebay.com/itm/275603608415
Liked 3,559 Times
Quoted: 3466 Post(s)
Liked 2,840 Times
From the image, bores need to be enlarged and if one had access to a mill, a counterbore added, verify you have 2mm gap to the chainstay to avoid that need.
‘there might be a need to file the ring to clear the TA pro lands.
ambulatory senior
Quoted: 1957 Post(s)
Liked 3,673 Times
Do you guys think these are aluminum?
Quoted: 1118 Post(s)
Liked 1,346 Times
Thanks, got a pair.
I have a similar 36 tooth, just went and checked, the holes are about 7.25mm dia and the TA arms just fit nice and snug.
For this - and any other inner ring - don't bother to counterbore, just use a longer sleeve.
Likes For oneclick:
Liked 6,888 Times
As others have pointed out, different sized chainring bolts. The TA 3-pin also uses bolts unique to that chainset; different size from anything else I’ve seen. The Stronglight steel cottered (and its Nervar variant) don’t use a bolt and sleeve system, but just a bolt as the crankarms are threaded. That’s what these rings are intended for, I’d guess.
Likes For nlerner:
Liked 1,346 Times
Liked 6,888 Times
aged to perfection
Quoted: 857 Post(s)
Liked 1,295 Times
timebehindbars is a good ebay seller
/markp
/markp
Likes For mpetry912:
Liked 6,888 Times
My ring arrived today, prompt shipping from PA to MA:
As I guessed, those small holes don’t quite line up with any of the 116bcd cranksets I have around. Here it is on a Stronglight 3-pin of some sort:
You can see the holes on the crankarm have a larger diameter than the holes on the ring:
Here it is next to a 42t ring for a TA 3-pin crank arm; again holes are smaller:
I also tried it with a steel cottered Stronglight arm, which uses threaded crank bolts through the ring and into the arm. The problem here is that the arm has a raised ridge around each hole. Mind the gap!
So to be useful, I’ll need to enlarge the holes on this ring. Might have to finally figure out how to use the drill press I traded a vacuum cleaner for.
Likes For nlerner:
Liked 3,459 Times
thank you for this information
the chainset model in your image is Verot's TS which stands for Touring Sport
IIRC it launched in 1974
note how in this parts illustration the chainwheel you received appears to match the part number 252 in the drawing
Liked 6,888 Times
Liked 3,459 Times
yes, there is early and late
the revision may have occurred with the big reworking of the range which took place for the 1977 model year
this is when:
model 93 was discontinued
model 99 was revised
model 104 was launched
model 105 was launched
Liked 6,888 Times
Ah, Velobase.com abides, as always:
https://velobase.com/ViewComponent.a...=115&AbsPos=71
Not sure how I ended up with one DS arm, but it does reasonably match a later model 99 NDS arm.
Liked 3,459 Times
another variable to be aware of for readers -
lands thickness
up until the launch of models TS & 99 Verot's chainwheels were always tooth cut from one side of the stock only
when assembled into a chainset they were mounted with the flat sides facing each other
this means that the thickness of the lands ("spacer") is thicker on a model 57, 63 or 93 than it is on models TS, 99, 104 and 105
models TS, 99, 104 & 105 all have their chainwheel teeth cut from both sides of the stock so their lands need to be thinner to have the correct spacing between chainwheels
lands thickness
Likes For juvela:
Liked 1,346 Times
b) don't drill those holes 10mm, there isn't enough left after; instead just bump them to 8 and use the crank bolts reversed, as indicated.
Likes For oneclick:
vintage motor
Quoted: 169 Post(s)
Liked 107 Times
I just received my chainring and promptly lined it up and drilled and filed the holes to match the TA cranks. I think there is still plenty of metal around the holes, but we'll see.
Bikes: Road: 1972 Raleigh Competition,1989 Marinoni, 1990 Limongi. MTN: 1990 GT Team Avalanche, 1991 Rocky Mountain Blizzard, GT Team RTS , Rocky Mountain MSL 50 Element, CCM fat bike
Quoted: 36 Post(s)
Liked 81 Times
Raleigh Competition with 38T chainring.
Th
Chain on 52 and 28 in the rear.
Chain on 38 in the front and 14 on the freewheel.
The next cog up had better tension. Pretty good for that little Jubilee derailleur.
