Is the qr frameset dead?
Had a lovely salsa vaya for my hed wheels to reside in. She was my go fast bike. Then the pandemic hit and I had to cull the herd for survival sake. Some say it’s not worth it. I disagree. Help is help no matter how small. Now that I can turn down the work volume and turn up the play volume again, I want a road bike. But I seem to be marooned on quick release island as the cycling world has converted to thru axle.
Budget still dictates so custom frames are a no go.
Anything I missed out there? Or am I just going to have to save my shekels for a carbon gizmo?
steel is real
steel is real
Quoted: 455 Post(s)
Liked 485 Times
Thru axle wheelsets often have QR endcap adaptors. But if it's an older wheelset then perhaps thru axle adaptors do not exist. If getting a new frame, everything will be thru axle starting from ~2015. In which case, you may try to sell the current wheels to someone who could use them and just get new wheels.
Likes For tFUnK:
Bikes: Soma Double Cross Disc (2017), red Hardrock FS (circa 1996)
Quoted: 217 Post(s)
Liked 155 Times
Or Surly Preamble?
Quoted: 913 Post(s)
Liked 2,097 Times
I have a mixed herd and it's annoying AF.
I have a Soma Fog Cutter QR with a White Industries rear hub and SP front dyno. Disc no less - QR road disc existed for a millisecond. Neither wheels nor frame has much of an upgrade future. Plus I have a 650b wheelset for this bike that has no other purpose in life.
IIRC, the new Fog Cutter is available with replaceable dropouts that support QR and TA.
Veteran, Pacifist
Quoted: 3920 Post(s)
Liked 4,894 Times
Thru axles are stiffer laterally, some added stiffness may be just because the latest forks are. Altho the trend toward 30+mm road/mixed tires offsets the added stiffness, Tire pressures will determine the ride & handling responsiveness one wants in a fast 'n racy new road bike.
Maybe there is online info with a side-by-side fork review, comparing the two axles?
Frame & fork - if 'steel is real' very nice used framesets (quite modern) are affordable. Soma is a good recommendation, too. Or, for a carbon frameset = check out threads on BF about 'direct from China' frames. There are several companies with a popular reputation.
The preamble is on my list but sizes are questionable right now I have to contact surly on that. Maybe I can snag a used vaya or pre thru axle midnight spec.
hope springs eternal
thanks peeps!
Thread Killer
Quoted: 3212 Post(s)
Liked 1,751 Times
I’m confused… intransit1217 , what’s important here? Going fast, reusing the old HEDs, quick releases, or a steel frameset?
The HEDs are QR disc, no? I don’t recall Vaya ever having rim brake. Are they deep section aero rims, or Ardennes/Belgium?
I also don’t think of Vaya as a go-fast bike, nor the Preamble, for that matter.
Without knoeing what model HEDs, what kind of budget, or what’s the priority, all I can say is that probably the HEDs are not as important as you think.
Checking boxes for metal frame, quick releases, and go-fast, the Wilier Montegrappa can be had for sub $2k. It’s aluminum, under 22lbs, drop bar, proper 2x drivetrain, and has classic road geometry. It’s also rim brake, so you’ll have a much easier time getting aero go-fast wheels than you will tring to find a go-fast frame for QR disc wheels.
Quoted: 6329 Post(s)
Liked 4,918 Times
If you are flatting so much that you need wheels with a QR, then you aren't going to have fast times for a ride no matter what you get. I was a little apprehensive about giving up to the thru-axle. But I haven't had any issues because of it. It's actually made for less checks and less worries.
I was one of those that drank the kool-aide of the "steel is real" mantra not too long ago. But I have to now say that my Specialized Tarmac is the most fun bike I've ever ridden. So don't be so down on CF bikes.
The montegrappa is the prettiest aluminum bike I’ve seen. Prefer steel or carbon. Wasn’t thrilled with my specialized sectuer sport.
ignominious poltroon
Quoted: 2280 Post(s)
Liked 3,503 Times
My wife's bike has I9 torch hubs. You can buy QR end caps for them. I did, just in case I ever want to try them on my 2014 custom steel road bike that has disk brakes and QR.
In addition to I9, White Industries and DT Swiss are two other hub manufacturers that make QR/thru-axle swapping comparatively painless. I am sure there are others, too.
Bikes: 2002 Eddy Merckx Team SC Resto-Mod; 2019 Ibis Hakka MX; 2017 Spot Brand Ajax Belt Drive
Quoted: 169 Post(s)
Liked 192 Times
Reusing the Belgium plus wheels is #1. (I-9 hubs and Sapim spokes) I’m a Clydesdale so I stay 32 or better and I have 1300 in that wheelset so it’s hard for me to want to just trash them. Yes they are disc.
Likes For mattcalifornia:
HOLY FRIJOLES BATMAN! Gonna check with my lbs that built the wheels. If true, I’m jumping on a bikes direct bike I’ve been avoiding because it’s spec’d with 28hole Stan’s. I *think*. Had my eye on that reynolds mule kick forever. Maaaaaan
With a mighty wind
Quoted: 1114 Post(s)
Liked 912 Times
I don’t remember what Stan’s newest hub is, and I don’t know how convertible it is.
Liked 3,503 Times
I was wrong. DT Swiss 24 spoke. Still, yours is the best solution if my hubs are compliant.
