Squealing Brakes
Quoted: 364 Post(s)
Liked 137 Times
Squealing Brakes
I have a '73 Schwinn Voyageur 11.8. I put on some new brake shoes on it and the brakes just squeal like nothing else! I've tried everything make it stop and nothing works. To date, I've retoe the brakes several times and even bought new brake pads, nothing works. Right now it has on Kool Stop brakes but the noise wouldn't go away. Any ideas on what to do next?
Likes For Kai Winters:
Mother Nature's Son
Quoted: 864 Post(s)
Liked 1,459 Times
Tinker-er
Bikes: 1956 Rudge Sports; 1983 Univega Alpina Uno; 1981 Miyata 610; 1973 Raleigh Twenty; 1994 Breezer Lightning XTR; V4 Yuba Mundo aka "The Schlepper"; 1987 Raleigh "The Edge" Mountain Trials; 1952 R.O. Harrison "Madison"
Quoted: 184 Post(s)
Liked 310 Times
What kind of brakes does it have? side-pull or center-pull calipers? Both systems benefit from disassembly and a good cleaning and lube.
With side-pulls, try tightening up the pivot bolt to the point just where it binds then back off the nut just enough to let the caliper move.
Center-pull calipers are notorious for squealing but when they work, they really stop. You can first try tightening up the pivots paying attention to the arms and noticing if they rock at all. If so, the bushings should be replaced. Unfortunately, it's easier to buy a whole brake than it is to find little nylon bits like these. A final thing you can do is to make a brake booster which locks together the pivot bolts and prevents them from oscillating.
Try cleaning the rims with some mild steel wool and remove any dust with a moist rag. Does your bike have steel or aluminum rims?
You could always just view your brakes as a horn to let people know you're coming!
Quoted: 3630 Post(s)
Liked 3,051 Times
Quoted: 364 Post(s)
Liked 137 Times
Yes, I've sanded the rims too. Sorry for the misspelling of some words. You get up at 3:30 A.M. and see how well you spell. (The Cats made me do it. ) BTW, they are side pulls.
Quoted: 4872 Post(s)
Liked 4,038 Times
So the cats' squealing awoke you. And once awake, they took a break from squealing.
1973 sidepulls. How did you set the toe-in? When those brakes were made, the brake pads with the fancy washers you rotate to set the toe-in didn't exist. Mechanics reached into their toolbox and pulled out the toe-in adjustment tool that conveniently was made to handle both metric and English. The Crescent wrench. (Back when Crescent was capitalized and the wrenches made by Crescent.) Fit the wrench over the ends of the calipers after removing the pads and twist hard enough to get the proper toe-in.
Fast forward to 2023. You have just broken every rule in the book and all warranties ever written. This is a sin for which you will never be forgiven. Fortunately the mechanics who did this on a daily basis are fast dying off. Soon all memories of these atrocities will be buried forever. (If you happen on a pair of those old brakes that doesn't squeak - beware - its been touch by that cursed tool. Now, if you hadn't read this post you could ride those calipers forever in bliss but who would want that?)
Likes For 79pmooney:
Liked 3,051 Times
Quoted: 364 Post(s)
Liked 137 Times
The brakes are all original, as far as I know. As for the Cats, their bad...and they know it. LOL If they were worked on it before I bought the bike, I don't know. It is a Barn Find and hopeful with help of this list it will be ok.
Bikes: Schwinn Varsity
Quoted: 1931 Post(s)
Liked 742 Times
We know what a Cresent wrench is.....ask for the Cresent wrench and you will get the right one. Ask for an adjustable wrench.... and you will get the look... Channel-loc? pipe-wrench?.... what you talking about.......?
Bikes: !982 Trek 930R Custom, Diamondback ascent with SERIOUS updates, Fuji Team Pro CF and a '09 Comencal Meta 5.5
Quoted: 1301 Post(s)
Liked 745 Times
and when you sanded the rim, what grit and type of sandpaper was used?
and if your bike doesn't look like this one, it's not a 1973, and the '73 came equipped with center pull brakes...
https://bikeindex.org/bikes/88207
what is the brand/model of your side pull brakes?
I apologize for the spelling commenters... Bored old men in search of cheap thrills will say dumb things and be mean, then complain about the lack of results.
PS.. the cats promise they'll quit waking you up at 3:30am if you quit using them as scape-goats.(cats lie a LOT!)
Likes For maddog34:
Quoted: 5939 Post(s)
Liked 2,843 Times
New brake shoes are like new chalk on a blackboard. Both squeal annoyingly for the same reason. In time, normal wear solves the problem.
For those lacking patience, speed the process using a rasp or coarse file to break the rear corners of both shoes.
People will advise using more toe in, but it's too easy to get carried away and end up with spongy brakes. Normal wear will always establish the optimal toe in matched to brake arm flex and contact friction, so I prefer to use minimal initial toe-in, and let the brake do its thing.
FB
Chain-L site
FB
Chain-L site
Liked 4,038 Times
An anti-squeal solution I learned here that works rather well - rub the rims with garden dirt, preferably dirt with little sand, clay or grit. Doesn't last forever but the squeal won't be as big when it comes back.
Quoted: 249 Post(s)
Liked 473 Times
I used a "toe in" adjustment tool today on a pos front brake caliper...the tool works as it always has and will be used for years to come until the last of the flat pad calipers are gone...I doubt I'll see that day as I'm 67.
PS: The proper tool works far better than the adjustable wrench.
Wheelman
Bikes: 1982 Holdsworth Avanti (531), 1961 Holdsworth Cyclone
Quoted: 305 Post(s)
Liked 715 Times
I've used the adjustable spanner method on Weinmann 500s successfully, but the only "toe in tool" I can see online seems to measure the angle for brakes with shims or similar.
Liked 3,051 Times
It’s designed for the job and fits better. No “extra” metal like on the jaws of an adjustable wrench. It’s also stiffer since there aren’t any moving parts.
An adjustable will work; but as I frequently mention, the proper tool will make the job easier.
Wheelman
Quoted: 305 Post(s)
Liked 715 Times
Found it now: Park Tool BT3, no longer in production but available on Ebay etc.
Likes For Aardwolf:
Liked 3,051 Times
Liked 3,051 Times
Liked 4,038 Times
Liked 3,051 Times
