1 and 1/8 threaded fork, taller stem height
Quoted: 5898 Post(s)
Liked 3,513 Times
I'm helping a friend with a 1992 900 series mountain bike Trek with a 1 and 1/8 threaded fork. She needs to get that stem higher and I'm trying to figure out the options.
Option A is to find a 1 and 1/8 threadless adapter. Those are hard to find. I found this from Performance, https://www.performancebike.com/fort...BoCijsQAvD_BwE
The other ones I've found are all one inch threadless adapters. Does anyone else make a threadless adapter for a 1 and 1/8 inch threaded fork?
Option B is to shim it. Is that an acceptable solution? I'm a little leery of doing this but perhaps I'm wrong to be concerned about a shim to take the fork from 1 and 1/8 to one inch. If this is a viable option, what should I look for?
Edit: Soma sells a shim: https://www.somafabshop.com/shop/273...rer-5554#attr=
Bikes: !982 Trek 930R Custom, Diamondback ascent with SERIOUS updates, Fuji Team Pro CF and a '09 Comencal Meta 5.5
Quoted: 1300 Post(s)
Liked 742 Times
Plan C: get your friend to do Stretching Exercises on a daily basis, and get high rise BARS.
https://www.ebay.com/itm/29563893984...Bk9SR5qb4YmzYg
And i've found that the more upright a person sits when riding, the more PAIN they are in after a ride.
When their want to plant both feet flat on the ground while their butt remains firmly stuck to the extra-wide, too soft, Chafe-causing seat is added to the equation,... they are absolutely miserable during the ride too. Each pedal stroke brings a pained grimace to their faces.
Likes For maddog34:
Cyclist
Quoted: 39 Post(s)
Liked 16 Times
I have a couple of 1 1/8 threaded bikes, one with a threadless adapter. I wouldn't use a shim for a quill stem. Maybe a different style bar with some rose and sweep would accomplish the same end?
Likes For storckm:
Bikes: Franklin Frames Custom, Rivendell Bombadil
Quoted: 124 Post(s)
Liked 216 Times
Bikemig, This is one of those cases where the US market isn't so great. Procraft as well as by.Shulz (German brands) makes them in both sizes and they're inexpensive in Europe. I'm quite familiar with many of European retailers who deliver to the US and in checking these it seems Rose Bikes offers the lowest shipping to the US "if" you're only ordering small items and not too many. The cart adjusts the price for deliver fees. You'll figure it out as to whether or not it's worth it for you. From my experience when I shop at such places, I go through the website and see if there's anything else worth buying, to maximize the bang for the shipping cost. There's many other German websites to shop from that have higher fixed shipping cost that are better if you order many items, like tires or something.
https://www.rosebikes.com/byschulz-a...-stems-2665754
Likes For Garthr:
Liked 3,513 Times
Fair enough, but this is for a person with short legs and a long torso. So a 15.5 inch rigid MTB (a '92 Trek 900) works great in terms of standover height, but the cockpit is a problem. I need to stretch the cockpit out for this to work and tallish 1 and 1/8 quill stems or threadless adapters are scarce.
Liked 742 Times
https://www.ebay.com/itm/26634494152...Bk9SR6rF7JWzYg
etc..... there are dozens of them available. I have two in stock, personally...
Have you actually MEASURED a "1 1/8" threaded stem"?
they are ONE INCH OD where they slip into the top of the fork... plus or minus a tiny bit.
i also have many of those, in various lengths and rises... some with, and some without Canti cable guides.
I strongly advise that you GO TO A BICYCLE CO-OP/RECYCLER, or Local Bike Shop, and get what you falsely think is so rare.
also.. measuring from the crank center to the top of the seat tube is a now Obsolete Gauge of frame size due to the very frame type you have.. Measure from the Center of the steering head to the center of the Seat Post to correctly determine frame size. I understand that you referred to Standover height, but that is NOT the "frame size" .. (this is mostly to clarify for others that might read this thread... )
Liked 3,513 Times
Edit: By the way, I did put you on my ignore list. It will save me the trouble of reading your weirdly condescending posts in the future, .
Likes For bikemig:
Likes For Schweinhund:
Liked 3,513 Times
Bikes: a couple
Quoted: 563 Post(s)
Liked 869 Times
https://www.amazon.com/dp/B0B7L424X2
https://www.amazon.com/cyclingcolors.../dp/B07FH7CQ7P
Liked 3,513 Times
Do you need something different from this?
Garthr in post 4 hit the problem on the head.
Clark W. Griswold
Quoted: 4449 Post(s)
Liked 4,111 Times
I would look into high rise bars and maybe something with a little sweep back as the cheaper option and a better more reliable option is get a Cane Creek 40 in EC34/EC34 and a fork from Surly or really anyone who makes a threadless 26" fork and then you have standard parts and can get whatever is needed and that bike can go on for a long time. Plus with the new fork you might have more mounting options for racks and bottles and stuff sack cages and whatever else you need plus you might could find something lower travel (so you don't screw up the geometry too much) and get a little more comfort out of the bike.
I wouldn't faff about with adaptors and stuff like that. I would say check out Innicycle but their stuff is 1" only but It is the best solution to the problem of adapting threaded forks with modern threadless components.
Likes For veganbikes:
Liked 742 Times
Thanks but I know the difference. I'm familiar with the other things you talked about as well but you apparently didn't read what I asked about and why. A threadless adapter makes it easier to play around with different configurations.
PS... i posted a link to what you are "having trouble finding". i also tried to help your quest to raise the cockpit, and other responders offered similar advice.
Quoted: 546 Post(s)
Liked 479 Times
I'm still trying to figure out why a female with a long torso should be on a small frame and looking for a tall handlebar, when a larger frame with standard handlebar would offer better reach (if stand-over wasn't too huge - plenty of kids used to ride bikes they couldn't straddle, and most of them didn't die).
Zoom Q-5, is available on the US's most popular bike distributor(QBP), I'm sure someone will sell you one!
The Forte also looks fine.
Likes For cpach:
Likes For BTinNYC:
Quoted: 890 Post(s)
Liked 844 Times
I don't see the problem since the adapter you referenced should function perfectly. AFAIK, there are a couple of sizes (lengths). The combo of adapter, stem length/rise and bars should place your friend wherever she feels comfortable. However, I would not consider a shim.
Quoted: 430 Post(s)
Liked 713 Times
One thing I would NOT do is to shim a stem. To get a bar up higher, why not put a "BMX" bar on it. Many different heights available and you wouldn't have to change the stem. 25.4 bmx handlebars - Google Search
Likes For freeranger:
Liked 3,513 Times
Thanks, that's what I was looking for. My earlier search only turned up the Forte and I was curious what the heck was out there. And yeah QBP stuff is easy to find in a lot of retail stores/mail order places but for some reason this one did not turn up when I googled it. This is very helpful.
Liked 3,513 Times
Quoted: 522 Post(s)
Liked 455 Times
