How do I remove the freewheel from a 1973 Schwinn Collegiate wheel?
Quoted: 818 Post(s)
Liked 1,044 Times
Your best bet would be to bring it to a local bike shop. I have a lot of freewheel tools but I did not have the one for what I believe is your Schwinn/ Atom. I had to go to a bike shop that had the tool myself. Usually the older shops are better for this. If you go to a fancy new Trek store, they may not have the tool.
Is this from your Collegiate? Good luck.
Likes For Velo Mule:
Time Traveler
Bikes: 1983 Ross Paragon
Quoted: 207 Post(s)
Liked 100 Times
Likes For BikePower:
Time Traveler
Quoted: 207 Post(s)
Liked 100 Times
32,26,21,17,14
It is 22 mm inside diameter spline to spline
there are 20 teeth on the spline
Quoted: 6345 Post(s)
Liked 4,948 Times
It's not that difficult if you have the right tool. But the right tool for that freewheel is only going to work on that particular FW and maybe a few others. And if you replace that FW because the cogs are worn out, then the replacement FW will probably use a different tool to remove it.
That's why most of us would just take it to a shop if we couldn't figure out how to DIY our own tool.
Quoted: 3631 Post(s)
Liked 3,052 Times
Buy the tool and do it yourself if you want. It's only $40 bucks. Which would probably go a long way towards a brand new freewheel.
20 spline freewheel tool
Time Traveler
Quoted: 207 Post(s)
Liked 100 Times
https://www.google.com/aclk?sa=l&ai=...ECAUQEA&adurl=
Liked 3,052 Times
Search me. Buy it and see if it fits.
Quoted: 1632 Post(s)
Liked 2,723 Times
Schwinn does use the Atom freewheel remover.
Liked 2,723 Times
Looks a bit rusty. You may want to put the axle back on so you can lock the remover down while breaking it free.
Likes For curbtender:
Bikes: a couple
Quoted: 563 Post(s)
Liked 869 Times
are you sure it isnt this one?
EDIT: the entry on velobase
https://velobase.com/ViewComponent.a...4b3d3&Enum=114
Likes For Schweinhund:
Old fart
Quoted: 3617 Post(s)
Liked 3,454 Times
Yes, the Park FR-4 will work for the OP's Schwinn Approved freewheel.
N.B. some Schwinn Approved freewheels of that era were made by Normandy, and use a wider diameter tool, e.g. the Bicycle Research CT-3:
Likes For JohnDThompson:
Liked 3,052 Times
Time Traveler
Quoted: 207 Post(s)
Liked 100 Times
the park tool is only $8. but how much is the satisfaction of doing it yourself worth? its something fun to do and you learn something new. I saw this poor green 73 collegiate 5 speed and I dont know.. I just felt sorry for it and wanted to save it. ... If I spend $100 so what, its entertainment for me and I have somethign to show for it and talk about when Im done. I mean we all love bikes right? Besides Im going to put alloy wheels and hybrid tires on it, upgrade the brakes and maybe get rid of the stick shift on the stem and weld on a shifter boss on the down tube (heck I dont know).
Bikes: !982 Trek 930R Custom, Diamondback ascent with SERIOUS updates, Fuji Team Pro CF and a '09 Comencal Meta 5.5
Quoted: 1301 Post(s)
Liked 748 Times
Why are you wanting to remove that old thing anyway? That entire wheel is a great candidate to be made into part of a Hyundai Fender, or a toaster oven, IMO.
Likes For maddog34:
Time Traveler
Quoted: 207 Post(s)
Liked 100 Times
I have an FR-4 in front of me right now.. it WILL NOT WORK on your Rusty French freewheel... not the SQUARE Spline profile of the FR-4.. and then note the PYRAMID profiles of the spline notches in your French Freewheel. They are Very different.
Time Traveler
Quoted: 207 Post(s)
Liked 100 Times
Liked 748 Times
https://www.ebay.com/itm/27409613673...3ABFBMjo6fvMBi
Liked 748 Times
I want the original freewheel to use on an alloy wheel for this bike. Im throwing the old schwinn wheel away. I guess I dont need it but the 6 sprocket freewheel that is on the donor wheel from an old trek seems a little wide for the bike and the wheel is not centered in the bike. I think if I use the original 5 sprocket from the Schwinn then the wheel can be centered between the stays.
Liked 4,948 Times
New freewheels only cost about $18. Some less, some more. Depends on how good you are at searching the internet. No tool needed to mount them.
Likes For Iride01:
Time Traveler
Quoted: 207 Post(s)
Liked 100 Times
seriously? you were already shown the correct tool. and it's a FREEWHEEL
Liked 3,052 Times
Likes For smd4:
