How long to clean drivetrain and bike?
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2663 Post(s)
Liked 5,868 Times
Cleaning both seems to take an inordinate amount of time. Depending how anal I am, it will take 2 to 3 hours. Cleaning the drivetrain on the bike necessitates cleaning the frame and then we go down the rabbit hole. (I am not waxing the bike either).
If you do a thorough job, how long does it take you?
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
Bikes: 2021 Trek FX Sport 4, ~1996 Mongoose Crossway 4.50
Quoted: 96 Post(s)
Liked 1,360 Times
Maybe 30 minutes? I clean the bike every time I lube the chain. Mount the bike on the stand, then wipe everything down with Meguiar's Ultimate Waterless Wash & Wax and a microfiber cloth. Wheels and spokes are black, and I'll wipe them down too. I'll also reach inside the wheels and clean the hubs. Then I clean the chain using Simple Green and two toothbrushes squeezed together. Usually there is some caked on dirt/grease on the front sprocket and the derailleur gears, and I clean that off. Wipe the chain with a shop towel and lube it with T9. That's it.
I could probably use Q-Tips to fully clean the brake calipers, but I don't go that far. Just do the best I can with the microfiber.
I'll take 2-3 hrs to detail the car, but not the bike.
Mark
Mark
Quoted: 7680 Post(s)
Liked 3,570 Times
if you don't want to you don't have to.
Likes For Maelochs:
Quoted: 4561 Post(s)
Liked 5,084 Times
Thorough job - maybe 30 mins for a road bike. I use a Muc-Off chain scrubber and then dry and re-lube. Frame and wheels just get a quick wash in warm water and dry with a micro cloth. Minimal effort really.
Liked 3,089 Times
an invasive clean might include bearing services. 2.5hrs maybe? That's touching each nipple too.
-Oh Hey!
-Oh Hey!
Quoted: 523 Post(s)
Liked 684 Times
30 minutes without rushing, 20 if I'm pressed for time. I do it outside cause it's easier. I put it on a stand, take off the wheels and chain, spray with water, soap up with an all in one car wash/wax thing wash/wax thing working from top to bottom and rinse. Use a laundry brush for the drive train and underside with some degreaser and rinse that. Do the same to the wheels, then drop the chain in a juice/tea container with degreaser and shake the bejesus out of it, pull it out and dry it and hang it in the sun while I wipe down the bike and reassemble it.. Go back to the chain, spray lube it and wipe it dry and put it back on the bike.
I am potato.
Quoted: 1808 Post(s)
Liked 1,676 Times
The most thorough I ever do includes a tooth brush for dust on the chain and/or a similar brass wire brush at the cassette to remove any gross debris or flakes of wax. Probably 5 minutes of actual work if I'm superlatively thorough. Not that any such attention is warranted more than maybe once per season or so.
The chain goes in a preheated crockpot for 5 minutes, and get reinstalled at my convenience anytime after it has cooled enough to be stiff.
I wax my stainless steel Wipperman Sx chains when I hear "the rattle of pearls." So far they refuse to generate any measurable wear. So, maybe I am spending too much time fussin' over cleaning.
LR÷P=HR
Bikes: 1981 Holdsworth Special, 1993 C-dale MT3000 & 1996 F700CAD3, 2018 & 2019 Cervelo R3’s & 2022 R5, JustGo Runt, Ridley Oval, Kickr Bike 8-)
Quoted: 886 Post(s)
Liked 1,235 Times
I’m embarrassed to say how long a deep clean takes.
In my defense, bikes get this annually.
I'm a road cyclist in California and bikes stay clean. Although last weekends Metric (Tour de Fuzz) was in the rain & this is what happened the day after.
Chain off & in the ultrasonic twice (once in a ziplock bag with degreaser & once in the tank to flush it)
wheels off & cassette goes in the ultrasonic after chain finishes
bottle cages off & washed
Crankset off & cleaned by hand.
Take bike outside and blow out brake dust
Hand wash bike (inc. bar tape) & dry
Clean nooks and crannies with Q-tips
Wax & polish (2 coats)
clean wax from nooks and crannies, more Q-tips
Clean RD cogs (usually in-place)
wash tires, rims, hubs & spokes.
Lube & reassemble bike
All this in 15mins…. Honest!
Barry
Barry
Likes For wheelreason:
Quoted: 18529 Post(s)
Liked 15,883 Times
Liked 3,089 Times
they're a recumbent fixie though...
-Oh Hey!
-Oh Hey!
Quoted: 6330 Post(s)
Liked 4,922 Times
Likes For Iride01:
Bikes: Lemond Zurich/Trek ALR/Giant TCX/Sette CX1
Quoted: 603 Post(s)
Liked 853 Times
30 min or so. Right now, I'm taking care of my 2 main bikes, my sons road bike (he's 12 and helps) and his MTB.
Dry/ceramic chain lube really makes my life easy.
Some people will probably yell at this method - but it works for me.
I simply wet the bikes down, spray with simple green and let it sit for a few minutes. Rinse off with light spray - most of the grime is gone at that point. Then wash the bike with a microfiber cloth and dawn.
I let the drivetrain sit with simple green, scrub it with a brush, rinse/dry/relube.
About every 5 lubes or so, I take the chain off and soak in simple green.
"wet" lube - for me its a nightmare of gunk, build up and the stuff transfers all over the bike.
The Wheezing Geezer
Bikes: 1976 Fredo Speciale, Rivendell Clem Smith Jr., Libertas mixte
Quoted: 423 Post(s)
Liked 982 Times
When I clean my bike in the car wash, clocks run backwards!
It's the darndest thing.
Likes For Fredo76:
Quoted: 2629 Post(s)
Liked 1,979 Times
I use the bucket of warm water with Dawn and a good brush. "Thorough" for me means brushing the rims and tires, and the outside of all the spokes to get rid of rain ride dirt.
Getting everything together takes 15 minutes. Washing the bike is 5-10 minutes, depending on whether or not I get the rims. Next bike is 5-10 minutes again. Third bike I usually want to change the water.
Quoted: 7088 Post(s)
Liked 11,207 Times
Twenty minutes or so.
Edit: as it happens, today was bike bath day. (2-3 days in a row of riding on our incredibly dry and dusty gravel roads left the bike covered in dust and dirt, and a puncture on last night's group ride left sealant all over the rear triangle.) I timed it, and it was 17 minutes -- that includes filling the bucket with soapy water and also dragging the hose around to the driveway and putting it away when finished. Bike is now in the workstand, out in the sun, so the drivetrain can dry completely prior to lubing the chain.
Liked 11,207 Times
Likes For Koyote:
Grupetto Bob
Liked 5,868 Times
Amazed how fast people get it done.
What I do:
Run chain through Chain Pig device several times
Spray rear cluster with degreaser and scrub
Clean both front and rear mech - remove jockey wheels/ clean-lube
remove both wheels and clean wheels hubs and spokes
wipe down frame and bars with water and Dawn mix then rinse everything
reassemble bike and wipe down.
blow the chain completely dry using compressor
lube the chain
Do any fine tuning of mechs if necessary
If people can do all that in half an hour, my hat is off to them.
What I do:
lube the chain
Quoted: 1110 Post(s)
Liked 1,048 Times
10-15 minutes at most. Grab the windex, pull both wheels and spray the frame and wipe it all down toss each wheel in the truing stand, spin it and spritz it. Spokes get wiped first, then the rim between them followed by the hub. Rub the edge of the rag between the cogs if needed. If bored, spray the frame down with pledge for that lemony fresh scent and rewipe down, install the wheels. Lightly drip lube on the chain and after a minute wipe off the excess. I used to get lots of complements on my repairs being the cleanest customers had seen, gave them a sense that the bike had been thoroughly inspected, but with practice its a quick and easy job. its only 12.00 for the 50 pack of white cleaning cloths from HF, and windex really does cut through grease and leaves a cleaner looking finish.
Likes For Russ Roth:
Grupetto Bob
Liked 5,868 Times
Liked 5,084 Times
I’ve been down that rabbit hole and eventually came to the conclusion that it’s not really worth all the extra effort. So now I just wipe the chain down between rides and occasionally run it through my scrubbing device with de-greaser (once a month maybe). Chains are a fairly disposable item too.
Liked 1,979 Times
Pulling jockey wheels for cleaning seems pretty OCD to me. Kind of like how dog show contestants wash, blow dry, and comb the dogs all the time. I'll wipe jockey wheels off if I see any buildup on the wheels, but that's about it. (And wash a dog when it rolls in something stinky.)
Quoted: 511 Post(s)
Liked 651 Times
Likes For KerryIrons:
