Tandem travel cases
Tandem travel cases
About to purchase a coupled tandem. What are your thoughts/experiences on soft sided cases (ie the ones sold by Co-Motion,) vs hard cases (like the S&S cases?)
Thanks
Thanks
Bikes: Merlin Road, Rivendell Road, Arvon custom tandme, Hi-Light G-7
Quoted: 24 Post(s)
Liked 11 Times
My personal preference is for 2 hard cases. The main downside of using a hardcase for wheels is 700c wheels are a very tight fit into 26x26x10" case. We have since switched to 26" wheels which fits into the hardcases much easier.
Likes For scycheng:
26" Wheel conversion?
We have a 700c 2005 vintage coupled tandem with a carbon fork and rim caliper brakes. I could fit a rear disc, but not a front disc.
Quoted: 24 Post(s)
Liked 11 Times
Please forgive the subject drift: please tell more about the switch to 26" (from 700c I assume). Bike brand and model, brake type, any challenges in the switch.
It use to be a coupled 700c touring tandem which developed a problem with the captain's seat post clamp area. When I discussed the issue (cracked tube at the seat post), the builder, Arvon, suggested he make me a new frame since replacing the captain's seat tube and some other changes I was asking for will end up costing about the same as building a new frame for us. So I sent the old frame and wheels back to him.
So we went with 26" to get much more tire width as we were getting pinch flats riding on Canal du Midi towpaths using the widest touring tire I could easily find back then (Conti Top Touring 700x37) due to the big rocks along the way. We were getting so many flats, I ran out of inner tubes and patches. Had to get off the canal to find a bike shop.
One of the changes I wanted was to have an option to use either rim or disk brakes in the back. He rebuilt the wheels with 48-holed 26" Rhinolite and single butted spokes which has resulted in pretty bulletproof wheels. I have not yet needed to true them after about 10 years. As for tires, I am currently still using Schwalbe Kojak (26x50) though I should find replacements in the next year or 2 as I can't find them any more.
Now note this is a touring tandem so somethings are way overbuilt intentionally.
Thanks! Your setup is ideal for loaded touring, which we no longer do.
I run Conti Gatorskin 700x28 tires reliably 3 seasons for day rides. I would like a front fender, but it is out of the question with the current fork. Also, wider tires would smooth the ride on the roads in our part of rural Ontario; either chip-sealed or unsurfaced. A new tandem is not in the cards. So, I have wondered about a 26" conversion.
Happy touring!
Happy touring!
Quoted: 24 Post(s)
Liked 11 Times
Happy touring!
Happy touring!
[On my gravel single bike, I have 2 sets of wheels, 700c and 650b. The swap is straightforward is easy since the disks and hubs are identical between the 2 set of wheels and there is clearance between the fork stays and the chain/seat stays in the back.]
Re: the original post and question: I have the Comotion soft cases and have had no problems. As with any case, I use plenty of padding and reusable zip ties to minimize movement of contents in transit.
Ferengii
Bikes: Co-Motion tandem; Bilenky tandem; Trek Domane SL6
Quoted: 7 Post(s)
Liked 18 Times
We have hard cases and soft cases. I think the hard cases are less likely to allow damage vs soft cases. We’ve also travelled with BOTH a hard & soft case (then on destination arrival in Frankfurt put the empty soft case inside the hard case and shipped it to our end point in Prague - easier/cheaper than sending two hard cases). We watched as luggage was loaded onto our airplane and saw how they swung and tossed the cases around while loading - we were less concerned about the hard case allowing damage than the soft case. Some people claim that airport personnel handle soft cases more delicately, but that’s not what we’ve seen. The hard cases really hold the plastic compression members in place vs soft cases as well. The S&S website states that the hard cases provide the highest level of protection for your bikes - and I agree. HOWEVER, the soft cases are lighter than the hard cases - a key issue if you’re just over the 50 pound weight limit per cases.
I hope this helps!
I hope this helps!
