Riding out of the saddle difficulty
Bikes: Subject to change at any given moment but currently is...... Colnago Mapei, Colnago C40, Wilier Triestina Carbon, Wilier Triestina Ramato, Follis 472, Peugeot PX60, Razesa, Orbea Terra, Soma Pescadero and 1/2 owner of a Santana tandem.
Quoted: 342 Post(s)
Liked 788 Times
Want to ask about this technique as I’m finding it surprisingly exhausting and incapable of doing it for very long at all. I consider myself at least a moderately conditioned cyclist doing centuries a few times a year and around 200,000’ annual climbing numbers. At times that I try riding out of the saddle, it’s not long at all before I sit back down. I have specific points along a favorite route where I intentionally work on it but I’ll be damned if I can see any improvement.
Quoted: 4227 Post(s)
Liked 2,491 Times
Riding out of the saddle and standing on the pedals is like second nature to me. I find it very easy to do....Best way to become good at it is to climb hills while standing up, stand up when accelerating from a stop and riding singletrack trails which requires you to stand up a lot when riding over obstacles. The more you do it the better you become at it.
Likes For wolfchild:
Quoted: 526 Post(s)
Liked 693 Times
It requires more arobic capacity (as well as capable core and upper body strength and fitness) in order to climb standing for prolonged periods. I think pedal dancers are born, not made, though everyone can certainly improve somewhat. Larger heavier riders usually have trouble with it. Technique also has a lot to do with it, unless sprinting a short burst, one wants to use effort to align the feet (foot) over the pedal, and use body weight to apply power to the pedals, augmented somewhat by arms on the hbars.
Cheerfully low end
Quoted: 649 Post(s)
Liked 1,067 Times
Riding single speed helps me keep the necessary muscle tone and fitness. I also make sure my bike is set up so that it is suited to a lot of standing. So there will be some balancing of what is optimal for standing and what is optimal for seated riding.
Otto
Otto
Klaatu..Verata..Necktie?
Quoted: 10634 Post(s)
Liked 12,267 Times
I have always had difficulty riding out of the saddle for very long. I used to find doing just 10 pedal strokes was about as much as I was comfortable with. I've gotten better because of two things. The first is, I just intentionally worked at it, doing it more often on my rides, and for longer stretches. I count pedal strokes and set a goal, and I've found that keeping at it makes it possible to do it for longer.
The other thing was getting a smart trainer. Finally, I had power data, and what I discovered was that I tend to try to push too high a gear when I climb out of the saddle. So, let's say I'm doing a long climb at 225w. I get to a steep pitch, get out of the saddle and click up a couple gears, and now I'm pushing over 350w, and of course I tire quickly. But if I go one gear easier, and only push 300w, I can do it for longer and I don't feel blown up after. Basically, unless it's REALLY steep so you have to fight for every pedal stroke, an easier gear might help you carry on longer.
Quoted: 2626 Post(s)
Liked 3,174 Times
A Global Cycling Network video from a year or two ago had a bunch of their presenters start a very long climb together while attempting to ride out of the saddle for as long as possible (inspired, as mentioned at the beginning of the video, by Alberto Contador's habitual training practice of climbing out of the saddle for half an hour at a time).
Turned out that the presenters fell into two groups: taller and/or heavier cyclists, all of whom were strong riders but who were unable to stay out of the saddle for very long, and smaller, lighter cyclists, who had no trouble climbing that way.
At 5'8" or so and 120 lbs, I can climb out of the saddle for 10 or 15 minutes with no trouble, which gets me up the longest hills around here.
Likes For Trakhak:
NotaNewbie
Out of the seat
I run a Cross Country bike mostly because it is a 12 mile ride to get to my Single Track Trails. I have broken either my Seatpost or Seat twice on my off-road adventures. My last time I had to ride 14 miles standing up. I learned a lot about being out of the saddle. First, you need to shift up about 3 gears. This settles down your cadence, next bring your weight a little to the rear, and third is to get your speed up and glide the flat sections getting as low on the pedals as you can. I would recommend everybody do a standing up session on their ride. Talk about cross training, it is completely different in every way. Your muscles will burn and parts of you will complain. It is all for a better, more well rounded skill set on your ride. You will be a better rider and can handle situations you come across with experience and confidence. Like all riding, start a little, and practice up.
Likes For Jimriides:
Liked 12,267 Times
For fun and practice last night, and because I was on Zwift due to poor AQI, I was climbing the "Leg Snapper" in the "Innsbruck" world (0.27 "miles" at 6.9% average "gradient), going out of the saddle the whole way. I was carefully watching the watts and keeping it right around 300, and that took 1:46 or so each trip. That worked out pretty well - I made it to the top without being so gassed that I had to just coast.
Likes For genejockey:
Quoted: 6353 Post(s)
Liked 4,956 Times
IMO, riding out of the saddle is old school if we are talking about road bikes. I can climb better for longer in the saddle at 90-95 rpm. I just resort to standing when needing to get the last few strokes to crest the hill if I don't wish to shift to a lower gear. I'll let my cadence fall to where I can stand while pedaling. Don't know if I'll ever be able to do 90 rpm standing.
Standing takes more energy. It also takes different muscles or uses your muscles differently than when seated. So if you want to stand, then you are going to have to work at it. Start at a lower cadence than you would for climbing seated and build up your muscles and ability to stand and pedal at a higher cadence. I also find I seem to control the bike better if I'm in the drops while standing.
Liked 2,491 Times
Agree about singlespeed, riding SS or FG gives me no choice but to stand up and ride out of the saddle very often, if I didn't stand up I wouldn't be able to ride up hills.
Find a hill that you can run up, the steeper the better, and run up it without touching your heels to the ground. Then do the same thing on the bike.
climber has-been
Quoted: 3584 Post(s)
Liked 3,767 Times
Out of the saddle riding definitely gets easier the more you practice it. And it's a useful skill when the road gets steeper than your gears can handle.
On climbs, I get out of the saddle often, clicking up a couple of gears, pedaling slowly with a relaxed upper body. When done this way, it should be no harder than walking up stairs.
There is a tendency to want to push harder when out of the saddle. Try to avoid this, as it will tire you out faster. I like to watch my power meter to keep my effort in check.
Likes For terrymorse:
LR÷P=HR
Bikes: 1981 Holdsworth Special, 1993 C-dale MT3000 & 1996 F700CAD3, 2018 & 2019 Cervelo R3’s & 2022 R5, JustGo Runt, Ridley Oval, Kickr Bike 8-)
Quoted: 891 Post(s)
Liked 1,245 Times
A good dose of PT & I’m able to move them. Now trying to strengthen them.
I didn’t know it was even a thing, let alone I had it.
Barry
Liked 3,174 Times
As TerryMorse and Genejockey and a few others pointed out, it's best to fight the natural tendency to push much harder when you ride out of the saddle. I've been riding fixed-gear bikes as well as geared bikes a very long time, but it's only comparatively recently that I've had the sense to moderate my effort out of the saddle to where I'm pushing maybe 10% or so harder than in the saddle.
That's fairly easy to do with a road bike, but it takes concentration to keep from overdoing it with a fixed-gear bike. The best trick I've seen for that was shown to me by a racer friend of mine years ago, when he demonstrated what he called "skateboard climbing"---leaning and lunging the bike sharply to the left and then to the right.
On a mild enough incline, he was able to make his way up the hill without pedaling.
That can be adapted to fixed-gear climbing---lunging left and then right with each pair of pedal strokes. Less forward progress per revolution, but (or therefore) lower climbing effort.
Liked 2,491 Times
Who cares if it's old school and who cares if it uses more energy ?....I actually enjoy riding out of the saddle when climbing , it provides a great full body workout and I also believe it saves the knees from too much wear and tear... if I didn't enjoy this style of riding I wouldn't be doing it. I can't imagine being glued to my saddle for an entire ride and never standing up.
Liked 4,956 Times
However, if one is lacking the energy to stand but can make it up the hill seated and spinning a good cadence even at 4 mph, then maybe they'd care at that moment whether which uses more energy.
Likes For Iride01:
Cheerfully low end
Quoted: 649 Post(s)
Liked 1,067 Times
There are steep short climbs I do and sometimes I do them at about 1000 watts. Seated is the only way I can do them at that rate on my single speed. I start to push myself out of the saddle but I’m starting from seated because higher cadence is needed than I can manage standing. If I want to take it easy, I climb those same hills standing.
Note: the considerations are different for a multi-gear bike versus SS.
Otto
Likes For ofajen:
Quoted: 526 Post(s)
Liked 693 Times
LOL. We used to do laps around a military base that crossed a taxiway for the airfield and had a stop sign at the crossing, of course we blew by it after checking for planes until the CMC got hold of it, and the CO said we had to put a foot down then we could proceed, didn't slow down any, but did have to change a cleat more often....
Quoted: 526 Post(s)
Liked 693 Times
Likes For wheelreason:
Method to My Madness
Quoted: 2068 Post(s)
Liked 1,561 Times
But the odd thing is, I can climb out of the saddle better (i.e., > 10 pedals strokes) on my hybrid bike with flat handlebar and flat pedals. I wonder why?
Bikes: One of each: Road, Hybrid, Trekking
Quoted: 137 Post(s)
Liked 115 Times
Cheerfully low end
Quoted: 649 Post(s)
Liked 1,067 Times
It’s more complex to really understand the dynamics of riding out of the saddle because you have all the joints in play and many adaptations are possible.
If you ride SS or FG for a while, you will learn the little adaptations that help reduce the instantaneous difficulty and stress of climbing and riding into headwinds when the single gearing seems high. You will also develop additional strength that allows comfortable and stable pedaling at low cadence with significant pedal force.
Single gearing will push you close to your limits in ways that multi-gearing would allow you to avoid except perhaps on the steepest climbs. This has some positives for strength and fitness. OTOH, it has negative consequences for maximizing speed and overall power output and reduces sustainability on long multi-day rides and races.
Otto
Quoted: 7713 Post(s)
Liked 3,645 Times
^Everyone I know who had knee replacement (s) came back and rode strongly (assuming they rode before.) I never asked about climbing in or out of the saddle.
Likes For Maelochs:
Liked 2,491 Times
