Sora or Claris, Beginner Road Build
Quoted: 193 Post(s)
Liked 37 Times
Hey all. Accepting all opinions: I'm building out a "first" road bike for my 16 year old son. He likes biking and has a basic entry road bike with the old lever gears. But he isn't gung-ho about it. His interest is growing, though. I obtained a like-new Fuji aluminum frame with carbon fork for $110. I'm blown away by how nice it's made and how light it is. I now have to fit a groupset to it. I had been planning on a Sora groupo. We live in a desert with no hills. Essentially all flat. I run a 105 on my bike and find that I never use more than 4 gears. But the 105 is super smooth and the brakes are great (rim.) I can get the Sora for about $430 new and complete. But I just found a new Claris set for all-in at $275. I don;'t want to be cheap and can afford the Sora, but I like to watch my pennies. With this info, will the Claris be fine for his uses; allow him to do all the things he may want to do? He's not going to race. I just want a solid ride for him to get into. Or should I just jump for the Sora right now? I have it on one of my bikes and it's a nice set-up. One thing I found are opinions that the Claris rim brakes are actually a bit better than the Sora brakes. So that's a plus in the "safety" department (if accurate.) Thanks for your input everyone!
Sunshine
Quoted: 11068 Post(s)
Liked 7,634 Times
My oldest, now 19, has had a Claris rim brake road bike for 4 years now. In the first 3 years she rode it over 5000mi, did 7 or 8 centuries thru those years, and trained for an Ironman with it. The drivetrain is perfectly fine, its dead simple to set up and maintain. The only downside is its heavier and uses some steel where higher levels use aluminum or composite. Basically, there is some spot rusting on bolts or a couple sections of the derailleurs. It doesnt impact reliability or performance at all.
We have a bike with Sora- its fine. Same things- dead easy to maintain and is heavier than more expensive groups.
We also have a road bike with older 105 9 speed and one with older Tiagra 9 speed- the Sora bike shifts just as fine and has lasted years without issue.
I would use any of the groups for a kid that isnt racing and not think twice. Whichever you buy, just get some quality cables and housing plus quality brake pads. Those things can be felt.
Over the hill
Quoted: 1016 Post(s)
Liked 1,246 Times
Personally, I would go with whichever is cheapest since there's a good chance he will want to upgrade if he really gets into it, and probably won't care if he doesn't really get into it.
It's like riding a bicycle
Quoted: 193 Post(s)
Liked 37 Times
Thanks guys. I'm reminded of something I read online. The poster said something like, "today's cheap groupsets are better than the sets that the pros were using in the Tour de France 20 years ago." In that regard, I saw a really decent looking used Ultegra set on sale at Ebay for less than $200. But it's over 20 years old! Looks good though. So, I'm thinking the Claris is the way to go, especially since he probably won't be using more than a few gears on our totally flat roads. The only challenge I didn't consider is that I got him nice used Dura Ace rims. A bit older, but in great shape. The rear has a 10 speed hub. New Claris has an 8 speed cassette. I'm assuming it will work. Any advice in that regard will be appreciated.
Quoted: 10303 Post(s)
Liked 5,276 Times
If you look hard enough I am positive you could find 105 rim brake for less than 500.00. Hell I bought one last year new for 650.00 and that was before 105 Di2 was released.
Liked 5,276 Times
Quoted: 687 Post(s)
Liked 456 Times
Quoted: 1864 Post(s)
Liked 1,732 Times
A few years ago, some Dura Ace wheels had alloy freehubs with deeper splines. If your wheels are those, 8 and 9 speed cassettes won't fit
Likes For alcjphil:
I’d argue to actually throw in the extra bit for 105, rather than the other direction. $450 for Sora seems high, and as bampilot points out, 105 can be had for under $500. The benefits:
- if he’s into it, he’ll have no reason aside from vanity to upgrade
- You’ll have a bike with parts that are completely cross-compatible. Need a wheel or any drivetrain component? Borrow it from the other bike, no worries about 8, 9, 11 speeds and chains
I think one of the upsides of Claris over anything higher up the chain is that fewer cables are hidden, which makes maintenance just a little easier.
Quoted: 687 Post(s)
Liked 456 Times
Quoted: 3261 Post(s)
Liked 2,578 Times
If you have to get the STIs separately, then get Microshift STIs. You won't have to whack the brake lever to shift ever again.
Other DA Hyperglide splined cassettes should all be 8/9 speed compatible.
The R2000 & R3000 series of components are very similar in many ways, many of the parts are the same. No way to really know if the build/material quality is different.
For the shifters, they both have under the bartape cable routing for both brake & shift housing.
You mentioned brake differences, they are identical.
Should Be More Popular
Quoted: 22732 Post(s)
Liked 9,101 Times
Bikes: SL8 Pro, TCR beater
Quoted: 1027 Post(s)
Liked 595 Times
Seems like you could get a 105 grouspet for the price you want to pay. That's what I would do. Long term wise, it's better. Groupset of the people for the win.
Going down from 105 to Tiagra, down to Sora and Claris... you don't get that big of a gap. Truth be told, Claris and Sora are really designed for manufacturers to realize savings at-scale. They're not bad components, by any means - but by the time an individual tries to buy a groupset from an LBS or even an online store, the costs of warehousing, labor just to pack the pieces, shipping, not to mention an reasonable profit margin - will quickly eat into the savings, as those costs are going to be pretty much the same, regardless of the groupset level.
Bikes: 2015 Felt Z75 Disc, 2008 Fuji Cross Comp, 2010 Trek Navigator 1.0, 1974 Raleigh Sports, 1974 Schwinn Le Tour, 1981 Schwinn Super Le Tour, Surly Cross Check, 2021 Giant Talon 2
Quoted: 206 Post(s)
Liked 71 Times
Both are reliable, but I think Sora shifts noticeably nicer. I'd go with Sora.
check out the Frugal Average Bicyclist
Frugal Average Bicyclist – The goal here is to help you keep cycling on a budget.
Likes For BikingViking793:
For the OP the issue with using 105 that is 11 speed is that the cassette that is included would probably be the standard 11 speed version, and would need a 11 speed compatible freehub/wheelset. He says that he has wheels already that are 10 speed.
So, a compatible cassette would need to be added, or a freehub body swapped. Duraace freehubs/wheelset are usually not easy/cheap to do a freehub body swap on, if even possible.
I think so too. I had one of each for awhile and buying the Sora bike made me feel like I'd found the best bike in the world. But the Claris bike was certainly a decent bike and I put a ton of miles on it with no issues.
Bikes: 2022 Salsa Beargrease Carbon Deore 11, 2020 Salsa Warbird GRX 600, 2020 Canyon Ultimate CF SLX disc 9.0 Di2, 2020 Catrike Eola, 2016 Masi cxgr, 2011, Felt F3 Ltd, 2010 Trek 2.1, 2009 KHS Flite 220
Quoted: 4435 Post(s)
Liked 3,064 Times
Too much focus on groupset is a newbie tell. Treeing up the wrong bark.
Quoted: 1110 Post(s)
Liked 1,050 Times
The last bike I had for a kid with claris I could never get it to stay shifting well for any length of time, really have no good feelings towards the set. When I checked yesterday ribble.com had 7000 series 11 speed really cheap for the shifters, front der and brakes, sub in the non-series 510 crankset. Get an 11-34 11sp mtb cassette to fit your 10sp wheels and you'll have to find a rear der but the shifters, crank, brakes and der were only a little over 200.
Liked 2,578 Times
True. I've never understood the need for a complete matching groupset. Some things have to match, but not all. I'd check the Bay/CL/local FB market place first and see what I could get there. A lot of people are unloading slightly used components/groups there because of upgradeitis.
Liked 595 Times
Sunshine
Liked 7,634 Times
Thats hardly too much focus or a newbie tell. It's just someone who doesn't have experience with entry level stuff asking how different tow options are.
Quoted: 458 Post(s)
Liked 490 Times
With respect to the statement "modern entry level > vintage top level", it makes some intuitive sense but all my bikes are still on SRAM 10 speed and I've never felt compelled to replace them with modern Claris or Sora. I've always built my frames up with lightly used parts because that's what I can afford, but I do get that there's a certain sense of satisfaction building a frame up with all new components. Before I converted to SRAM 10 speed I've ridden Shimano Tiagra and Ultegra. The only time I rode a Sora was on a rental about 14 years ago and it was just fine.
