extending a shift cable
Like the title says, the shift cable some some routing through the bike frame so I don't want to remove it. I think to remove it would also require me to remove the mid drive motor.
What's the best way to extend or add on to it? I'm thinking just cut a piece of shift cable and use electrical shrink wrap to hold it.
Quoted: 7089 Post(s)
Liked 11,208 Times
Bikes: There is always room for one more.
Quoted: 190 Post(s)
Liked 399 Times
Cable splitters for S&S Coupled travel bikes
You can probably find other options as well with a two minute Google (or your favorite search engine) search.
Don
Don
Quoted: 1000 Post(s)
Liked 1,679 Times
I have never had great success splicing a bicycle cable to lengthen it. I have tried though. It always looked super BAD. Just get yourself another cable...
Youtube: Incredible Huge Rope Splicing & Fabricating Process - Amazing Factory Machines Production Technology
Likes For zandoval:
Bikes: Trek FX 7.3, Specialized Roubaix, Orbea Terra, Aostimotor S17 ebike, Huffy RedRock (first bike)
Quoted: 225 Post(s)
Liked 345 Times
some internal cables are easier to route than you think, just make sure your string is good quality and securely attached to the cable you're removing.
Quoted: 3261 Post(s)
Liked 2,576 Times
If you do end up needing to buy another cable/housing, get one for a tandem. It will have the added length you need.
Likes For seypat:
Cantilever believer
Quoted: 564 Post(s)
Liked 1,947 Times
One tip I discovered here on BF is to use the old cable as a fish wire, cutting any ends off the old cable and connecting the old and new cable with a length of thin (such as 1/16" I.D.) shrink tube long enough for good grip as it's pulled through. Worked great for me on my most recent attempt.
Likes For RCMoeur:
Mother Nature's Son
Quoted: 860 Post(s)
Liked 1,454 Times
You can get housing end caps that are one unit, but open at both ends with a separator in the middle of the cap, ergo, you need two pieces of housing of the correct lengths. Or, you can use two housing end caps with the closed end back to back, and the same with two pieces of housing. The cable runs straight through either option. With the back to back caps, you could wrap them with tape of the same color, but it is not necessary. Either way, can be seen only from close up. They work just like the cable stops on the frame.
Using just tape to splice the housing together will work, but not work that well. the connection just is not stiff/strong enough, IME.
Quoted: 523 Post(s)
Liked 231 Times
If you are not fussy and want to use one of the more expensive housing brands like Jagwire or Shimano, standard cable housing is pretty inexpensive bought online. I'm still working with a 25 foot roll of shifter cable purchased from Nashbar more than a decade ago. This happens to be a source located one town away who sells on eBay.
12 foot roll of 5mm shift cable $16 postpaid https://www.ebay.com/itm/291917358195 same company 25 foot roll $25 postpaid https://www.ebay.com/itm/391259402350
Sheldon Brown (or John Allen) says splicing a cable is easy and does not require any extra hardware:
https://www.sheldonbrown.com/heroic-repairs.html
scroll down to the "splicing cables" section
Cantilever believer
Quoted: 564 Post(s)
Liked 1,947 Times
I've used shrink tubing for this purpose (over the back to back ferrules) with good results.
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3926 Post(s)
Liked 6,574 Times
I have a bike with a thru-frame rear brake cable routing. Nearly the entire length of housing goes through the top tube. The way I replace the housing is to leave a headless brake cable in there all the way through while pulling out the housing. Then reverse the process to install new housing. I keep the headless cable in my tool box just for this operation.
Quoted: 523 Post(s)
Liked 685 Times
Quoted: 2736 Post(s)
Liked 490 Times
Do you have a little metal (pref aluminum) cylinder? Could drill and tap a hole on either end of it and use socket head set screws to grab the cable. 4-40 screw should be plenty strong. Simple, strong, and elegant, but you’d need the tools
A quicker way could be just tie a knot. I doubt it would work but you could try, it’s probably what I would do just to see if it works.
I agree rerouting it seems like a *****
another option could be to get a nice zip tie, and use a lighter and a needle to poke two holes through it, tie the zip tie to itself. Thread the housing through the melted holes and then figure out how to make the end bunched up so it can’t fit back through the melted hole in the zip tie. One looped knot and some glue so the loop doesn’t slip out should work fine. The zip tie is acting like a shackle, it would probably hold honestly.
Liked 490 Times
señor miembro
Liked 6,574 Times
Quoted: 2514 Post(s)
Liked 752 Times
Good Lord, 20 posts. My newest bike has internally routed cable but I haven't had to replace it. I didn't realize it was this hard. Maybe it is, maybe it isn't, but I have to think Park Tool or Sheldon Brown or some other technical authority has a best practice tutorial in one of the usual places. If I had to do it myself I would already be on it. Let's get this thread notched up to #useful status and find a peer reviewed authority to post a link from.
Edit: A start? <shrug>
Liked 490 Times
Cool internally routed cables, Sheldon Brown was posted and it looks like he just tied another cable to it to extend it lol. Its what I would have done but Im surprised it works
Mother Nature's Son
Quoted: 860 Post(s)
Liked 1,454 Times
I have replaced internally routed cables/housing once on my Orbea Avant. I bought the Shimano routing tool, but, after doing the work, I realized I could have done it without the tool with no more time and hassle involved. I dreaded doing it the first time, but I am pretty sure if/when I do it again, it will go a lot quicker. I believe different manufactures use different techniques in the routing, ergo, there will be some differences in the replacement process. It seems likely to me that frame sets with oversized tubing make it a bit easier.
Likes For delbiker1:
Quoted: 249 Post(s)
Liked 473 Times
I use the cable as a guide, sliding the housing out of the frame leaving the shift/brake cable intact then sliding the new housing up the cable. I don't worry about the length at that moment, only that it extends beyond both ends of the frame, then I remove the cable and size the housing cutting it to the correct length. I then install a new cable and voila I'm done.
Quoted: 523 Post(s)
Liked 685 Times
Likes For wheelreason:
Advanced Slacker
Quoted: 2764 Post(s)
Liked 2,543 Times
https:/jagwire.com/products/small-parts/connecting-junction-ferrules
Don’t even need to tape it if you don’t want to. Had one of these on hand when running the cables for my commuter. I did not have any housing runs long enough for what I needed and this worked great.
Likes For Kapusta:
