Very bad BB problem. seized and broken teeth.
Quoted: 10 Post(s)
Liked 8 Times
I have a tandem (Bike Friday) with a bottom bracket that was clearly seized with rust. When I took the bike apart there was water in the seat tube, so must have been standing water above the BB. I soaked the whole operation in PB Blaster and let it sit. Clamped the frame down to the bench and tried to free the BB nut on the drive side. Non-drive side was easily loosened. But on the drive side I had to try increasingly longer cheater bars. Thought it was moving but instead the teeth for the removal tool tore their counterparts out of the BB. So I can free the non drive side, but the drive side has absolutely nothing to grab onto and it's hopelessly seized. Any suggestions?
Quoted: 4239 Post(s)
Liked 3,976 Times
Did you turn the tool/cup in the correct direction to loosen? (The common Eng BB thread direction for the drive side is left hand, not right handed).
There's a similar thread here Getting medieval on an adjustable cup. Ideas? - Bike Forums Once one cup is removed working on the frozen other one becomes vastly easier. Clamping methods (I have both the Kingsbridge and the UBI cup vises which are commercially made versions of the Sheldon Brown design) that install in the BB shell and grip the cup via it's end wall are able to be tried and the next step of grinding away a section of the cup is assessable too. Andy
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
Bikes: 3Rensho SuperRecord Export, Bridgestones MB1 RB1 XO2, Colnago Super, Medici GranTurismo, Schwinn Paramount, Olmo Competition, Raleigh Portage, Miyata 1000, Stumpjumper, Lotus Competition, Nishiki Maxima, Panasonic DX6000, Zeus Criterium
Quoted: 31 Post(s)
Liked 91 Times
post a photo and some BF members will weigh in with some possible creative fixes
Clark W. Griswold
Quoted: 4523 Post(s)
Liked 4,229 Times
Huge +1 on the turning of the tool. Also something that can help before it is stripped out is an impact gun, I wouldn't use it for a tightening role and wouldn't use it too often for loosening but it can really help on those tough ones. Most people probably would abuse it so be wise it is not really a bicycle tool but can be really helpful in these small instances and then for the future put plenty of grease in there.
Bikes: old ones
Quoted: 26482 Post(s)
Liked 10,449 Times
Quoted: 4629 Post(s)
Liked 1,776 Times
I think figuring out if it was being turned the wrong way or not is a pretty good first step.
aged to perfection
Quoted: 869 Post(s)
Liked 1,310 Times
The tool is an imitation of a $40 shop tool that fits into the fixed cup as a crank spindle would, and pinches the cup. You apply unscrewing force to the tool, and it transfers this force to the cup with this tight friction fit.
The tool consists of a large bolt, a nut or two, and a few washers. The size of the bolt is not particularly critical, as long as the bolt is strong enough not to break, but small enough to fit through the hole in the cup. I used to use an ordinary 1/2-inch, 13 TPI hex bolt (also called a "cap screw"), which served me well for quite a while. It finally met its match on friend's Schwinn that had an unusually tight fixed cup; the bolt snapped in two before I could remove the cup.
Now I use a 5/8-inch 18 TPI hex bolt 1 1/2inches long, with a nut, a flat washer, and four lockwashers. The 5/8-inch size is the largest standard size that will fit through the hole in the cup. This bolt and nut both take a 15/16-inch wrench. With my 1/2 inch drive Craftsman six-point socket set, the 15/16-inch socket is also the largest size that will fit into a normal bottom bracket shell.
If you have some other brand of socket, check the fit before you buy the bolt and nut-you might need the next size down (9/16-inch).
Liked 1,776 Times
The OPs description sounds very much like a Shimano cartridge bb with a spline cup tool. So the spindle is not going to be coming out for cup access.
Quoted: 1012 Post(s)
Liked 1,712 Times
Don't forget to try freezing it too...
Or use a can of Liquid Air by just turning it upside down.
Oh... Here's another one... My nephew was trying to replace the cups on an old Peugeot Mixti. That right side was stuck-STUCK! Right before giving up, and knowing it was reverse threaded, he tapped the cup's hole for a big bolt and put an impact driver on it. He said after three knocks it spun right off...
SE Wis
Quoted: 2756 Post(s)
Liked 3,427 Times
With the NDS cup removed, pounding/pressing on the spindle will either push the spindle out of the bearing or the bearing out of the cup.
This isn't a Shimano but they're all built pretty much the same.
Liked 1,776 Times
OP states the NDS will come out. A cartridge can be disassembled. it's not like they are 1 piece units. They were put together, they'll come apart.
Dunno what the OP actually has, but I think it would be better to wait for that information, and the information about removal direction and frame model before advising him to hit the spindle with a hammer or weld stuff.
SE Wis
Liked 3,427 Times
Here's a Shimano. Some did have removeable DS cups, most do not. It is just part of the body:
Quoted: 536 Post(s)
Liked 701 Times
It's a section of the body. Still not 1 piece. But yes, it'd be nice to see a photo of what they're actually working with.
https://youtu.be/Aa5RNxyOdsU?t=356
SE Wis
Liked 3,427 Times
The point was that a cartridge can be disassembled in situ if the option of working to remove the DS cup without the spindle in place made sense in the proper situation.
As has been mentioned, we don't have enough information from the OP to discern exactly what they are working on, and if that would make sense. A situation like careful destructive removal of the cup.
Liked 1,776 Times
Bikes: old ones
Liked 10,449 Times
Liked 1,776 Times
1. Which direction did you turn the drive side cup?
2. What brand and model crank is it?
3. What brand and model bike is it?
Quoted: 996 Post(s)
Liked 596 Times
I saw the title of this thread and thought a seized bottom bracket led to some dental injuries!
Likes For sweeks:
Quoted: 10 Post(s)
Liked 8 Times
https://www.bikeforums.net/g/user/548708/photos
Photos in this album.
I think the original diagnosis is right: turned the cup the wrong way. Sheared off the teeth. So now what?
Quoted: 1167 Post(s)
Liked 1,847 Times
I would clamp the tool in and try the correct rotation
Liked 1,776 Times
Anyway, if the part that sheared off is black plastic, hammer the spindle out toward the left and then grab the cup with whatever and turn it out. Or cut it out.
That is, after trying to simply turn it out as Mr. 66 suggests.
Likes For Kontact:
