Threaded Headset Tool Options for 33mm/34mm Locknuts
I've got two bikes with mid 80's Tange Sekine headsets:
1986 Miyata 210 (33mm Locknut). This was a $150 CAD bike but I've sunk several hundred more into it since purchase (wife's vintage ride).
1985 Norco Avanti (34mm Locknut + small diameter three notch threaded spacer). TH-235. This is a $60 bike.
My Park tools won't cover me for this work unfortunately. And my stack heights are small-ish.
So I seek recommendations. Ideas that I've come up with based on my research to date:
1) Swap the existing headsets -- or at least the tops of them -- for the new Tange base model which uses 32 mm locknuts.
2) Buy a Hozan small diameter hook spanner tool and wrenches for 33 mm / 34 mm. Finding reputable wrenches at a reasonable prices is proving very difficult. I also don't love having to retain tools that are only useful on two of my family's twelve bikes.
3) Buy a Hozan small diameter hook spanner and an adjustable Hex wrench. Like everyone, always, I've not enjoyed using crescent wrenches on my hex nuts. Is there any reason to expect the adjustable hex wrench thing to be better?
Recommendations?
Recommendations?
Quoted: 568 Post(s)
Liked 425 Times
I work on these kinds of old bikes all the time (mostly curb finds) and I have the right tools. I never use "poor mans" adjustables.
I'm not going to give crappy curb finds new headsets.
At least good tools I have to buy, I get to keep after I sell off the bikes.
Thanks for your response. Can you point me to where I might find these "right tools". I'm not opposed to buying the right tools. I simply cannot seem to find them at 33 mm / 34 mm.
If new headsets would wind up cheaper than than the tools, I'll probably go with the new headsets. I'm all vintaged up at the moment and I don't anticipate any additions unless it's something super special. Now that I've encountered this, I would also measure the headset locknuts on any future acquisitions before committing and factor that in.
Quoted: 4585 Post(s)
Liked 1,740 Times
I don't get you objection to an adjustable wrench. That is the defacto locknut wrench shop mechanics use.
Is there a particular wrench that you've had good experiences with? Amazon has three versions, in order of price (CAD):
Max Power @ $29
Rigid Tools @ $58
Milwaukee Tool @ $58
All seem to be rated about the same. That said, I imagine that bicycle work is not the most common usage for these things.
SE Wis
Quoted: 2755 Post(s)
Liked 3,426 Times
For about $25 ea you can put a new Tange Levin in. They are my go to on older, short stack bikes. Cheap, reliable, comes in JIS & iso
Don't always think you need bike specific tools either. I've bought numerous hook spanners at yard sales that were from other applications.
https://www.amazon.com/Mdvora-Coilov...dc19cdf73&th=1
Likes For dedhed:
Quoted: 4236 Post(s)
Liked 3,963 Times
I would get replacement 32mm top nuts and a few spacer/washers and get rid of the notched lock ring. Even with a HKC "Rock Ring" wrench, working these headset notched rings is a pain. Andy (who has a 15" adjustable wrench and is not afraid to use it)
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
Bikes: !982 Trek 930R Custom, Diamondback ascent with SERIOUS updates, Fuji Team Pro CF and a '09 Comencal Meta 5.5
Quoted: 1302 Post(s)
Liked 749 Times
put tape on those black locknuts to protect the finish...
a quick search and the 5th option opened presents...
https://toolsandmore.us/shop-fox-x17...0ff08c6f87f2a5
i'd imagine a similar 34mm version is out there, somewhere... a 1 5/16" wrench will be slightly under 34mm, and a 1 3/8" will be slightly over 34mm........ i'd get the 1 5/16 and grind to size....
or just swap out those pesky odd jam nuts, since, being a co-op person, i have a 6"x 14" bin of those sorts of things.... (hint)
as to the hook spanner... you can never have enough, or find the one you know you had at one time, many decades ago....
try taping and old channel lock pliers...?
Quoted: 3634 Post(s)
Liked 3,062 Times
My headset locknut is mirror-polished aluminum alloy, the surface of which is no doubt considerably more fragile than your black locknut. I used an adjustable (“Crescent”) wrench, using electrical tape on the jaws, to tighten it.
Thanks all. This should give me enough information to be able to make an informed decision.
Follow up question: are threaded headsets kept from coming loose by the torqueing of one of the threaded elements against another? So grease the steerer tube threads and, ideally, do the torqueing with a pair of wrenches worked in opposition?
Liked 1,740 Times
I'm not sure if you were referring to me but it's less of an objection and more of an inquiry. Purpose made headset wrenches have worked great for me in the past. Crescent wrenches... obviously not, especially on black locknuts. Not having tried an adjustable hex wrench, I wasn't sure where that would fall on the continuum. If the use of such wrenches is common practice, that will be an attractive option for me.
Max Power @ $29
Rigid Tools @ $58
Max Power @ $29
Rigid Tools @ $58
I would consider Rigid, but I don't think it matters. The other two aren't known for wrenches. Go to Lowe's and buy whatever is on sale. "Crescent" is a brand. So is "Channel Lock" or "Erwin". The one I have been using for 35 years is marked "Popular Mechanics", works perfectly and still looks new. Speaking of which:
https://www.popularmechanics.com/hom...cent-wrenches/
Personally, I looked for a wrench that would open wide enough to also work on the 36mm locknuts of 1 1/8" threaded headsets, but those might not be something you care about.
Bikes: old ones
Quoted: 26481 Post(s)
Liked 10,448 Times
.... If the use of such wrenches is common practice, that will be an attractive option for me.
Max Power @ $29
Rigid Tools @ $58
All seem to be rated about the same...
Max Power @ $29
Rigid Tools @ $58
...far and away the best adjustable wrenches for headset lock nut is made and sold by Channellock.
They come in 6", 8", and 10" and 12" versions. I've had pretty good luck using either the 6" or the 8" (refers to overall wrench length.)
They are a little pricey, even on Amazon. But they work much better (less slop, thinner jaws, closer tolerances) than any of the others I've tried.
Liked 3,062 Times
Yes. Use a headset wrench to keep the lower cone stationary and use the adjustable wrench to tighten down the locknut.
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3936 Post(s)
Liked 6,619 Times
Alas, modernity runs further and further away from this concept.
Mad bike riding scientist
Quoted: 6276 Post(s)
Liked 4,303 Times
And towards better and better connections. Threadless headset solved a very big problem in terms of headsets…that of loosening headsets, particularly in mountain bikes. The jam nut concept works but not in situations where there is a lot of vibration. Loosening headsets was such a problem in the early 90s that there was a very large cottage industry making locking mechanisms to replace the top nut on threaded headsets. There were dozens of different approaches.
Threadless solved that issue with a better simple machine.
Stuart Black
Stuart Black
Liked 4,303 Times
These kinds of headsets are particularly finicky since there are 3 parts that need locking…the lower race (which also locks against a toothed ring), the middle nut that is adjusted with the hook spanner, and the top nut. And, to make matters worse, the headset has a brake cable hanger that interferes with use of the lock ring spanner. It’s a bloody nightmare!
Stuart Black
Stuart Black
Bike Sorceress
Bikes: Yes
Quoted: 62 Post(s)
Liked 123 Times
For the headsets in question, the Hozan lockring wrench should work just fine for the lockring, and is probably the best quality tool for the purpose. For the top nut, adjustable wrench does the best job, the Channel Lock ones are great. I usually use a vise-grip for the lower part, though you have to be careful not to use it too tight or you will chew it up a bit. The purpose made pliers haven't really impressed me, it is difficult to grip them tight enough, which also chews up the lower part some.
For the headset with the cable hanger, it will likely be easiest to adjust it with the brake unhooked, top nut all the way undone, cable hanger slid up out of the way, get the adjustment set with the lower part and the lockring, then bring the cable hanger and locknut down and lock them in place.
Liked 749 Times
interesting... not one mention in this thread of the TABBED WASHER or TABBED brake cable hanger.... they can and do negate the need to use a hooked spanner on the top cup...or nut.. or whatever someone calls it.... the notched nut cup. Yah.. we'll call it that! It's the HoliDaze, anywayz.
hmmmmm... how odd... has the tab been wiped off the washer? happens way too often..... one headset features the tiny toothed terror, the multi position tabbed lockwasher... which also depends on a TAB into the slot on the Steerer tube........ shades of old ralieghs and french creations....and a day in the Vinegar bath.
aka: Dr. Cannondale
Quoted: 2172 Post(s)
Liked 3,517 Times
If you can locate two lengths of mild steel, cut an appropriate sized notch in the end to fit your 33/34mm nuts. They don't require a whole lot of torque and you might be able to get the steel for free- 8" by 2" scraps would work fine.
Quoted: 862 Post(s)
Liked 1,105 Times
Or, make your own notched lockring tool that can be used on various sizes. DIY Lockring Pliers : 3 Steps (with Pictures) - Instructables
Liked 1,740 Times
This type of headset was designed to not need a pair of pliers to tighten. The knurled cup is adjusted by hand, then the lockring and top nut are tightened to each other to prevent the cup from loosening. Don't mar up your headset with a tool it wasn't built for, unless it is frozen from rust and looks like hell already.
And never rely on a tabbed spacer to hold torque. They are there as a tightening aid, that's all.
Likes For Kontact:
Liked 4,303 Times
Stuart Black
Stuart Black
Liked 4,303 Times
Stuart Black
Stuart Black
Liked 4,303 Times
Stuart Black
Stuart Black
señor miembro
Liked 6,619 Times
And for $15 shipped, you can buy a brand new, proper headset in the Tange Passage. It looks great and has a low stack that will fit on almost anything.
https://www.ebay.com/itm/223220754810
I installed one on this '80s Falcon a couple months ago.
You can build your own cup press tool with some big washers, nuts and a long threaded bolt. Some PVC pipe is all that's needed to set the crown race.
