Making an old road bike lighter
Bikes: 1985 Fuji del Rey (stolen 🙁), 2021 Soma Double Cross
My girlfriend has an old 1980s Miyata road bike. It’s not a high end bike, but it rides well and has a lot of sentimental value. The only problem is it’s HEAVY, like over 30 pounds (over 35 with a rear rack, basket, lock, etc. attached). I’d like to make it lighter for practical purposes, like carrying it up and down the stairs.
The best solution would probably be buying a lighter bike, but given the sentimental value I’d prefer to keep the current frame. The reason it’s so heavy (other than the heavy 1024 steel frame) is that almost all the components are steel. I think I could save a good bit of weight by switching some components to aluminum.
Here are the changes I’m considering:
Which changes seem worth it? Let me know if any of my estimates (weight or cost) look off.
- Tires. This might be a no-brainer because the tires could use changing anyway. It currently has Schwalbe Active Line K Guard tires (27x1-1/4). I could save ~200 g per tire by switching to something like the Panaracer Pasela (going by the official listed weights).
- Estimate: 14 oz, $60
- Wheels. The wheels have steel rims and spokes. I’m not sure if it would be better to buy new complete wheels or swap out the rims (and maybe spokes) for aluminum and rebuild using the current hubs and freewheel. I expect this would be the largest weight savings, but also the most expensive change.
- Estimate: 2 lbs, ~$200? (not sure on price)
- Seatpost. Save a few ounces by switching to a cheap aluminum seatpost.
- Estimate: 5 oz, $20
- Handlebars and stem: change steel to aluminum
- Estimate: 8 oz, $40
- Pedals: change the big chunky steel pedals to cheap aluminum
- Estimate: 6 oz, $30
- Chainrings/crankset: It looks like the current chainrings are steel but the crank arms are aluminum. Could save a few ounces with aluminum rings.
- Estimate: 3 oz, $50
Bikes: Cuevas Custom, Cimmaron, 1988 "Pinalized Rockma", 1984 Trek 510, Moulton custom touring, Raleigh Competition GS, Bridgestone Mb-2 & 3, 1980's Peugeot - US, City, & Canyon Express (6)
Quoted: 1169 Post(s)
Liked 4,096 Times
If you really want to upgrade your Miyata, understanding your starting with a "heavy 1024 steel frame", probably the way to go is buy a "donor bike" on craigslist, offerup, facebook, etc and swap everything over. You will need to match up specs, but the market is soft and you can likely grab a whole bike for less than price it would cost you to buy just rims.
Likes For SoCaled:
Bikes: !982 Trek 930R Custom, Diamondback ascent with SERIOUS updates, Fuji Team Pro CF and a '09 Comencal Meta 5.5
Quoted: 1314 Post(s)
Liked 763 Times
Wheels, tires/TUBES, and a hollowtech (or lighter)crankset (Much higher Weight loss than just rings!), in that order... they are all Rotating Mass and will be felt immediately when riding.
and FYI.. there are some MUCH Lighter seats available.. but convincing someone to give up a easy chair for a skinny stool is not easy... i recently test fitted 6 seats for a customer before we found the correct seat... it was much narrower than what she had been considering, But "just feels right!" and she called in to thank me again... no more chafing.!
and the new seat was almost a full pound lighter than the spring mounted easy chair that she was on previously. :-D
now i need to find another seat for my cannondale M600, but her happy smile was worth it.... ;-)
Likes For maddog34:
SE Wis
Quoted: 2756 Post(s)
Liked 3,427 Times
Likes For dedhed:
Bikes: 3Rensho SuperRecord Export, Bridgestones MB1 RB1 XO2, Colnago Super, Medici GranTurismo, Schwinn Paramount, Olmo Competition, Raleigh Portage, Miyata 1000, Stumpjumper, Lotus Competition, Nishiki Maxima, Panasonic DX6000, Zeus Criterium
Quoted: 31 Post(s)
Liked 91 Times
as a side note : years ago in brooklyn NY my girlfriend was riding a boat anchor raleigh sports 3 speed cruiser with steel components prob weighed 35+ pounds. just for fun i bought a cheap small sized dave scott centurion converted to single speed it came in at just under 19 lbs. we kept both bikes around while testing out the new one. after riding the centurion the raleigh was ridden less and less until it was sold a month later. she especially liked the centurion could easily be carried up the 3 flights of stairs
Likes For brooklyn_bike:
Bikes: '72 Peugeot PX-10 '78 Motobecane Le Champion '83 Motobecane Grand Jubile '85 Trek 830 '88 Merckx Team ADR Corsa Extra
Quoted: 472 Post(s)
Liked 1,218 Times
Cheap donor bikes are abundant. This one isn't far away.
https://www.facebook.com/marketplace...type=top_picks
Really Old Senior Member
Aluminum rims also stop much better than steel.Especially when wet.
Since your bike has 27" wheels, that's a fly in the ointment, trying to find good, used ALUMINUM ones.
Maybe your "donor" bike will be enough of an upgrade, she'll willingly ride it and put the old bike up in the attic?
Likes For Bill Kapaun:
Happy With My Bikes
Quoted: 887 Post(s)
Liked 2,358 Times
This is what I think I would explore first. If the Miyata has some sentimental value, will she be OK with so much of it being replaced?
SE Wis
Liked 3,427 Times
Old fart
Quoted: 3617 Post(s)
Liked 3,454 Times
Estimate: 5 oz, $20
Estimate: 8 oz, $40
Estimate: 6 oz, $30
Estimate: 3 oz, $50
By my estimates, I think I could save a little over 4 pounds if I made all those changes. The biggest chunk comes from the wheels, which is also the most expensive change.
Estimate: 5 oz, $20
Estimate: 8 oz, $40
Estimate: 6 oz, $30
Estimate: 3 oz, $50
Likes For JohnDThompson:
Quoted: 573 Post(s)
Liked 430 Times
Nothing you do will make these steel bikes lighter, and doesn't help that there's a ton of crap fastened to it.
Get a 2nd bike with nothing on it with the target weight you want, that way you can hoard the first bike without letting it go.
You'll see the new bike get used more, and heavy bike used less, or at least, when you need to buy bulk cat litter.
I too am sentimental with my high school bmx, but there is no chance in hell I will ride more than a mile on it, let alone 25 or 50.
Mother Nature's Son
Quoted: 866 Post(s)
Liked 1,463 Times
I had an Oschner, late ‘80s, I was sure I would never part with. I did just that 2 years ago, giving it to a nephew. I do not regret it, and do not miss it. Still sort of a connection, being that my nephew has it. I am sure he would allow me to ride it when I visit my hometown, which seldom happens, and I am pretty sure I would not ask. I always take a bike with me.
Clark W. Griswold
Quoted: 4521 Post(s)
Liked 4,220 Times
Find a more practical bike. This bike is old and of little actual value beyond maybe sentimental value. While you could go to the trouble of spending ridiculous amounts of money on a bike boom style bike and you could lose small bits of weight mostly from the wallet, the bike is just not a great candidate for it. Plenty of awesome vintage bikes with decent components and nicer frames or even better plenty of great modern bikes that give you better gearing and braking and will likely be lighterweight. You can save this and still ride it but don't pour a ton of money towards it unless the sentimentality is that great and even then strip the bike completely and put the frame on the wall so you can look at it daily.
Generally bewildered
Quoted: 1152 Post(s)
Liked 342 Times
I had a friend in college who had a Schwinn Varsity that he'd swapped aluminum wheels (rims and hubs) in for the steel. I think he'd also found a kit to replace the Ashtabula forged steel one-piece crank for alloy.
It still had the heavy, crappy Varsity frame but as i recall he kicked my tail (and I had a 531-based Raleigh Competition).
To the point of your question, I'd suggest that wheels and tires (rolling weight) would be the first change. Alloy or CF stem and handlebars, seat post, and seat. But do a budget and figure out if buying a donor bike which has all the parts you want to change can be had cheap. And reflect if all that work is worth it when the frame is standard unbutted carbon steel.
Quoted: 1163 Post(s)
Liked 1,845 Times
I see that the op is Chicago based. Bikes like that can get down to maybe 26lbs taking all the steel and swapping alloy parts.
Is there a co-op in that area to help you find the parts at a reasonable rates? Otherwise it could be cost prohibitive vs getting a different bike.
Quoted: 573 Post(s)
Liked 430 Times
If someone just putz around town filling their basket with weekly organics, it won't matter what kind of bike they have, and I think GF is fine with it.
Sounds more like the BF is mansplaining to GF about what HE thinks she SHOULD have.
Likes For soyabean:
Dirty Heathen
Quoted: 897 Post(s)
Liked 950 Times
I’d take the $300 or so that you’re going to spend on parts and look for something newer and lighter to hang the rack and basket on.
You’ll probably find that they already have most of the stuff you’re looking to install, and a lighter frame, too.
In my area, it’s not uncommon to find 1990s Cannondale hybrids or rigid 26ers for $200-$250.Treks and Spesh, too, but they’re just a little bit heavier. Even a base model H-300 would be 5-8 lbs lighter than that Miyata, right out of the gate.
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3946 Post(s)
Liked 6,637 Times
All of them ... if you can find a donor bike for parts or if you have a co-op with used bins.
When I did a lot of bike flipping, I always fully overhauled each bike and swapped out low level junk like steel seatposts and chainrings for aluminum replacements. I would never ride nor sell a bike with steel rims. Changing to aluminum rims is the biggest improvement you can make with a bike like this, not just for the weight savings, but for operational ridability.
Do not listen to the people who are telling you that an Eighties Miyata cannot be lightened.
Just this year, I built a steel '86 312 into a modern gravel bike, and it weighs only 21.1 pounds at 58 centimeters. Now, it might not make financial sense, depending on your situation, but it absolutely can be done.
In my case, I ditched the heavy 27" steel wheels, and built a set of aluminum 700s for it -- which cost me $316 and the pair weighs 1487 grams. Obviously the tires were replaced, and I went with Vittoria Terreno Drys, without tubes, that weigh 410 grams each. I replaced the entire cockpit, using an aluminum Easton gravel bar, and Shimano R7000 brifters. I replaced the rear derailleur with an R7000 11-speed unit, but I kept the original SR Sakae Signature crankset with its 52/42 chainrings, and front derailleur, because the former is cosmetically attractive, and the latter didn't really matter. Installed a CS-5800 11-32t cassette. I kept the original aluminum seatpost, which is both aluminum, and quite heavy at 341 grams -- it's a 26.8mm post, and not easy to replace. The brakes are also original Shimano calipers, with upgraded pads. It has a medium-weight saddle installed ( 292g ). I maintained the lovely original manganese steel fork, as well.
My total cost, including purchasing the entire complete, ride-able bicycle, was $883 -- then I sold the original wheelset for $75, and I still have a box of original parts that I may sell. All of the parts I installed were brand-new, except the saddle, and I replaced all the bearings as well. So it's a mostly-new 21 pound gravel bike for $808, and that makes financial sense for most people.
As you can see, had I been interested in spending more money, I could've gotten this bike even lighter than 21 pounds -- but I like it as-is. Many vintage steel bikes are simply not as heavy as many people assume.
If you do decide to listen to the people trying to tell you that your girl's bike is no good, drop me a line. I'm local, and might take it off your hands, so I can build another one.
Quoted: 899 Post(s)
Liked 864 Times
Like many above, IMO SoCaled nailed it. Considering your location you should have a plethora of donor bikes. You might look at bikes direct for one although they seem to be getting pricier these days.
Quoted: 2402 Post(s)
Liked 2,963 Times
Life is too short not to ride the best bike you have, as much as you can.
Likes For squirtdad:
Bikes: A Blue One and 2 Green One's, then there's the Yellow one. And oh, yeah, a Black One. Did I mention the Red One?
Quoted: 78 Post(s)
Liked 197 Times
With judicious use of money, you can usually shave 4 pounds off fairly easily on the older bikes. I got my 28lb. Dawes Galaxy down to 23lbs.
- Aluminum wheels, dbl. Butt spokes, folding tires, TPU tubes
- Aluminum handlebar
- Omni Racer titanium axle BB and aluminum drive line.
- lighter derailleurs and chain
- Aluminum seatpost
- Lighter saddle
- Lighter pedals
This all cost more than the bike is worth but it's my daily transportation in the summer and I like it, so don't care.
It's a 531 straight gauge triangle frame and was trying to get it to 20-21 lbs.... But that ain't happening.
- Aluminum seatpost
- Lighter saddle
- Lighter pedals
