"Wall hanger." (DIY fancy wall display)
www.theheadbadge.com
Quoted: 2446 Post(s)
Liked 4,466 Times
Not long ago, I posted some pictures of a room that I renovated to display some of the favorites. At the time, I was still short any wall displays to clear some room on the ground.
Not anymore.
These brackets took way too long to dream up, given how simple they look. Somewhere in the pinball of my brain, I came up with the idea of cradling the rims on two separate brackets, but from the top of the rim, not the bottom. This ensured that whatever the final product would be, it would be complicated enough that nobody could have possibly mass produced it. I was also dead set on finding something with a clean mid-century flair to it, oodles of chrome and capable of supporting any bike on display without contacting a painted area of the frame. Any one of these requirements are a tall order on their own, and "mid-century" usually brings up wood. That's fine for furniture, but I'm approaching this room as it was a styling exercise handed down from GM's Bill Mitchell himself.
I got lucky finding the above 16" brackets on eBay for a floating bathroom vanity. The seller claimed they were chrome, but they turned out to be stainless. No arguments there - no chrome to chip when drilling out the holes. Granted, the stainless has a slight yellow tint in comparison to the chrome plated bits, but I can't ask for everything. They're also dirty and as-delivered in these pictures; they cleaned up a lot better.
The cradles are half of a fork mount clamp for a motorcycle turn signal off Amazon.
....an adhesive rubber strip makes it look as if it belongs there.
Also note the nut cap cover, also a motorcycle part off Amazon, though definitely from the cheap-o bin unlike the clamps. It looks good though.
Unfortunately, the stainless brackets are a bit on the thin side, and so tend to deform under the pressure from the wedge anchors - no welded-in anti-crush sleeves here; rather a disappointment. I drilled the bottom holes larger - only on the front - allowing me to install a split sleeve as a pseudo shear bushing. In reality, the nut and washer on the bottom (not installed here) is pushing against the sleeve bushing, which is pushing against the backside of the rectangular stainless tube. It's more than "secure enough" though, so I'm pleased.
I would have done the bushing trick on the top as well, had I been able to get both the drill and drill bit jammed square in the triangle - but I couldn't, so didn't.
Here's the victim, Leo the Bottecchia (speaking of which, I somehow lucked into identifying it while posting this - the brand and badge hails from the Leo Chlorodont team). The bike is slightly twitchy up there, but I account a bit of that for the lack of a BB or crankset to help weight it down. The Nexus 7 and Dynohub do more than enough to ensure it stays there though, and I dare say I could help snug up the fit with 3D printed rubber inserts instead of the generic rubber pads.
Now I just need to luck into another pair of those brackets for the other wall. Back to finding a needle in a haystack...
-Kurt
Not anymore.
-Kurt
Likes For cudak888:
AdventureManCO, billytwosheds, BTinNYC, clubman, cyclic_eric, dedhed, Dfrost, dphi, Eric F, Ged117, jamesdak, John D, KonAaron Snake, Korina, kunsunoke, LeftCoastJon, Mad Honk, mhespenheide, mpetry912, nlerner, nomadmax, non-fixie, OTS, panzerwagon, pastorbobnlnh, PilotFishBob, qcpmsame, RALEIGH_COMP, Reynolds, rm -rf, roadcrankr, smd4, SpeedofLite, steelbikeguy, SwimmerMike, tiger1964, tkamd73, USAZorro, Velo Mule, velomateo, WaveyGravey
The Huffmeister
Bikes: '79 Trek 938, '86 Jim Merz Allez SE, '90 Miyata 1000, '68 PX-10, '80 PXN-10, '73 Super Course, '87 Guerciotti, '83 Trek 600, '80 Huffy Le Grande
Quoted: 1291 Post(s)
Liked 3,732 Times
Yes!
There were 135 Confentes, but only one...Huffente!
Freewheel Medic
Quoted: 1468 Post(s)
Liked 2,238 Times
Well done Kurt!!! A perfect addition to your bike cave.
Bob
Bob
Quoted: 3035 Post(s)
Liked 3,926 Times
Excellent work!
I don't want to hijack, is it OK to show other diy wall brackets?
Likes For iab:
Liked 4,466 Times
Quick note: For anyone curious why I fitted these to the wall with wedge anchors: There's no drywall in these 1940's-era Florida rooms. It's straight to CMU wall.
Ah, but true celebration would require hanging a Huffy on these.
Thanks, Bob! Also a relief too - I need to finish a number of small things on most of the bikes below for a show at the end of February, and the Racor freestanding bike rack I had in the room took far too much space. Now I can get to them for a change.
Please do, @iab - I found very few inspiration threads as I was coming up with this design and would love for this to become one.
-Kurt
-Kurt
Likes For cudak888:
The Huffmeister
Liked 3,732 Times
Likes For AdventureManCO:
Liked 3,926 Times
So you all have probably seen this pic of my basement.
Frejus by iabisdb, on Flickr
This is the mount. 2-inch diameter aluminum tubing, 1/8-inch wall. 2-inch diameter dowel. Scrap 8/4 cherry, but anything will do.
I don't have a lathe, so I manually "turned down" 3 inches of the dowel to the ID of the of the aluminum pipe, pounded it into the the pipe, a tight fit. Made a fixture to clamp 2 pipes with inserted dowel and used a 1 1/4-inch hole saw to make the cutouts. Since they were clamped together, the hole saw drilled "1" hole. It was easy. I used wood because the paint rests on wood, no real worries about marring the paint.
On the back I had my local welder add a piece of 1-inch x 1/8-inch flat stock to the pipe. I think he charged me $30 to do 12 of them. This allows the addition of the keyhole slot and a means to add the decorative cherry. It also may increase the load area onto the wall, but it may not and probably doesn't need to. Then, with a single screw driven into a stud, drop it on using the keyhole slot.
Likes For iab:
Liked 4,466 Times
Likes For cudak888:
Liked 4,466 Times
-Kurt
The Huffmeister
Liked 3,732 Times
And the wall with it if we're talking Huffys. But then again, why play w/ fire trying to break the universe? Mine lives squarely on the ground so as to not upset the space-time continuum
Liked 3,926 Times
Likes For iab:
Passista
Quoted: 886 Post(s)
Liked 748 Times
Very nice! Being such a cheapskate, I used A/C brackets and a recycled gas pipe to hang my bikes
Likes For Reynolds:
The Huffmeister
Liked 3,732 Times
South Carolina Ed
Bikes: Holdsworth custom, Macario Pro, Ciocc San Cristobal, Viner Nemo, Cyfac Le Mythique, Giant TCR, Tommasso Mondial, Cyfac Etoile
Quoted: 346 Post(s)
Liked 294 Times
Utilitarian, but these Stalwart Bike Wall Mounts work great. I have three in my garage and they work pretty well for fiddling with drive trains.
Quoted: 1652 Post(s)
Liked 853 Times
Just be aware that if you display your bike in front of a window, do it where the sun will not shine through the window because the UV rays will eventually fade your paint and dry out the rubber and plastic parts on he bike. A north facing window will be best.
72 Line Seeker
83 Davidson Signature
84 Peugeot PSV
84 Peugeot PY10FC
84 Gitane Tour de France.
85 Vitus Plus Carbone 7
86 ALAN Record Carbonio
86 Medici Aerodynamic (Project)
88 Pinarello Montello
89 Bottecchia Professional Chorus SL
95 Trek 5500 OCLV (Project)
72 Line Seeker
84 Peugeot PSV
84 Peugeot PY10FC
Insane Bicycle Mechanic
Quoted: 815 Post(s)
Liked 748 Times
Here’s my setup for showing off my favorite (now defunct) frame by itself. It’s a plank of maple with a couple stainless angle brackets to hold it to the wall. The stands for the axles is chunks of maple enclosing conventional QR axles with bolt-on skewers to hold the dropouts. The stands aren’t quite right- I carved them up with a handheld circular saw before I had my table saw set up.
(Don’t hate on the recumbent. It’s 25 years old and I broke it behind the head tube. Unsalvageable but still pretty.)
Jeff Wills
Jeff Wills
Likes For Jeff Wills:
Liked 4,466 Times
I do have to show you the Bad Idea Cranbrook (modern) that I'm converting into an e-bike. I didn't want the thing, but a really rough Bafang rear hub fell into my lap concurrently with this frame and some other unwanted parts. The hub was gladly purchased, but the rest showed up against my wishes (long story). The e-bike conversion is the most obvious way to get rid of everything without a loss, and it will involve the MIG welder.
I've noticed that shopping for decent "polished chrome" home goods is next to impossible, bathroom accessories included. It's as if the ban on chrome plating has expanded to a ban on chrome plated imports (though just to be clear, that's not the case, there's no ban on importing chromed goods into the US).
-Kurt
Likes For cudak888:
Semper Fi
Quoted: 1173 Post(s)
Liked 358 Times
Okay Kurt, you have me at “ involves a MIG welder”, you have to post this project here. Pretty please🙏
Bill
Bill
Semper Fi, USMC, 1975-1977
Likes For qcpmsame:
Freewheel Medic
Liked 2,238 Times
Kurt, the only cause for the lack of chrome plated fixtures in that designers and consumers want us to only purchase nickel fixtures. If you wait long enough chrome should re-emerge. You might try some salvage or antique shops. Of course you won't find that style, but you shoul be able to find something in chrome.
Bob
Bob
Likes For pastorbobnlnh:
Liked 4,466 Times
I wound up finding a US source, finally. $130 for five of those suckers. Ouch.
-Kurt
aged to perfection
Quoted: 856 Post(s)
Liked 1,288 Times
Very nice trick with those "motorcycle turn signals"
never would have thought of that !
/markp
/markp
Likes For mpetry912:
Bikes: Drysdale/Gitane/Zeus/Masi/Falcon/Palo Alto/Raleigh/Legnano
Quoted: 1016 Post(s)
Liked 699 Times
Possibly as bad as finding anything in polished brass. Which could also be an interesting motif from bike-display stuff.
Larry:1958 Drysdale, 1961 Gitane Gran Sport, 1974 Zeus track, 1988 Masi Gran Corsa, 1974 Falcon, 1980 Palo Alto, 1973 Raleigh Gran Sport, 1974 Legnano. Susan: 1976 Windsor Profesional.
Likes For tiger1964:
Liked 4,466 Times
Side note: The US source for those curtain rod hangers just sent me this:
Thank you for your order. I'm sorry to report that we can no longer access the Chrome finish in this bracket. The closest I have now is Polished Nickel. Please advise if you are willing/able to substitute - or - if you prefer a refund.
Here we go again.
-Kurt
Liked 3,926 Times
To be fair, curtain rod holders get zero wear/abuse. Chrome plating certainly isn't needed, Whats wrong with polished nickel? My 1939 Paglianti is polished nickel.
Liked 3,926 Times
And just my .02, an inset roller-curtain is the way to go for that window. Just sayin.
