Flats
Flats
Last year, I though was my bad year with 9 flats - don't recall each one, but I remember one was a pinch flat, couple of tire wire, thorn? and some because glass or small rock into the cuts on the tire - GP4SII or GP5s.
This year, just one month I got 3 already
Luckily, two of them were at the garage, result of thorn in the tire on a ride the day before. The other one was a tiny glass on a small cut on the road.
Does anyone patch the small cuts with rubber cement or some other thing?
Any good result to reduce flats?
Thanks
Thanks
Should Be More Popular
Quoted: 22702 Post(s)
Liked 9,059 Times
Likes For datlas:
Quoted: 233 Post(s)
Liked 323 Times
I run tubeless GP5000's and after about 1 year (5,400 miles), zero flats. Though many self sealing punctures, mostly from goat heads. So, if you aren't running tubeless, I would do that.
If you still want to run tubes, then I'd look at tire liners. They add significant weight, but are another layer of protection.
I think I tried Shoe-Goo or something like that just to try to fill a cut. As I recall it didn't work well. I also think anything you try for that purposes is at best cosmetic. And even then, likely to look worse than a little cut.
I wouldn't expect this to be an issue with an experienced rider/bf member, but lowering tire pressure, not riding in the "roadside rubble" might be considered along with avoiding some road conditions. Otherwise, tubeless certainly worth considering.
Quoted: 833 Post(s)
Liked 1,972 Times
Or, a more robust tire.
No, I'm not recommending Gatorskins.
I have had zero flats on Schwalbe Green Guards the past two years and have run over plenty of broken glass and road debris.
aged to perfection
Quoted: 852 Post(s)
Liked 1,282 Times
there used to be a kevlar tire liner that was very light weight. have not seen it offered for years
/markp
/markp
Pennylane Splitter
Bikes: Yes
Quoted: 1847 Post(s)
Liked 1,493 Times
Patch your tubes if the hole is small? From years of experience at it, I'd say take spares with you and patch the punctured ones when you get home. This is a totally unscientific observation, but the only problem I had with patched tubes is using higher pressure tires (+100psi). I'd found those tended to eventually leak at the patch. These days I'm riding on 700x32 or 35s pumped to 70-80 lbs max using puncture-resistant tires. No issues.
Quoted: 1610 Post(s)
Liked 1,800 Times
I was patching a tube roughly once a month for my two kids who bike to school. Then I changed their wheels to tubeless. In the roughly 1.5 year since I have not had to patch anything for them.
it’s a no brainer for people getting flats all the time
Quoted: 1366 Post(s)
Liked 1,689 Times
I did experiment with reinforced tires like gatorskins and one from Continental. They felt heavy and dull and sapped the joy out of the bikes. I will say though that the ones I tried were grippy and cornering felt good.
tl/dr...tire liners FTW!
Bikes: 1999 Giant ATX MTB, 2002 Lemond Zurich, 2018 Fuji Transonic 2.3, 2019 Specialized Tarmac Disc Expert
Quoted: 172 Post(s)
Liked 401 Times
Thanks
Thanks
I do patch tires but I do it at home after the ride. I have used Shor Goo/Patch on tires but it doesn't last too long before it wears off. It's best for filling cuts. Just spread it on like peanut butter and push it down into the cut.
climber has-been
Quoted: 3539 Post(s)
Liked 3,695 Times
I carry a small piece of ripstop nylon and a tube of super glue in my saddle bag, just in case I get a big hole. This has saved me from the "phone call of shame" at least once.
Likes For terrymorse:
Quoted: 833 Post(s)
Liked 1,972 Times
If the tire cut is large enough to see the tube inside when inflated, and the tire still has useful life in it, I will patch the tire from the inside using some ripstop nylon (backpack material) and rubber cement.
That is a novel approach I had not heard of.
Thanks!
Boot your tire
I carry a small patch kit, not to patch my tube (I carry spare tubes and patch when I get home) but to boot the inside of the tire if there's a large cut. I've heard people use dollar bills or GU packets as well. I have also used ShoeGoo to fill moderate cuts when I got home, but you need to use it on a deflated tire and let it dry and trim the excess.
