Campagnolo bb spindle measurements?
Mid 60’s Paramount tear down . Looking at the Campagnolo bottom bracket , the axle / spindle is stamped with 120.
Decided to measure it with my calipers and I’m getting 112 mm end to end.
Whats up with that? Just Campagnolo weirdness or what?
thanks
thanks
Bikes: 1968 Raleigh Super Course, 1972 Raleigh Professional, 1975 Raleigh International, 1978 Raleigh Professional, 1985 Raleigh Prestige, 1972 Schwinn Paramount, 1980 Schwinn Voyageur 11.8, 1960 Carlton Franco Suisse Peugeot PX10, 1972 Motobecane Le Champ
Quoted: 326 Post(s)
Liked 697 Times
The 120 stamp on the spindle means that this bottom bracket is to be paired with a frame spaced 120mm at the rear dropouts. Your getting the correct reading from your caliper.
Makes sense even to me. Thank you for the info.
Quoted: 3470 Post(s)
Liked 2,844 Times
only a concern if you want to use say 6 in a diamond drive side crank arm or later.
6 can be either, not terribly hard to tell.
Likes For repechage:
There is a good article here:
https://www.retrobike.co.uk/archive/...ol-1-no-2.343/
Where "all is revealed" ... :-D
