Gitane rat rod...
ambulatory senior
Quoted: 1957 Post(s)
Liked 3,669 Times
Gitane rat rod...
I've had this tour de france frameset for over a year and lately been picking up completely rusted out bikes for their sturmey archer hubs and associated parfenalia. Turns out if they look horrible 25$ buys em and I have a friend who wants the frames. Anyway these two things come together nicely. My gitane frameset didn't have a derailleur hanger and it has massive clearance for 650b tires without any modification. So I built an inexpensive set of wheels. Zac19 rims, aw hub out back and shutter precision up front. The aluminum caliper brakes off a completely decimated Schwinn speedster reach the rims and off we go. I have a ways to go but wanted to show someone what my flu racked body was up to. Btw, I know the skewer is in backwards and the basement's a mess.
Gear ratio will probably go up a bit.
Quoted: 3824 Post(s)
Liked 6,789 Times
Nice! How did you deal with the wider spacing of the rear end on the Gitane as compared to the Schwinn?
Likes For nlerner:
Quoted: 3844 Post(s)
Liked 3,406 Times
with those 650's in there the arrestor centres appear to be in the vicissitude of eighty mm
good to see those CLB guidonnets - this will give IdahoBrett an opportunity to view how they appear...
handsome Motorbeacon there in the shadows...
hope U R feelin' mo' beddah nowadays
Likes For juvela:
ambulatory senior
Liked 3,669 Times
It's not much different and in fact the gitane is wider by a hair. It may have been massaged before, the frameset is pretty rough looking. Anyway, I flipped the anti rotation washers over and it went together well, but I wouldn't mind using the proper anti rotation washers designed for derailleur bikes as they do a better job of centering the wheel vertically.
Likes For 52telecaster:
ambulatory senior
Liked 3,669 Times
Liked 3,406 Times
maybe you could get together with jeirvine to form a MAEDA "backwards" front mech appreciation society...
...thinking of renaming my town "top normal"...
Likes For juvela:
Quoted: 485 Post(s)
Liked 659 Times
Looks like huge fun ‘52! My own experiments along these lines have tended to land on upright bars, as me old back is aging (not the rest of me, nope!). Is it my imagination or are the chain stays really quite short for the size of the frame?
Likes For markk900:
Quoted: 949 Post(s)
Liked 3,045 Times
Looks like a fun time!
Likes For ascherer:
The Huffmeister
Bikes: '79 Trek 938, '86 Jim Merz Allez SE, '90 Miyata 1000, '68 PX-10, '80 PXN-10, '73 Super Course, '87 Guerciotti, '83 Trek 600, '80 Huffy Le Grande
Quoted: 1275 Post(s)
Liked 3,666 Times
This is the second Gitane TdF thread I've seen in 24hrs and it is making me reconsider where on the priority scale rebuilding a neglected TdF in my garage should sit at. You start reading about these bikes and about how much folks gush over their superlative ride - it is not isolated. Hmmm! Things to think about.
There were 135 Confentes, but only one...Huffente!
Likes For AdventureManCO:
ambulatory senior
Liked 3,669 Times
Typically I go upright bars too but wanted to use these because they are so cool and french, plus the levers encourage being on top anyway. It's French fit for me as the frame is at the large end for me and this would probably get used like my super course three speed. The difference is this bike was definitely set up for sewups. 700c wheels won't remotely allow 35s and fenders. Oddly enough though there is a ton of room for chunky 650b. 42s fit easy. It really is a pretty sporting frame. Top gear will be around 70" or less so climbing river bluffs is easy with 40" or less and yes, the shorter chain stays help with climbing. Still experimenting.
ambulatory senior
Liked 3,669 Times
ambulatory senior
Liked 3,669 Times
ambulatory senior
Liked 3,669 Times
Just to delve into the pedigree of this frame I'd like to post a few detail shots.
Down tube shifter stop.
Fork crown
Seat cluster
No sign of ever having a derailleur hanger as far as I can tell.
And my goofy super bright tail light. My girlfriend is going to try painting the lenze.
Fork crown
Seat cluster
Liked 3,406 Times
this is the first TdF example seen from this era to be fitted with Juy ends set Nr. 881-881B -
...conditions of the boom: "use what you can get"
ambulatory senior
Liked 3,669 Times
Liked 3,406 Times
alas, am not one of the forum's MICMO experts
it certainly appears early seventies
one demarcation is the seat stay treatment at the seat lug
some received the "willow leaf" while others received the simple cutting out of a wedge and crimping as seen on your example
also some received "fish mouth" treatment to the stay ends where they join the dropouts while others exhibit "domed" ends
verktyg has given very specific dates for these differences in his posts
do not have them in me noggin
Likes For juvela:
Quoted: 177 Post(s)
Liked 331 Times
Your frame still has the brazed on bracket for the rear brake cable stop, whereas my 1973 TdF was shipped withe MAFAC hanger on the seat binder bolt, so pre-1973.
You also have the long-point lugs rather than the short-point Bocama the latest foil-era TdF's had.
My 1973:
Overdue for a refresh...
Member Hummer posted a thread to decode the Gitane serial number on the NDS RDO:
https://www.bikeforums.net/classic-v...l-numbers.html
My 1973:
72+76 Super Course, 74 P-10+ 79 Tandem Paramounts, 84 Raleigh Alyeska, 84 Voyageur SP, 85 Miyata Sport 10 mixte and a queue
Likes For Schreck83:
ambulatory senior
Liked 3,669 Times
My 1973:
My 1973:
ambulatory senior
Liked 3,669 Times
It appears I may have a 1971. Hard to be sure as the numbers on the dropout aren't super clear but that would make sense. I'm using a 1967 aw hub for whatever that's worth.
Bikes: Still have a few left!
Quoted: 467 Post(s)
Liked 541 Times
What mess? your goat (greatest of all time) TdF Rat Rod needs that hay bale!
Likes For ollo_ollo:
ambulatory senior
Liked 3,669 Times
Bikes: 1981 Raleigh GP, 1985 Norco Bush Pilot, . . .
Quoted: 243 Post(s)
Liked 192 Times
I have looked at your frame and tried to match it to Gitane frames with a date code serial number.
The Tour de France head tube lugs changed during the early 1970s.
I found a match with the same decals and head tube lugs. That frame was dated as week 3 of year 1973.
You can see that Gitane Tour de France on another forum's thread:
https://www.velovintageagogo.com/t17...-reynolds-1969
Bon appetit.
Bon appetit.
Likes For Hummer:
ambulatory senior
Liked 3,669 Times
Bon appetit.
Bon appetit.
ambulatory senior
Liked 3,669 Times
Last pic I swear.
