Winter Project Finished
Bikes: A Blue One and 2 Green One's, then there's the Yellow one. And oh, yeah, a Black One. Did I mention the Red One?
Quoted: 78 Post(s)
Liked 197 Times
Actually one of three Winter Projects. The next will be done in two weeks and the last will probably be a Spring finish.
1950 MacLean
I bought this nearly two years ago and it had been thrown together from a frame for display and eventual sale. It had no correct parts on it at all.
This will be in a 20 mile per day rotation come Spring so it needs to be comfortably ridable for me and period correct as possible. All my pre 60s bikes are mostly period correct sans consumables.
It ain't easy, or cheap.
- Full 531DB 24.5" Frame & Fork
- Constrictor Asp 597 rims, BH Racelite Hubs
- Cyclo Mk7 4 speed Drive line
- GB Courier Calipers & Levers
- Lamps are battery LED converted
As it sits it only weighs 28lbs. Without any accessories it's a svelt 24lbs. Sweet and nearly rides itself.
1950 MacLean
Likes For macstuff:
ambulatory senior
Quoted: 1957 Post(s)
Liked 3,673 Times
Wow is that beautiful.
Bikes: Raleigh Classic 15, 84; Miyata 912, 85; Miyata Ridge Runner SE, 85; Miyata 610, 86; Miyata 100M, 86; Miyata Valley Runner, 88; Miyata Triple Cross, 89; GT Karakoram, 90; Miyata Elevation 300, 91; Marinoni Touring, 95; Long Haul Trucker, 2013
Quoted: 162 Post(s)
Liked 135 Times
Soooo nice!
Likes For John Nolan:
Bikes: 1981 Bianchi Specialissima, 1971 Bob Jackson. 2012 Kestrel 4000. 2012 Willier. 2016 Fuji Cross 1.1, 1950 Hetchins, 194X James Fothergill, 1971 Paramount P15, 1973 Paramount P12, 1963 Legnano
Quoted: 282 Post(s)
Liked 986 Times
Great job! I really like the choices you made.
Quoted: 5915 Post(s)
Liked 3,567 Times
Very nice. Why no Brooks saddle? I have a 50s era Claud Butler I need to build up one of these days. It will be a sympathetic restoration rather than a completely period correct one.
Likes For bikemig:
Quoted: 1009 Post(s)
Liked 1,693 Times
Can I take it out for a ride?
NO! Its Mine!
Great work... Bike is fantastic...
Likes For zandoval:
Quoted: 78 Post(s)
Liked 197 Times
The saddle on it now is very nice and like sitting on a bench. It's a Selle Royale Scientia R3. Fairly light and very comfortable.
Likes For macstuff:
Liked 3,567 Times
I tried a few different Brooks on there but I'm old now and can't ride in the drops. I've got to ride upright and sitting 80% of the time. I may get a new reissue B72 and try but I haven't run into a vintage 72 in good enough condition so far.
Likes For bikemig:
Quoted: 3873 Post(s)
Liked 3,472 Times
lovely machine and so beautifully done
is the clip style headset a CL product to go with the chainset?
from what can be seen in photos it appears to bear no marking which makes me suspect Brampton
did it come with the frame or did you need to seek it?
believe the Gerald Burgess arrestor set may be one of the Coureur models rather than Courier
VB give two variation of Coureur sidepull said to have launched nineteen fifty
https://velobase.com/ViewComponent.a...117&AbsPos=246
https://velobase.com/ViewComponent.a...117&AbsPos=247
[images courtesy of VB]
surprised not to see the clear cable casing with white fabric liner employed by Mr. Burgess
is it the case that no replica has been produced?
is dual binder stem a Reynolds?
what drive chain did you select; was thinking that a Renold with beveled plates may have been OEM
thanks again for sharing this terrific project
Quoted: 78 Post(s)
Liked 197 Times
A Witcomb and a Dawes came in just last week, as well as an Italian.... G...something, and a couple Miyatas. Always interesting even if 1/2 are junkers.
Let me know if you need stuff, I've got he "in" for fairly cheap vintage parts.
Likes For macstuff:
Quoted: 78 Post(s)
Liked 197 Times
Second, yeah, those are them, spelled British sideways.
The clip is unmarked and came with the Bike. Like many, it was cracked at the base so Ive modified the action and retain it for looks. I actually have a GB HIDUMINIUM Girder clip stem I may try to use later on. Right now the Reynolds twin bolt is happy in the breeze.
The chain is a SRAM 1/8". The entire driveline is 1/8" and clunks in and out of gear smartly.
Bikes: 2017 Sage Skyline, 2015 Co-Motion Periscope Tandem, 2012 Soma Smoothie, 2006 Kona Jake, 1978 Richard Sachs, 1977 Peugeot UO18c, 1977 Peugeot PRN10, 1974 Allegro Schweitzermeister Model 76, 1972 Hugo Rickert Spezial, 1971 Fuji Finest
Quoted: 120 Post(s)
Liked 640 Times
Chater Lea?
Is the whole crankset CL or just the rings?
Quoted: 78 Post(s)
Liked 197 Times
No, the Chain ring is the only thing on the bike CL. 42t.
The crank is a Williams 1200 with Bikesmith modified cotters. BB is a TDC "lightweight."
One of the trickest parts on the bike are the pedals. They are amazingly light. Actually rival lightweight pedals of today at 130g each. They have hollow spindles.
Likes For macstuff:
