Where to mount a rear Light on a Road Bike with an Under Seat Bag?
Bad picture but it's all I have right now. Is that the best way to mount the rear blinky light? Seems like it's facing downward a bit. Any other suggestions?
Tinker-er
Bikes: 1956 Rudge Sports; 1983 Univega Alpina Uno; 1981 Miyata 610; 1973 Raleigh Twenty; 1994 Breezer Lightning XTR; V4 Yuba Mundo aka "The Schlepper"; 1987 Raleigh "The Edge" Mountain Trials; 1952 R.O. Harrison "Madison"
Quoted: 177 Post(s)
Liked 291 Times
If I'm riding a bike without a dynohub, I personally use multiples; one on the bag, one on my belt or sweater scoop (pocket). If I'm on a bike that has built-in lighting, the rear light is high up on the left side seat stay, but still below the lowest point my bag can block; and that's a Carradice Barley, so it's a substantial bag. I haven't yet gotten one fit to the helmet, but that is a sensible idea too.
Likes For Bogey Speedwell:
Quoted: 233 Post(s)
Liked 323 Times
Some bags have places for lights to clip to. There are also mounting systems for lights to attached to the saddle. Some use mounts specific to a given saddle, but there are versions that attached to standard saddle rails. I've used something like that to mount a Garmin Varia radar unit. Even though the radar unit hangs down, it cleared the large Topeak wedge saddle bag I was using.
I got that at Bup Labs
https://buplabs.com/
Likes For Mtracer:
Quoted: 5909 Post(s)
Liked 2,777 Times
I prefer using seat stay bracket. This lets me go as high as possible staying below the bag. If your seat is high enough, you can also improvise a bracket using the brake bolt.
FB
Chain-L site
FB
Chain-L site
Quoted: 1366 Post(s)
Liked 1,689 Times
Here's my seat-stay mounted rear light from 9 years ago.
Likes For BobbyG:
Likes For 13ollocks:
For The Fun of It
Bikes: Lynskey GR300, Lynskey Backroad, Litespeed T6, Lynskey MT29, Burley Duet
Quoted: 2137 Post(s)
Liked 1,650 Times
Turn it on and walk a couple hundred feet away to see how it shows. Mine aren't perfectly oriented but still show bright.
Likes For roadfix:
Quoted: 913 Post(s)
Liked 2,097 Times
IMO the light needs to be rigidly mounted and aimed level. I don't use low seat stay anymore, after seeing a friend seemingly disappear a few hundred feet in front of me. The road was gently curving right, just so his wheel obscured the light. Yikes.
Seat stay above the wheel, or below bag level on the seat tube or seat post. This can be difficult on a short frame. An alternative is one on each seat stay. Helmet is a great second location, but isn't consistently aimed correctly to be primary.
Likes For downtube42:
When I buy rear lights, I make sure they have mounts for both seat post and seat stay. I use both. If you just use one on the seat stay, make sure it is on the side facing traffic and as high as possible.
I would never put a light on a seat bag, jersey pocket or backpack. Those lights are almost never facing the proper direction and are often not seen by approaching traffic. I use Cygolites, which come with both seat post and seat stay mounts, but many other brands offer them as well.
Here's my thread when I had issues mounting my Garmin Varia
https://www.bikeforums.net/electroni...-question.html
Quoted: 5234 Post(s)
Liked 3,609 Times
left rear seat stay. there are lots of slender units out there now w/ decent mounts
Probably not your cup of tea but every bike I use, I install a pannier rack. So I'd put the bike light at the very end of the pannier rack.
Liked 3,609 Times
Standard Member
Bikes: 1948 P. Barnard & Son, 1962 Rudge Sports, 1963 Freddie Grubb Routier, 1980 Manufrance Hirondelle, 1983 F. Moser Sprint, 1989 Raleigh Technium Pre, 2001 Raleigh M80
Quoted: 1302 Post(s)
Liked 949 Times
Get a clip-on type (Planet Bike has one), and clip it to the waist of your pants, your collar, or your pack.
"In every job that must be done, there is an element of fun. You find the fun, and - SNAP - the job's a game!"
I have the issue that I have a low seat and I'm using a Surly rear cable hanger. I just got a Varia and then I mount it to the seatpost it hits the rear cable hanger and is forced sideways. Did you see anything that might help with that?
EDIT: here's a photo
Likes For Saxicola:
Liked 3,609 Times
see post #9 here
mounting lights is similar to mounting fenders in that sometimes one has to be creative & crafty
Likes For rumrunn6:
Bikes: Columbine, Paramount Track Bike, Colnago Super, Santana Tandems (1995 & 2007), Gary Fisher Piranha, Trek Wahoo, Bianchi Track Bike, a couple of Honda mountain bikes
Quoted: 193 Post(s)
Liked 111 Times
After getting hit from behind on a wide straight road, I decided to come up with a better light than the typical bike light. Emergency vehicle flasher powered by a 12v makita battery. The one on our tandem is mounted to the rack and my commuter bike has one on the seatpost.
Cheers, Mike
Cheers, Mike
Likes For PromptCritical:
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2663 Post(s)
Liked 5,862 Times
That is one ginormous seat bag which makes a seat post mount difficult.
Mine is half to a third of the size and contains: Spare tube, tire levers, tire boot, 3 patches and glue, multitool, valve core remover, 2 CO2s and head. I can affect any repair with what I carry. Yes it’s all crammed in there, but all of it fits, plus it is a bit more aero.
Consider a smaller bag, pack efficiently and then a seat post mount is no issue.
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
