Shimano 105 shifter lost its click
Hello
I have a 105 front shifter here which won't drop from the big to small ring. Happened all of a sudden on the road.
Cable tension etc is OK. When I push the lever rightwards, the smaller metal lever that usually clicks up and right simply swings out without any resistance and then stays stuck out towards the bike stem. I can push it back easily - no resistance on it.
I've (technical term) spaffed a load of W5 into the lever having taken off the cover and removed bottom plate.
What next? Site won't let me attach a pic unfortunately but hope above is clear enough.
Thanks in advance
Thanks in advance
Quoted: 4236 Post(s)
Liked 3,963 Times
How about which model number and which double/triple? Some had known issues with internal breakages, all are like any STI lever in that in time the lube dries out and becomes gummy.
Sure sounds like something might have broken inside to have come on so suddenly. Are you able to shift off the big ring with any lever fiddling? Or is the shifter still stuck in the big ring? Andy
AndrewRStewart
AndrewRStewart
Liked 3,109 Times
If the brake action is engaged, it'll not let the shifter execute its sweep.
-Oh Hey!
-Oh Hey!
- no amount of fiddling with the shifter itself or the small metal lever it usually clicks into place shifts the gear. It remains in big gear
- brakes loosened off and everything moves freely with the shifter, just without any weight/resistance behind the small metal lever when trying to shift
Liked 3,109 Times
Using your finger, try pulling the metal lever as you move the plastic lever at the same time.
-Oh Hey!
-Oh Hey!
I assume it's possible that whatever action the metal lever has, the piece it connects to inside has broken?
Quoted: 861 Post(s)
Liked 1,103 Times
Opened it up some more to flush out and found what appear to be the remains of a spring attached to the end of the small metal lever. Assume a spring normally attaches it to another part in the mechanism and that this has snapped? New shifter time I assume. Thanks for help
Likes For danieljnolan:
Quoted: 6345 Post(s)
Liked 4,948 Times
Have you released the cable from the pinch bolt on the FD and then pulled a few inches out of the STI to make sure it isn't frayed?
If you put your pic's on the Gallery here at BF, we can find them. But today you should be able to get your additional five posts answering various questions or making useful comment in other threads. Still might need another day though after getting that magical total of ten posts.
Likes For Iride01:
Quoted: 682 Post(s)
Liked 456 Times
Quoted: 7118 Post(s)
Liked 11,276 Times
You can stop wasting WD-40, because your shifter is broken. Same thing happened to one of mine.
The solution is a new STI unit.
