Will these cranks bottom out if installed on this square taper bottom braket?
I've been working on an old Specialized Rockhopper, now getting to installing cranks. The cranks are New Albion XDT triple cranks. I popped them on by hand without tightening, and they look awfully close to the bottom bracket and frame. I'm concerned that the cranks will bottom out. Also worried there might not be clearance for the crank arm from the chainstay once installed. There only at most a few mm before reaching the end of the taper, where it looks like there is also some sort of stop or seal. Is this typical? Will these install correctly? Would getting a wider bottom bracket be preferable?
The manufacturer specifies a 113mm spindle for 47.5mm, which from reading Sheldon Brown (and other places) is correct chainline for mtb triple. So that is what I got—a Shimano BB UN300 73x113. I'm not sure these cranks are meant for a mountain bike however, since they are listed as touring cranks. Could this be contributing to the issue?
Thanks!
Thanks!
Likes For The_Joe:
Edumacator
Quoted: 2536 Post(s)
Liked 3,360 Times
Dang. No room for error there. Those bb-300s are sort of different than the previous iterations that worked really well. The collar bothers me.
The old cartridge BB-series were much more easy to predict.
1987 Crest Cannondale, 1987 Basso Gap, 1992 Rossin Performance EL, 1990ish Van Tuyl, 1985 Trek 670, 2003 Pinarello Surprise, 1990ish MBK Atlantique, 1987 Peugeot Competition, 1987 Nishiki Tri-A, 1981 Faggin, 1996 Cannondale M500, 1984 Mercian, 1982 AD SuperLeicht, 1985 Massi (model unknown), 1988 Daccordi Griffe , 1989 Fauxsin MTB, 1981 Ciocc Mockba, 1992 Bianchi Giro, 1977 Colnago Super, 1971 Raleigh International, 1998 Corratec Ap & Dun, 1991 Peugeot Slimestone
e: to be actually helpful - try it. install the chainrings and order a crank puller if you haven't yet. If it bonks anything, you need a longer spindle. Different bikes have different chain stays and so on, usually the spec sheet steers you right but you cannot be totally sure without trying.
Quoted: 2394 Post(s)
Liked 2,950 Times
I would put the rings on and see if you have clearance. you could use a spacer also to move BB out a bit
Life is too short not to ride the best bike you have, as much as you can.
Likes For The_Joe:
Quoted: 433 Post(s)
Liked 1,021 Times
From the pics it seems fine. Throw the chainrings on, mount it and see how it fits.
If you do have to replace the BB, I’d go with something better than the UN300. They tend to wear out pretty fast because of the tiny bearings.
If OP was able to put in a bottom bracket backwards against the threads on both sides I doubt they'd need us at this point.
I have a crank puller. I've installed a few dozen square taper cranks in the past. Never had one sit so close to the bottom bracket before even tightening. I double checked other current bikes and none are that close on the taper even after installing. But those cranks are all, like the bikes and bottom brackets, older. So perhaps things have changed with new cranks and bottom brackets. Or maybe this is just wrong.
So you don't think there is any risk of damaging the cranks by just installing?
So you think this is a typical/acceptable room on the taper before tightening the crank bolts at all? If so, it means the cranks would not move very far during installation. I don't think I've paid attention in the past to how much closer they go when installing the past since it never seemed worrisome.
Fair question. I've made plenty of boneheaded mistakes in the past. But I'm pretty sure the bottom bracket is installed the right way around. The threading would not allow this (without very significant damage I suppose). There are L and R markings on the BB, and directional arrow on the NDS cup. And the spindle itself does not seem to be reversible/detachable like a cup and cone BB.
Car free since 2018
Bikes: Mostly japanese ones
Quoted: 260 Post(s)
Liked 270 Times
Looks suspiciously like a Sugino XD2. Maybe OEM is Sugino? I do have an XD2 on a 113 spindle, but not on a mountain bike. Works fine.
Quoted: 66 Post(s)
Liked 63 Times
I love triple cranks. Being on my first resto job (Panasonic Tourist), I'm amazed at all the different standards for bicycle parts. My research on the Internet tells me that it's not getting better; if anything, it's getting worse.
Stop reading my posts!
Quoted: 1468 Post(s)
Liked 1,106 Times
hard to be certain with the angle of the shot but I'd say this spindle is too short (at least on the DS): I think the granny and/or middle ring might hit the chainstay, but you should do a "dry fitting" and see for certain. No reason to rely on anybody's guesswork based on one photo!
When you do get it all-on take a ruler and measure from the C/L of the seat tube to the C/L of the middle ring, should be about 47.5 to 50mm (per St. Sheldon, peace be upon him )
Chainring clearance and chainline aside, my primary concern was if installing the cranks on what looks to be a super tiny amount of remaining taper would bottom out and/or damage the crank.
My thought was that this was not meant for a mountain bike, and perhaps there is an issue with the difference between a 68x113 and a 73x113.
Quoted: 4882 Post(s)
Liked 4,049 Times
I'd put the rings on, mount it and start tightening. Stop and look often. Watch for that collar hitting the BB shell. Won't do much harm if it does except make the bike unridable. And scuff the collar where no one will see it. Watch for any of the chainring teeth hitting - paint. Watch for crank hitting - paint. If all those clear and you are up to torque - ride it! (Unless the teeth and crankset are within 2 mm or so and you are strong. More if the bike frame is flexy.)
If the crank is close, watch the other side too.
Liked 1,106 Times
This has only happened once in my many builds but I had a re-threaded BB shell (Brit shell with Ital threading so "Frankenbike" material) and everything else was "within spec" Good chain line, spindle taper and length but the Shimano 600 crank arm center casting came too close to the BB cup for my comfort.
So I took it to the bench grinder and removed some material off the backside!
Did not affect the fit but did create some clearance that wouldn't have been there otherwise.
Quoted: 805 Post(s)
Liked 1,839 Times
To make things work just add a 2mm drive side washer then adjust the shifters rest to work. I have done s bunch Shimano stuff this way seems to work just fine if the frame is good
Quoted: 2368 Post(s)
Liked 1,761 Times
Looks to me like the arm would hit the chainstay, or at least come to within a couple coats of paint distance.
Quoted: 822 Post(s)
Liked 3,074 Times
Q factor/
your crankarm end appears too close to the chainstay no? think the older un BB's were longer on the drive side.the new style are equal lengths.the next 73mm un300 available is a 118 x 73. you maybe able to install a 2mm spacer on the DS to get by though as mentioned.if you still have the old BB measure the spindle length from the DS lip & compare to the UN300.
Okay, got the cranks mounted. The base of the crank reaches into the cup, but it seemed to install okay, and seems pretty solidly on there. The arm and 36t chainring clear the chainstays with sufficient room I believe. So I'm going to call this a success for now. Next step is to hook up shifting, and then it should be ready for a test ride. This is is intended to be a commuter for my wife.
Likes For drewfio:
