Nitto stem clamp diameter?
Can anyone tell just by looking if this Nitto stem is for 26.0 or 25.4 bars? Not sure if "T.W." is a clue or not.
Thanks!
Thanks!
Bikes: Yes
Quoted: 3278 Post(s)
Liked 4,020 Times
I think the T.W is a date code.
My Bikes
My Bikes
Bikes: several Eddy Merz (ride like Eddy, braze like Jim!)
Quoted: 1158 Post(s)
Liked 2,051 Times
Harbor Freight has really cheap calipers.
"Leave the gun. Take the Colnagos."
Good idea (I have calipers). For some reason I had figured that measuring the "hole" would not be helpful--but even with the bolt loose it's max 25.7 mm in diameter, so it's gotta be for 25.4 mm bars. Thanks.
Bikes: Yes
Liked 4,020 Times
If you have 26.0 bars, I'd see if they fit. A 25.4 might seem tight but slip in use. It looks like there might be a burr in the clamp area, so if 26.0 start to go in bit then snag it may just be that.
My Bikes
My Bikes
