I'm new member 1st time posting. CONFENTE?
When I saw the spades in the lugs I immediately knew I had something because I remembered calnago had the club sign on their lugs in the '80s when I was in high school. So I looked up spaded lugs and learned all about Mr Mario Confente -what a brilliant individual with a tragic end to his robust life and what a unique talent he was.
The spades on the lugs for the frame that I own are a different shape than what you see on the show bikes on this website and elsewhere they are more narrow.
And serial # is 76L55#.
IDK what the standard format was for his frames numbers, though I've read that he only made 135
I'm looking for your input thank you Bob
Also the shape of the forks including the crown and the way the chains stay in seats stay tubes merge with the rear drop out as well as the seat post tube at the top is identical to the Confente frames online. also the cable guide for the derailleur cables as they pass by the bottom bracket are on top of the bottom bracket brazed on the top of the bottom bracket.
Quoted: 1012 Post(s)
Liked 1,712 Times
Are you ridding it?
Likes For zandoval:
Quoted: 2660 Post(s)
Liked 3,225 Times
Likes For Trakhak:
Quoted: 3261 Post(s)
Liked 2,582 Times
Did the OP mean covfefe?
Likes For seypat:
Quoted: 18596 Post(s)
Liked 16,094 Times
What About Bob?
Quoted: 9685 Post(s)
Liked 6,421 Times
Liked 16,094 Times
Liked 6,421 Times
Forum Moderator
Bikes: Fuji SL2.1 Carbon Di2 Cannondale Synapse Alloy 4 Trek Checkpoint ALR-5 Viscount Aerospace Pro Raleigh C50 Cromoly Hybrid Legnano Tipo Roma Pista Vitus 979
Quoted: 3141 Post(s)
Liked 6,851 Times
Time to close
