Looking for an electric bike pump, screw onto valve type, doesn't need to be portable
I'm seeing mostly either rechargeable ones with usb chargers or 12v cigarette chargers, not much with ac plug that also have the screw on type to valve--I've always dislike the flip up type, feel like they put strain on the valve. I don't mind the rechargeable ones if that's all there is but would prefer an ac plug,
Quoted: 3633 Post(s)
Liked 3,059 Times
Sounds like you want a compressor.
Likes For smd4:
Quoted: 2388 Post(s)
Liked 2,938 Times
way overkill but as I have milwaukee 18v tools I got the Milwaukee inflator..... I added a silca chuck
you can preset desired pressure (multiple pre set) work great for bikes and cars
I am normally a why use power if I can use a simple hand tool, but this is so slick
https://www.milwaukeetool.com/Products/2848-20
Life is too short not to ride the best bike you have, as much as you can.
Likes For squirtdad:
I then use Avid Power tire inflater that comes with 20v rechargeable battery that I use it for my bikes and car tires. I also have an impact wrench from the same maker, and the battery fits both. If you want a bigger battery for an added power while working on cars, you can buy 40v rechargeable battery. As for me, I never needed more than a 20v battery. It doesn't come with a screw on valve though, but I have never felt I needed one.
https://www.amazon.com/Inflator-Comp...07CTGM2LD?th=1
P.S. I only check and pump air in my bike tires once in three or four weeks, and I do it at home with the above tire inflater. I then carry a mini bike pump on my rides because it is small, weigh less, and easy to carry.
It's how you have to push in then flip to lock those kind of chucks, seems simple screw on type would be easier.
Quoted: 646 Post(s)
Liked 412 Times
alpharalpha: There are presta chucks that don't put the stress on the presta valve. I replaced the chuck on my Silca pump with the
. I recently purchased a
and screwed it into my new Stompump. Jaco makes an adaptor for there presta chuck that puts a male schrader on the end so you can screw it into many compressor lines.
While riding along the Arakawa, I saw a roadie refilling a tire with a portable electric pump. I suppose they work, and are probably more easy to use than most mini or micro pumps. But the ones I’ve looked at aren’t as light as I would like, and my charging table is already crowded with phones, watches, lights, cycle computers, action camera, etc.
Quoted: 1451 Post(s)
Liked 2,046 Times
do you have battery powered tools ? if yes - one option would be a compatible battery powered portable inflator
I have Dewalt battery powered tools - so I purchased the above portable inflator that operates with the same battery
I also have an optional AC adapter - but I have not used it (and they are fairly expensive)
this is one of my favorite tools - use it to inflate auto tires, garden tractor, trailer, wheelbarrow etc
if you have Milwaukee tools - squirtdad provided a link to the Milwaukee inflator
there are many other similar good options
