Campy Chorus ct 10sp Q
Buddy of mine has a bike with this group set and during a ride the threaded insert for the left crank arm sheared and ripped out.
He says he cannot mix in a different crankset to replace it if it is not from the same groupset, something he read from campagnolo. I'm under the impression he could swap it out for an 11sp or whatever but some input would be appreciated .
Liked 9,428 Times
Likes For big john:
Age made it necessary for me to switch to compact cranks. One of my bikes has a Chorus 10 speed setup and the other is a Chorus/Record mix. Both bikes went from the original Chorus square taper to Ultra torque cranks, but when I decided to go to compact cranks 10 speed compact ultra torque cranks were pretty much impossible to find. So, I bought a couple of Chorus 4 arm 11 speed Ultra Torque cranksets to make my bike more user friendly for my 72 year old legs. They work fine even though Campagnolo probably doesn't recommend them.
Liked 9,428 Times
Yes, that's Ultra Torque. Pretty tough to find a 10 speed Chorus crank but I did find a used 11 speed which works fine. The rings will work from the 10 onto the 11 but the 10 uses bolts and nuts but the 11 has threaded holes in the small ring, iirc.
A Fulcrum Racing Ultra Torque will also fit.
