Complete Tripleizer kit for a Stronglight Crankset!
Bikes: 2017 Sage Skyline, 2015 Co-Motion Periscope Tandem, 2012 Soma Smoothie, 2006 Kona Jake, 1978 Richard Sachs, 1977 Peugeot UO18c, 1977 Peugeot PRN10, 1974 Allegro Schweitzermeister Model 76, 1972 Hugo Rickert Spezial, 1971 Fuji Finest
Quoted: 120 Post(s)
Liked 638 Times
This is the complete kit, not just the 122 BCD tripleizer chainring. These are typically used to convert the more common Stronglight 93s but I used it on a Stronglight 49d. I ran it for a few years on a Peugeot PRN 10 I used occasionally for Randonneur events. You replace the stock inner chainring (usually a 42) with the tripleizer. It has 5 bolt holes for the granny ring and you attach the granny ring to the tripleizer ring. This gave me a 52/42/32 crank. I ran a long cage Shimano Crane in the back and it worked really well.
This “kit” has the middle tripleizer ring, the bolts, the spacers and a 32 tooth SR steel inner chainring. I am also including a 121mm spindle which is longer than the standard 113-118 mm spindle you would have on a typical double. This spindle gave the inner chainring the needed clearance on the Peugeot with room to spare, but your needs may vary so I can’t guarantee it will be sufficient for your frame.
Quoted: 843 Post(s)
Liked 2,213 Times
Hey Sactown Albert. I want it! PM incoming.
Likes For gaucho777:
Quoted: 120 Post(s)
Liked 638 Times
Quoted: 179 Post(s)
Liked 336 Times
Nice package! I’ll get in line, just in case.
72+76 Super Course, 74 P-10+ 79 Tandem Paramounts, 84 Raleigh Alyeska, 84 Voyageur SP, 85 Miyata Sport 10 mixte and a queue
Quoted: 958 Post(s)
Liked 3,110 Times
Shucks. Enjoy!
