Rear wheels sizes?
Bikes: Trident Spike 2 recumbent trike w/ e-assist
Quoted: 1321 Post(s)
Liked 374 Times
Rear wheels sizes?
I see trikes, same model, that comes with size options for the rear wheel. Does that mean the rear wheel size is interchangeable? Specifically, I am looking at the HP Gekco US sport model. You can get all 20" or 20" front with a 26" rearl. If i got the 26" rear model could that rear wheel be replaced with a 20"? I have a 20" rear wheel with hubmotor and might want to set it up for e-assist. But then at some point I might want to change to a mid drive and put the 26" rear wheel back on. Is that just a straight swap (other than aligning the chainline for the different cassete/hub combo)?
Quoted: 523 Post(s)
Liked 231 Times
It is pretty unlikely the frame is exactly the same for different sized wheels even though the trike has the same model name. If you buy one with a 26" rear wheel and then substitute a 20" wheel you might end up with problems with the RD being too close to the ground. My 20" wheel trike (Greenspeed GTO) uses a Shimano 105 short cage RD while my Catrike 700 uses a long cage RD. Both are the same distance off the ground at the lowest point. You might also affect the handling characteristics when making the switch.
Likes For VegasTriker:
Liked 374 Times
